LED Headlights use caution
Discussion in 'Lighting' started by gliv, Aug 9, 2014.
  1. Aug 9, 2014 at 3:16 PM
    gliv
    gliv [OP] Active Member
    FL
    2.7 Tacoma
    So I bought a set of Genssi LED Headlights with drivers they work great, for now, boat load of light output. I decided to do a test run without installing the factory boot on the back of the headlight housing, glad I did, they get hot, really hot. The lights must be able to vent and it is my opinion that using the factory boot will create a short life scenario based on the design of the second gen headlight housing boot, just not enough room to vent. I would recommend a thin sealing product to seal the housing and preventing contact with the led bulb. Anyone else notice this? Driver gets pretty hot as well.
  2. Aug 10, 2014 at 5:35 AM
    gliv
    FL
    2.7 Tacoma
  3. Aug 10, 2014 at 5:39 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    I am assuming these come with the massive heatsink and fan, yes?
  4. Aug 10, 2014 at 5:59 AM
    Large
    Large Red
    How hot are you talking? I'm sure the headlights can take 120ish degrees, hell we put them in the oven for 200 lol
  5. Aug 10, 2014 at 6:06 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Boot gets hot melts and causing flaming Tacoma?
  6. Aug 10, 2014 at 6:21 AM
    capturecolorado
    capturecolorado Well-Known Member
    Alex
    Grand Junction, CO
    01 4Runner SR5 with some things attached
    The LED bulbs I picked up for my truck have a monsterous heat sink on the back, and a small threaded stud to attach an included fan to, the fan comes on with the lights and runs constantly.
  7. Aug 10, 2014 at 7:26 AM
    gliv
    FL
    2.7 Tacoma
    It's not the fan it is the heat sink. Don't let any part of the boot cover any part of the heat sink, they will run very hot.
  8. Aug 10, 2014 at 10:49 AM
    gliv
    FL
    2.7 Tacoma
    Yes
  9. Aug 10, 2014 at 10:54 AM
    gliv
    FL
    2.7 Tacoma
    Not talking about the housing, the led. Well above 120, in this case your led will fail.
  10. Aug 10, 2014 at 11:02 AM
    gliv
    FL
    2.7 Tacoma
    Not sure however, if the boot chokes any part of the heat sink they get hot enough to the point that you can't leave one finger on the heat sink more than a second or two. I can only speak from my experience after testing both with and without the boot.
  11. Aug 10, 2014 at 11:06 AM
    Large
    Large Red
    Well I just had mine installed, will chime in next weekend! When I go to work it's dark and when I get off it's dark so we will see.
  12. Aug 10, 2014 at 11:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    But we remove all the rubber bits before baking. Housing can take the heat, not sure about the rubber boot.
