led help!!!
Discussion in 'Lighting' started by Fiend13, Jul 12, 2012.
  1. Jul 12, 2012 at 5:43 PM
    Fiend13
    Fiend13 [OP] Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    trying to install these led map and dome lights i got from ledsolutions. is there a diy on here? I guess I'm just dumb when it comes to these, i thought id just swap bulbs out and be done but like the dome light has a wire hanging from it, where does it go???
  2. Jul 12, 2012 at 5:58 PM
    Fiend13
    Chad
    Anyone? I thought I could just pull out the bulb and put the new ones in but they don't look like glass bulbs they look different
  3. Jul 12, 2012 at 6:43 PM
    Fiend13
    Chad
    Nevermind, figured it out. Turns out the first bulb I was using was bad along with the dome light and the other bulbs, oddly enough, I put them all in backwards first, once I swapped them around they worked. lol. Told y'all I didn't know $h!t about lighting or wiring. But I sure can fix multi-million dollar aircraft! Scary, huh?
