LED Headlight install - no high beams
Discussion in '1st Gen. Tacomas (1995-2004)' started by lukester78, Nov 1, 2017.
  1. Nov 1, 2017 at 5:40 PM
    lukester78
    lukester78 [OP] Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
  2. Nov 1, 2017 at 6:00 PM
    lukester78
    Luke
  3. Nov 1, 2017 at 6:28 PM
    tony2018
    tony2018 Well-Known Member
    I think you might have it backwards.
    12TRDTacoma likes this.
  4. Nov 2, 2017 at 8:25 AM
    lukester78
    Luke
    This is the only socket configuration that puts out any light
    I believe I’m activating the daytime running lights with my high beam switch currently.
  5. Nov 2, 2017 at 9:49 AM
    tony2018
    You might want to re-think the configuration and confirm them 1 by 1.
  6. Nov 2, 2017 at 10:24 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    that doesn't mean it's right though lol
  7. Nov 2, 2017 at 10:33 AM
    lukester78
    Luke
    Not saying it’s right, but at least I can drive with them currently. The low beams are a huge upgrade from what were probably the original headlights.
    If anyone has any info on how toyota operates the high beams it’d be much appreciated.
    ChadsPride likes this.
  8. Nov 4, 2017 at 10:35 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    A basic 3 wire headlight should be the low wire hot with low beam, and both low and high beam wires should be hot with the high beam.
