LED HIGH BEAMS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tommytutone, Feb 8, 2021.
  1. Feb 8, 2021 at 7:42 PM
    tommytutone
    tommytutone [OP] New Member
    tommy
    taco trd offroad
    Question I drive my tacoma 2017 trd offroad as a daily driver and its on back country roads,deer everwere. im wanting to change headlight bulbs to led my resarch shows the s-v,4 to be what i think i need or want, but for now because of budget. im thinking of only doing high beams those alone are like 160 bucks, then mabe later doing low beams and fogs later, any thoughts or other ideas ??
  2. Feb 8, 2021 at 7:54 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Some LED's don't get hot enough to melt snow when driving in a snowstorm. If you live down south it probably wont matter.
  3. Feb 8, 2021 at 7:57 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to the forum. See the link above, specifically post #3 in that thread for lots of LED testing. Most LEDs don't project as far as stock, they provide more foreground light and less distance light, which while it looks very impressive initially that is bad in a headlight. The only 2 recommended LEDs are the Hikari Ultra and Morimoto 2stroke 3.0s. Don't put LEDs in your stock fogs, you end up with poor performance and blinding glare. This thread below covers LED fog upgrades, which require replacing the assembly with an LED one. The SS3s are the current market leader:
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    DaBigDogg, WiscoPat and DWD484 like this.
  4. Feb 8, 2021 at 8:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    More light does not help with deer. Deer strikes happen as much in daylight as dark. If you want different lights just ask and dont try to justify it by deer.
  5. Feb 8, 2021 at 9:05 PM
    tommytutone
    tommy
    taco trd offroad
    Helps me see them on the side of road in the brush and trees, on my winding roads late at night, But thanks for your opinion..
  6. Feb 8, 2021 at 9:17 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Deer are most active from Dusk until around 9 PM or so. Another option might be ditch lights. The would help illuminate the sides of the road better.
    Dmac06 likes this.
  7. Feb 8, 2021 at 9:20 PM
    Puppypunter
    Johnny
    2019 Black SR
    Oh, and I suppose I might be able to interject an opinion on the Hikaris. I have them in both my low and high beams. The low beams are definitely a big improvement over stock. The high beams, not so much. While I wouldn't say they are worse, they are marginally better at best. I bet @crashnburn80 has a good recommendation for high beams that might be more budget friendly to try first.
    crashnburn80 likes this.
  8. Feb 8, 2021 at 9:21 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Good lights are not cheap, and cheap lights are not good.
    My old blotchy, hot, 100w 6” aircraft landing lights saved my butt more than once back in the day spotting and avoiding moose, elk, and caribou standing in the dark road. They also melted harnesses, fused relays, and beat the crap out of my alternator when they were all lit up.
    These days there are some really nice led driving lights out there. I’ve got a bit of a BajaDesigns habit, not Meso levels, but still enough to avoid highways and stay on the backroads with my lights on. It blows me away every time I flip the switch and they light everything up.
    tommytutone[OP] likes this.
  9. Feb 8, 2021 at 9:33 PM
    smikec
    smikec Well-Known Member
    for high beams, you already have the best in your truck = H9
    and the best part, they're free, since they already come in the stock truck
    if you want a different beam focus to see elsewhere, dedicated lights are best
    bulalo and vicali like this.
  10. Feb 8, 2021 at 9:43 PM
    tedusmc1345
    tedusmc1345 Well-Known Member
    ted
    2018 Tacoma Sport 4x4
    If you really need brightness than looks, I would go Hid kits. Nowadays is really cheap and much brighter than oem or led bulbs.
  11. Feb 8, 2021 at 9:44 PM
    Puppypunter
    Johnny
    2019 Black SR
    Is there a better performing H9 though? I ask as someone who is ignorant on those. I know the stock ones are pretty good, but there isn’t an upgrade?
  12. Feb 8, 2021 at 9:44 PM
    smikec
    HIDs are best in a fully designed housing/lens retrofit = not necessarily cheap
  13. Feb 8, 2021 at 9:45 PM
    smikec
    the OEM high beam H9 halogens are as good as it gets (for the OEM halogen based housings)
  14. Feb 8, 2021 at 9:48 PM
    Puppypunter
    Johnny
    2019 Black SR
    Good to know, thanks :thumbsup:
  15. Feb 8, 2021 at 11:41 PM
    tedusmc1345
    ted
    https://www.amazon.com/Xentec-H11-bundle-CANBUS-Ballast/dp/B07FTP9XT6/ref=mp_s_a_1_4?dchild=1&keywords=h11+hid+headlights&qid=1612855759&sr=8-4
    This type hid will works fine. The hid bulbs dimension same as halogens bulb. Unlike led bulbs size may varies.
    I’m running with Philip slivervison halogen bulb. It’s much brighter than stock.
    Hid is not good for high beam, because it’s take some time to warm up.
  16. Feb 9, 2021 at 12:02 AM
    smikec
    HID bulbs in our halogen housings create unsuitable glare due to the uplight design of the OEM housing (without a proper HID projector retrofit such as the RX350)
    model number?
    agreed, HID bulbs should not be used in our high beams
  17. Feb 9, 2021 at 12:26 AM
    tedusmc1345
    ted
    Hid bulb design/dimensions should be same as halogen bulbs. The 3rd gen Tacoma low beam has projector housing, the glare should be at minimum compared to reflector housing.
    Good design led bulb will be better than hid, however it will be expensive.
  18. Feb 9, 2021 at 12:38 AM
    smikec
    You are correct, the dimension of HID bulb emission source similar to halogen
    however
    there is uplight (for signage illumination) built into our OEM halogen housings
    HID is brighter, yes
    but it also results in unacceptable uplight in our housings resulting in glare for oncoming traffic due to the design
    HIDs should be done in a properly designed HID specific projector retrofit
  19. Feb 9, 2021 at 6:16 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    if you need that much light, put a 32" light bar in the slot above the bumper, below the grille...
    I have a 32" bar installed there, and a bar in my hood scoop grille (Sport model).
    VIOLA! let there be light. Ski
