LED Headlight "KIT"
Discussion in 'Lighting' started by TwzteD, Mar 2, 2013.
  1. Mar 2, 2013 at 4:22 PM
    TwzteD
    TwzteD [OP] Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
  2. Mar 2, 2013 at 8:32 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    $140.00, I'll pass....
  3. Mar 6, 2013 at 6:56 AM
    TwzteD
    Kyle
    St Lucie Fl
    Anyone have any experience/info with these?
  4. Mar 6, 2013 at 7:11 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    You would be halfway to projectors at that price, and I don't see how the light output would be anywhere near as good as a projector.
  5. Mar 6, 2013 at 7:12 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I just installed a LED wired as a reverse light on my truck and another as a headlight on my tractor. Package claims 1550 lumen output. They're good for my uses but I would never use them as headlights for my truck. Might be ok as auxiliary offroad lights. The 1550 lumen isn't bright enough to be main lights in my opinion. Close to stock maybe but not close enough.
  6. Mar 6, 2013 at 7:18 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Ive got a 1600 lumen headlamp for mountain bike riding and there is no way I would consider using it for a vehicle. Cheap LED makers also over rate their light output as well. Mine actually measures around 600 lumens
    Most of the time you can cut that number in half
  7. Mar 6, 2013 at 7:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just so you know, there is a lot more to good lighting than just lumen output. Lumens is just a measure of how bright a bulb is, it's slowly replacing watts as a measurement of brightness. When it comes to a headlight, all the lumens in the world won't matter if you can't put it where you need to in order to see where you're going.
    ^this. TRS's kits are only in the low to mid $200's during group buys. I can pretty much promise you that a retrofit will blow that little LED away.
  8. Mar 6, 2013 at 7:36 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I wouldn't touch any LED headlight kit. Especially since its relatively new for headlight use and only a handful of cars have it as a factory option. I would imagine a drop in kit would have sub par output and be nothing like you would get in an LED off road light.
  9. Mar 6, 2013 at 12:04 PM
    TwzteD
    Kyle
    St Lucie Fl
    Yea ill prob do a retro fit In the future just don't wanna ruin anything.
  10. Mar 6, 2013 at 9:42 PM
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
    Never seen that before... Don't know if I'd trust it.
    Modifystreet.com has projectors for half the price of TRFS, But I'd recommend using a different HID kit then what they sell.
