LED Headlights
Discussion in 'Lighting' started by FARNORCAL, Jun 2, 2016.
  1. Jun 2, 2016 at 11:17 AM
    FARNORCAL
    FARNORCAL [OP] Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Anyone running them? How do they compare to halogens? How bright do they seem.
  2. Jun 2, 2016 at 11:30 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Unless you are also doing a $1k retrofit, these are the only ones I have seen that are designed to work in a halogen reflector. They also do not have cooling fans to fail and are built by a quality manufacture. If they are not designed to run in a halogen reflector you will have glare. Off brand LEDs are often not reliable and fail. If you look at the ones with microprocessor cooling fans, where you have to cut the back of your headlight boot allowing moisture into the lens, it is easy to see why.
    http://www.xenondepot.com/h4-philips-12953BWX2-LED-Bulb-p/12953bwx2.htm
    Output: 1250 lumens
    If you are just looking for greater light output I would highly suggest this upgrade instead:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-not-led-or-hid.398066/
    Output: 2400 lumens
