LED Headlight Conversions
Discussion in 'Overland Alaska' started by benbacher, Jan 28, 2014.
  1. Jan 28, 2014 at 11:34 PM
    benbacher
    benbacher [OP] Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    821788DB-DF31-48FF-A8EB-D7111D7343DB_zps_ba329a779b686ea5cd9081bb69fafa1abb14df18.jpg
    9569FF09-6B77-4DF9-88CF-0636028AAC93_zps_15b8c04c75323d6a89a8a515c98eec7628bff66d.jpg
    TRUE LED Headlight Conversion Kits will give you the night vision that you need to drive safely at night and have more time to react on the road at lower and higher speeds.
    Specs:
    -5000K on Light Spectrum
    -1800 Lumens
    -25 Watts Running Power
    -2-3 times further vision that standard Halogen bulbs
    High Lumen LED Headlight! It provides up to 1800LM light, as the same as HID Xenon Light, however power consumption is only 25 watt. The life span of LED headlight is 30,000 hrs.
    Advantages over HID kits:
    No Delay when power on.
    No flicker
    No influence when Voltage drops or spikes
    Okay, thats it for the official schpiel, now my turn. We've installed dozens of these in the shop and they look and perform phenomenally. Every bit as bright as my projectors with the Osram bulbs and over ten times the longevity. One of our main clients for these is the local Toyota Service Department who's putting them in as factory headlamps! that should speak as a testimony to their quality. We all know the facts between LED and HID, you get reliability with one, and you get to swap out burnt bulbs with the other. We carry these for every make and model, even snowmachines and four wheelers can play!
    Online price is $249.99 plus shipping
    TW MEMBER PRICE IS $$225.00 SHIPPED!!
  2. Jan 29, 2014 at 12:17 AM
    benbacher
    Anchorage, AK
  3. Jan 30, 2014 at 3:02 PM
    SeminoleTRD
    SeminoleTRD Well-Known Member
    James
    Fleming Island
    2008 TRD Sport DCLB
    3" ProComp Add-a-leaf, 1.5" SpiderTrax, Center Bearing shim, Nitto TerraGrappler 285/70R17, Volant Air Box, BakFlip Tonneau HD, DIY 3.5mm AUX Jack install, D-Ring bed mounts, Plasti-Dipped badges, Dumped 50 Series Flowmaster with DeltaFlow Tech, Lumen LED Fog Lights, Lumen Marker Lights, Spyder Smoke Headlights, Satoshi Grill, Anytime Fogs
    What is the scatter like in an OEM headlight? What I mean is, when you put an HID in a OEM non-projector assembly it scatters the light all over and drivers in oncoming traffic will flash their hi-beams at you. Does the LED light scatter light like a traditional bulb, just brighter, or does it scatter like and HID which requires you to get a projector style?
  4. Jan 30, 2014 at 3:12 PM
    Large
    Large Red
    Curious as well.
  5. Jan 30, 2014 at 3:20 PM
    Hollywood22
    Hollywood22 Wranglin the Badger
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    How difficult are they to install?
  6. Jan 30, 2014 at 3:31 PM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    sub'd
  7. Jan 30, 2014 at 6:21 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Do you have any night shots. Comparing OEM bulbs and the LED? How are highbeams with these?
  8. Jan 30, 2014 at 6:22 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    x2 on difficulty of install and light pattern.
  9. Jan 30, 2014 at 9:27 PM
    benbacher
    Anchorage, AK
    542BA003-F097-402B-A42E-3AF505BF9048_zps_9699f71f587a116670d5663f81c913217b681e47.jpg
    Okay first question: Scatter.
    A: Because you are using the OEM housing and reflector bowl, you will still get the same beam pattern as you would with your OEM bulbs. No different than a standard HID setup there. You CAN however, put these right into a converted projector headlight with better results than HID and more than 20 times the longevity.
    Question 2: Ease if install.
    A: These are VERY simple to install. No different than a standard HID setup. You have a ballast for each of the bulbs and that's about it for the wiring. I'll go grab a box tomorrow and get a picture of the contents.
  10. Jan 30, 2014 at 9:37 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Output shots against a wall?
  11. Jan 30, 2014 at 9:45 PM
    benbacher
    Anchorage, AK
    Still looking for one but here's one straight on.
  12. Jan 31, 2014 at 4:55 AM
    Mitch
    Mitch
    Spokane, WA
    I looked on their website and it seems very straight forward. I was wondering though what the mini fan was for
  13. Jan 31, 2014 at 5:19 AM
    07tacoswb
    07tacoswb Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
    With LED's is there high and low beams or is it only low? Didn't know if that one bulb worked as both.
  14. Jan 31, 2014 at 5:54 AM
    Large
    Large Red
    The ballast probably gets hot.
  15. Jan 31, 2014 at 6:03 AM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    Do they melt snow and ice off the housings still? Are you blinding yourself during foggy situations?
  16. Jan 31, 2014 at 7:45 AM
    benbacher
    Anchorage, AK
    The LED itself produces very little heat. As far as I know they still haven't found a way to create light without producing heat. LED's however, are highly efficient in that department.
  17. Jan 31, 2014 at 7:49 AM
    T-rev
    T-rev Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    Subbed for output shots.
  18. Jan 31, 2014 at 10:30 AM
    Germ
    Arizona
    2013 TRD OR DCSB
    Hot enough to still melt snow so the housings don't get blocked?
  19. Jan 31, 2014 at 10:32 AM
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
  20. Jan 31, 2014 at 10:44 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    :popcorn: been following the other thread as well. Waiting to see someone put LEDs into a projector retrofit and see the comparison.
