Led headlights first gen
Discussion in 'Lighting' started by 2000TacoAvery, Mar 26, 2020.
  1. Mar 26, 2020 at 5:22 PM
    2000TacoAvery
    2000TacoAvery [OP] Active Member
    Avery
    2000 Tacoma extended cab
    Headlights
    Looking for a good cost effective led bulb. I got some auxbeams but they needed to be adjusted and these housings don’t have much room to go as far as they would need to. Wondering if there’s a good bulb that won’t need adjusting or is that how all leds are? Any suggestions on bulbs are great, thanks
  2. Mar 26, 2020 at 5:28 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    I'll be the first of many to say don't do it. LEDs do not perform well in the reflector housing.
    DirtJumper14 likes this.
  3. Mar 26, 2020 at 5:29 PM
    2BeersPlease
  4. Mar 27, 2020 at 1:35 AM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    I'm going to also recommend the "ultimate H4 upgrade" thread. Testing on here, courtesy of crashnburn80, and elsewhere shows that LED retrofit bulbs just don't work well enough (or at all) to be recommended over a high performing halogen, especially if you also do a relay harness.
    If you really want LED, the best way to go about it is a dedicated LED projector retrofit.
    I know morimoto is a popular source for retrofits, but I would suggest Hella's 90mm bi-LED.
  5. Mar 27, 2020 at 1:36 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
