LED Help
Discussion in 'Lighting' started by MassAppeal16, Jun 16, 2013.
  1. Jun 16, 2013 at 8:52 AM
    MassAppeal16
    MassAppeal16 [OP] Well-Known Member
    Carrollton, KY
    17 TRD MGM DCSB
    Ok so I have searched on here and found out why the turn signals will hyper flash, but I have another issue also. I installed white LED turn signals and parking lights in my 06 yesterday. When i turned them on the first time my passenger parking light worked, but not the driver... and i had the hyper flash on turn signals. Then i turned it off and back on and neither turn signal works at all, and they don't even show as working on my dash. Have I jacked something up awful or what?
  2. Jun 16, 2013 at 9:14 AM
    acdronin
    acdronin Well-Known Member
    Probably not, put the old bulbs back in to make sure everything works correctly, then try the LEDs again, maybe they're just not fitting in there well
  3. Jun 16, 2013 at 9:41 AM
    MassAppeal16
    Carrollton, KY
    17 TRD MGM DCSB
    I just switched them back. Now the parking light that was working is out, and the side that wasn't is back on. WTF!?
  4. Jun 16, 2013 at 9:46 AM
    acdronin
    Can't be a fuse or both of them would be out, it' probably the sockets, keep fiddling with them with the old bulbs
  5. Jun 16, 2013 at 9:46 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    LED lights are polarized. They will only light if the current runs through them one way. If you install them backwards, they won't light. It doesn't damage anything if they're in wrong, just makes for colorful noise pollution near your word hole:D
  6. Jun 16, 2013 at 9:50 AM
    acdronin
    but the polarity should be correct for the sockets he has if it's the correct bulb, i had the same problem with my reverse LEDs, just had to keep fiddling with them till they worked
