LED help!!! Almost lit my truck on fire
Discussion in 'Technical Chat' started by RadRed06, Jul 2, 2012.
  1. Jul 2, 2012 at 7:32 PM
    MXscott14
    MXscott14 Bartle Do Member
    Keith Stone
    In Front Of You
    2006 2nd generation antique
    Black Headlight, Foglight always on,
    its led's a fuse will work fine.
  2. Jul 2, 2012 at 7:33 PM
    RadRed06
    RadRed06 [OP] Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
  3. Jul 2, 2012 at 7:35 PM
    MXscott14
    Keith Stone
    In Front Of You
  4. Jul 2, 2012 at 7:36 PM
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
  5. Jul 2, 2012 at 7:37 PM
    MXscott14
    Keith Stone
    In Front Of You
    correct
  6. Jul 2, 2012 at 7:40 PM
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    Do you splice the ground wire from the leds into the ground wire running from the switch to the battery?
  7. Jul 2, 2012 at 7:41 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Start at the battery positive with a fuse. Connect the positive side of the battery to the + on the switch. Connect the accessory (A?) terminal (middle terminal usually) to the positive lead of your LEDS. Ground the ground terminal and connect the negative side of the LEDS to either ground or the negative side of the battery.
    What you did was wire the switch to directly connect the positive and negative side of the battery together with the switch on. We did this same basic thing using a battery and a piece of bailing wire in high school auto shop. It was very exciting. I have not wired anything without a fuse since.:eek:
  8. Jul 2, 2012 at 7:42 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Hang on dude...help is on the way! :cookiemonster:
  9. Jul 2, 2012 at 7:43 PM
    MXscott14
    Keith Stone
    In Front Of You
    the batteries negative terminal has a wire running to your trucks frame so anything that needs to be grounded, can be attached to any non painted metal on the truck. or you can run wires up the the battery, (not necessary) but up to you
  10. Jul 2, 2012 at 7:45 PM
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    So you do not have to ground the leds to the switch?
  11. Jul 2, 2012 at 7:46 PM
    MXscott14
    Keith Stone
    In Front Of You
    no, ground it to the truck.
  12. Jul 2, 2012 at 7:49 PM
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    Is there a certain gauge wire I should be using? How many amps should the fuse I use in the blade fuse holder be?
  13. Jul 2, 2012 at 7:51 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    He used a cigarette lighter plug which has a fuse built into it.
    He may not have known it, but it's there under the "nipple".
    Hard to tell where you went wrong, but it doesn't sound like you used the same LED system that he used. His activates from a wireless remote, yours is on a switch.
    Unless your switch has an indicator light, it sounds like your mistake was grounding the switch.
    It should be battery > fuse > switch > LED > ground.
    That's your basic circuit. Small LED strips you don't need a relay, but you ALWAYS must have a fuse. A 5amp fuse should be more than adequate.
    If your switch is lighted, then yes, it needs a ground. In that case, it sounds like you connected the ground to the wrong terminal.
    Without knowing exactly what you have, it's going to be very hard to tell you exactly how to wire this.
    Normally, on lighted switches, the center terminal goes to the LEDs, one of the "end" terminals (usually a little closer to center) goes to the fuse, and the other "end" goes to ground. The switch should have come with a diagram.
  14. Jul 2, 2012 at 7:52 PM
    MXscott14
    Keith Stone
    In Front Of You
    what kind of lights are they?
  15. Jul 2, 2012 at 7:52 PM
    #35
    Rich91710
    Rich
    Los Angeles
    08 Base
    Hopefully, but this is going to be a tough one with the information we have.
  16. Jul 2, 2012 at 7:53 PM
    #36
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    #36
  17. Jul 2, 2012 at 7:55 PM
    #37
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    #37
  18. Jul 2, 2012 at 7:59 PM
    #38
    MXscott14
    Keith Stone
    In Front Of You
    5 or 10 amp fuse will work fine. and you can use small wire, those lights use very little power. 20 gauge wire would be more than enough.
  19. Jul 2, 2012 at 8:01 PM
    #39
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
  20. Jul 2, 2012 at 8:02 PM
    #40
    MXscott14
    Keith Stone
    In Front Of You
    yea but why not just go to the autoparts store and get one. even walmart.
