Led headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jcollins, Oct 5, 2015.
  1. Oct 5, 2015 at 12:05 PM
    Jcollins
    Jcollins [OP] Well-Known Member
    Justin
    Browns summit north carolina
    2013 grey tacoma trd
    Light bar and pods with strobe back up camera any time mod 886 backup lights and a Detroit true track posi
    Hey I currently have 6000k hids in Stock 2013 housings I'm tired of messing with hids and have been looking into leds does anyone have any info on their led headlights and brands that are good.
  2. Oct 5, 2015 at 12:11 PM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    LEDs in headlights are a bad idea--you need to design the optics around the light source (LED) and not the other way around. Results are sub-par.
  3. Oct 5, 2015 at 12:13 PM
    Jcollins
    Justin
    I know the only thing is money on new housings and I haven't found any I like.
  4. Oct 5, 2015 at 12:13 PM
    TRSAndrew
    ATL
    So retrofit your stock lights with a proper LED projector
  5. Oct 5, 2015 at 12:15 PM
    Jcollins
    Justin
    How do you go about a retrofit I've not done much headlight mods before so I'm new to the process
  6. Oct 5, 2015 at 12:31 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    ^ It looks like he sells retrofits.
    Are you just looking to get more light? Your HIDs in stock reflector housings will not have a good beam pattern. They are not designed for HIDs. I would suggest running very high quality over wattage halogen bulbs like 85w Orsam Hyper H4s in your stock housings with a stand alone headlight harness. They put out 2400 lumens which is drastically more than stock. Take a quick looks at this thread so I don't have to retype it all:
    https://www.tacomaworld.com/threads/hid-headlights-yes-i-searched-i-always-do.393763/
  7. Oct 5, 2015 at 12:34 PM
    Jcollins
    Justin
    I'm just looking for more light I like my hids I know they don't have a great beam but I don't really care about that I actually like that I have light everywhere with them I've just gone through a couple sets of bulbs and now a ballast has gone bad and I don't like waiting for them to warm up
  8. Oct 5, 2015 at 12:35 PM
    Jcollins
    Justin
    What is a stand alone headlight harness?
  9. Oct 5, 2015 at 12:41 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    A standalone harness utilizes a relay controlled by your factory switch to draw headlight power straight from the battery, bypassing the factory wiring harness. This is more efficient, causing your lights to be brighter, but more importantly allows you to safely draw far more current to run higher power lights without risk of melting or burning your factory harness. It is completely plug and play and fully reversible. I posted some cheaper options in the thread I linked above, but here is the one I have. You could also build your own.
    http://www.rallylights.com/hl282s-upgrade-headlamp-harness-for-switched-ground-vehicles.html
  10. Oct 5, 2015 at 12:56 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The Retrofit Source sells components to do a proper retrofit. They don't sell retrofitted lights. If you are interested in a retrofit there are a couple of members that do provide the service if you don't want to tackle it yourself. There are also DIY posts. I definitely agree with you OP, get the HIDs out of the halogen housings that weren't designed for them.
  11. Oct 5, 2015 at 1:17 PM
    Jcollins
    Justin
    So it plugs right in no splicing wires ?
  12. Oct 5, 2015 at 1:20 PM
    Jcollins
    Justin
    What's so bad about hids in halogen housings is it the beam or is it dangerous to the truck because my eyes have gotten used to how they light up everything. It's the first headlight I have had that I could see good. I have bad eyes for night driving
  13. Oct 5, 2015 at 1:32 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    HIDs are bad because while they may seem to light up the road with a lot of light, that light is not focused in the correct places, so it actually strains your eyes more than a standard headlight. More importantly, they are dangerous to everyone else on the road coming towards you because the light is not focused where it should be, so your headlights are blindingly bright to to everyone else.
  14. Oct 5, 2015 at 1:35 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct. 100% plug and play, zero cutting or splicing. Plug headlight bulbs into the harness. Plug one OEM harness headlight bulb connector into the standalone harness relay switch and attach the power leads to the battery.
    ^That pretty much sums it up. However, another drawback is that light focused up in the air blinding other people is light that could be focused on the pavement increasing nighttime visibility.
  15. Oct 5, 2015 at 2:07 PM
    Jcollins
    Justin
    Ok
    Oka thank you and you said the stand alone harness is for high wattage halogen bulbs
  16. Oct 5, 2015 at 2:11 PM
    Capt. Obvious
    Darrick
    Gig Harbor
    '12 DCLB TRD
  17. Oct 5, 2015 at 2:11 PM
    Jcollins
    Justin
    So has anyone used leds yet
  18. Oct 5, 2015 at 2:40 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The harness will help anytime you have a higher power draw than stock. Most likely case for that is high power halogens.
    There are members running LEDs. You need to do the headlight projector retrofit, which will involve taking your lights apart to modify them, which will break the seals and could (but not necessarily) introduce annoying moisture problems in the housing. The brighter LED lights will utilize micro-processor electric cooling fans to cool the circuits at the base of the bulb. Not the most rugged design for a light in an off road vehicle IMO.
  19. Oct 5, 2015 at 2:44 PM
    Jcollins
    Justin
    Do they all have the fans because I saw a post where some one said they got them without fans but I can't find the post and what's a good brand retrofit or are they all the same
  20. Oct 5, 2015 at 2:53 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    BriteAss LED's.
    the lights are a different spectrum of color, not necessarily brighter. They are whiter, much like the HID. Replacing with actual brighter bulbs is illegal.
