LED headlight suggestions
Discussion in 'Lighting' started by tacotruck93, Jan 24, 2018.
  1. Jan 24, 2018 at 12:04 AM
    tacotruck93
    tacotruck93 [OP] Well-Known Member
    Zach
    Akron,Ohio
    2012 TACOMA TRD OFF ROAD
    What is a good L.E.D headlight bulb to run that you guys have used ?
  2. Jan 24, 2018 at 12:32 AM
    Superman
    Superman Well-Known Member
    Joe
    Michigan
    2017 Quicksand TRD OR DCSB
    Current: Behind rear seat MOLLE panel Softopper Empyre grille insert MesoJDM ultimate red maps MesoJDM ultimate white dome Future: BajaRack roofrack/basket Mobtown bolt-on sliders Mobtown rear plate bumper Mobtown front plate bumper On-board air compressor Ditch lights LED headlights (blacked out) LED taillights (blacked out) LED yellow fog lights Bedrack over softopper Maxtrax
    Before you do this, just know a lot of people have had wiring gremlins afterwards (even when changing back to stock. Not covered by warranty) or are unhappy with the beam distance on LED bulbs. Many will suggest halogen :)
    crashnburn80 likes this.
  3. Jan 24, 2018 at 12:34 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  4. Jan 24, 2018 at 12:36 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Socalmotogear.com h4 GL1500 GoldWing light kit, only LED's I have seen that are high quality, well designed (good cut off doesn't scatter light) cool running fanless bulbs that don't cause problems and are plenty bright without being HID dick bright.
    Consider the HIR (Not HID!! Halogen Infrared reflection bulb) upgrade instead of LED though.
  5. Jan 24, 2018 at 12:39 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    HIR only applies to H10 fogs and 921 reverse lights. Otherwise it is good old high wattage.
    Edit: unless driving a non-Tacoma that takes 9005/9005 Headlight bulbs.
    Key-Rei[QUOTED] likes this.
  6. Jan 24, 2018 at 12:40 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    None
    outxider likes this.
  7. Jan 24, 2018 at 12:46 AM
    Key-Rei
    Key
    Florida
    Derp! :p
    I thought you had an HIR in the headlights, how well do the higher wattage lights work in regards to heat and bubbling or melting the housings and lenses?
    We keep meeting in these threads. :thumbsup:
    crashnburn80[QUOTED] likes this.
  8. Jan 24, 2018 at 12:47 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Yes, the LED bulb construction does need to be precise in positioning the light source, in the same location as the halogen bulb filament to aim the light correctly into the reflector bowl. Anything outside of that will give poor lighting and glare to other drivers.
    stay away from COB (circuit on board) type LEDs; questionable quality & lifespan.
    can recommend Cree XHP50 SMD (Surface mount device) modules, as providing the right amount of light, along with a more broadband spectrum (colors) output to make the white light.
    example:
    https://www.ebay.com/itm/MOSTPLUS-1...3-Hi-low-beams-Bulbs-6000K-CREE/262138188783?
  9. Jan 24, 2018 at 7:41 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Design flaw on the early 2nd gens caused the melting issue for the DRLs, no issue for the headlights. They fixed the DRL issue with the TSB lights. The headlight lenses are just warm to the touch, not hot.
    Stalker.
    Key-Rei[QUOTED] and Muffdiver like this.
  10. Jan 24, 2018 at 8:03 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    None. LED headlights still overall suck for the most part, and the stock housings can't handle them anyways.
  11. Jan 24, 2018 at 8:44 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Do a proper retrofit and call it a day.
  12. Jan 25, 2018 at 2:03 AM
    Key-Rei
    Key
    Florida
    :anonymous:
    :spy:
  13. Jan 25, 2018 at 5:08 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    True, but halogen bulbs provide on omnidirectional light source while LEDs provide a very directional light source. That said, it's virtually impossible to get LED bulbs to preform correctly in a housing designed for halogens.
    Back to the OPs question, save your time and money and skip the LEDs - all of them.
