LED Headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bails, Sep 6, 2023.
  1. Sep 6, 2023 at 3:04 AM
    Bails
    Bails [OP] Well-Known Member
    Tampa, Florida
    2023 TRD Sport 2WD
    After owning 3 Tacoma's since 1996, I am getting ready to buy a 2023 TRD Sport 2WD in Lunar Rock. It seems that Southeast Toyota no longer offers LED Headlight package on Lunar Rock, I suppose maybe because of the in coming 4th Gen models. I can find them outside of the Southeast Tacoma block of States, but dealing with a trade, distance, and whatever. Those that have LED's do you feel it is a make or break? Do you like them in comparison to std. lights? I have read that to have them put on is not that easy and quite costly. Do the led fog lights help or?
  2. Sep 6, 2023 at 3:23 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Not sure about the LED fogs, but if you can get the OEM LED headlights, the common consensus on here is that they are way better than anything aftermarket you can get.
    Phenom3030, Chew, TheDanimal and 3 others like this.
  3. Sep 6, 2023 at 3:26 AM
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
    So there is a difference driving with LED's verse std headlights??? Enough that you would want them one way or another?
  4. Sep 6, 2023 at 3:51 AM
    RedWings44
    Michigan
    The LEDs are brighter. Your body is also more sensitive to scotopic light at night (white/bluish light) which is far greater in LED light than halogens. The OEM ones are specifically made for this truck and designed to work the best. Aftermarket and standard halogen ones just don't compare.
    The one downside to LEDs is that they don't produce heat the same way. So, in certain conditions in the winter, they will not self-clear spray that freezes on there. It's rare, but it happens.
    musicisevil likes this.
  5. Sep 6, 2023 at 4:09 AM
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
    :) Maybe I should have mentioned, I am in Tampa FLA. BUT point well taken..
    RedWings44[QUOTED] likes this.
  6. Sep 6, 2023 at 4:46 AM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    I have a 22SR5 with the standard lights. Looking back, I wish I had the LEDs but the H9 is a big improvement.
    6MTPro, grogorat and musicisevil like this.
  7. Sep 6, 2023 at 4:47 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I researched and saw that. I ordered without the LED for this exact reason. The factory lights are nice. Would love to have the LED if they just didn’t ice over
    MannyS likes this.
  8. Sep 6, 2023 at 5:12 AM
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
    So your saying the 2023 std headlights are an improvement that I would welcome,,,, to the yellowed over plastic lens (which seems I polish once a year) of the 2015?
  9. Sep 6, 2023 at 5:13 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
  10. Sep 6, 2023 at 5:18 AM
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
  11. Sep 6, 2023 at 7:20 AM
    Sasquatchian
    Sasquatchian Well-Known Member
    The factory LED units are not only brighter but have a significantly wider, broader beam at the same time and a much much smoother beam as well. They are simply the best lights you can get for your truck. I had the original H11 projectors and tried half a dozen higher performing bulbs from the high performance H11's to the H9 upgrade and while those were all much better then the stock long life H11 bulbs from the factory, none of them ever came close to the real world performance of the factory LED assembly.
    Since you're shopping for a new truck, one thing to really watch for, since the dealers and specifically the salespeople don't know crap, is that they are all too often completely confused and do not know the difference between LED Daytime Running Light and LED Headlight. These forums are littered with consumers who didn't know the difference either only to find out they missed out on a very affordable $500 option, so triple check because if you don't, know one else will either.
    Lunar Squirrel and OZ TRD like this.
  12. Sep 6, 2023 at 7:30 AM
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
    I agree on the confusion on truck specs.
  13. Sep 6, 2023 at 7:51 AM
    I do not know what you would welcome. But a headlight that is 9 years old and keeps on turning yellow every year probably needs to be replaced anyway. As far as the LED headlights, I suggest you buy them with the truck, that way you know you bought the best possible ones.
  14. Sep 6, 2023 at 7:53 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    The LED’s are a worthwhile improvement and easily worth more than all the inflated items combined that SE Distributors typically jams onto Tacomas at the port.
    100% agree we’ve seen instances here of dealers “confusing” LED headlights w LED running or fog lamps. Finding out the truck you waited weeks for doesn’t actually have the LEDs you expected only days prior to delivery is almost as deflating finding out there’s no Santa Claus.
    Might also keep in mind that LEDs will be spread further throughout the Gen4 trims, so likely they’ll be even more desirable out on the future market for preowned Gen3’s, where they’re still relatively rare.
  15. Sep 6, 2023 at 7:53 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I like the OEM LED headlights a lot. However, don't not buy a TRD truck because of them. You can easily upgrade for around $1400. Yeah, expensive, but sometimes you can get a truck that you like more for more than $1400 less than a truck that might have the lights and other options you don't want. the only thing not to do, is buy an SR/SR5. They are considerably more difficult to get working with the OEM LEDs properly. Not worth the hassle, if you want the lights then buy any TRD.
    Gear Jamin Jamie, Pro-Taco and Chew like this.
  16. Sep 6, 2023 at 7:54 AM
    TheDanimal
    TheDanimal Well-Known Member
    Daniel
    DFW
    2024 Silver TRD OR 6MT 2019 MBM TRD OR 6MT (RIP)
    I bought a 2019 which didnt have the led headlight option. As you can see from my pic in my signature, I upgraded to the OEM LED headlights and it was night and day difference. To me the stock standard housing with the projector beam looks dated already and the light output was garbage. I switched the headlights and fog lights to OEM LED. I opted for the black housing fog lights too which is an option and direct plug and play. The headlights require a harness and were a bit of a pain to place but I was able to do it in an evening
  17. Sep 6, 2023 at 8:04 AM
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
    OH Lordy, so does anyone in Florida know of a place that might install them???? I would end up with extra parts some way some how!
  18. Sep 6, 2023 at 8:06 AM
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
    There was a post that walk people through the process, no?
  19. Sep 6, 2023 at 8:09 AM
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    The LEDs on my 23 pro are the best headlights I've ever had on any vehicle. My previous vehicles were running gtr ultra 2 bulbs in projector housings which at the time I thought was insane. My dad's 18 sierra with factory LEDs isn't even in the same league as this truck. My brother has standard halogens in his taco. Get the factory LEDs.
  20. Sep 6, 2023 at 8:20 AM
    BLtheP
    Plano, TX
    Yes, and Chloe K has a good video on YouTube. @daveeasa makes the harnesses and has good info as well. Very high quality harness and well worth the cost.
    Pro-Taco likes this.
