LED housing for 2d gen (on amazon)
Discussion in 'Lighting' started by FishaRnekEd, Mar 4, 2019.
  1. Mar 4, 2019 at 7:01 AM
    FishaRnekEd
    FishaRnekEd [OP] Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
  2. Mar 4, 2019 at 7:04 AM
    FishaRnekEd
    New Orleans, LA
  3. Mar 4, 2019 at 7:22 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    they look very good and using projector lenses should focus the LED light properly, basically someone needs to test them to see if the performance is as stated by the manufacturer.
  4. Mar 4, 2019 at 7:26 AM
    BillsSR5
    bill
    2014 SR5
    one reviewer on AMAZON also said within 1 week one of the lights stopped working
  5. Mar 4, 2019 at 9:17 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The only LED's any of those headlights are designed for are the angle eyes and DRL's. The low beam projectors/high beams are for halogens.
  6. Mar 4, 2019 at 9:23 AM
    FishaRnekEd
    New Orleans, LA
    It appears that they come with cheap halogen bulbs and need to be replaced with LEDs immediately?
  7. Mar 4, 2019 at 9:59 AM
    FishaRnekEd
    New Orleans, LA
    Ok, i looked on the spyder website and it says that using a LED bulb will void the warranty. I'm not seeing any headlight units that are actually made for LED bulbs. this seems to be a PITA
  8. Mar 4, 2019 at 10:27 AM
    BillsSR5
    bill
    2014 SR5
  9. Mar 4, 2019 at 10:05 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Any LED headlight made for LEDs will not have a changeable LED bulb. The headlight will be a completely sealed unit, with built in LEDs, like the $1200+ Morimoto LED headlights. There are no legitimate drop in LEDs because they don’t work, so no manufactures will ever build a headlight for them. Instead they will design a proper LED headlight housing which requires a fully integrated built in LED.
  10. Mar 5, 2019 at 4:31 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Are you looking for replacement housings with LED light sources or are you looking for replacement housings that give you better lighting? There's a big difference between those two. Everybody seems to be running to jump on the LED band wagon, but most don't understand that you don't always end up with better lighting. In fact in many cases all you end up with is expensive lights that don't put much usable light on the ground and end up with moisture in them.
  11. Mar 5, 2019 at 8:59 AM
    FishaRnekEd
    New Orleans, LA
    After reading and researching in the last few days, it looks like LED isn't the way to go. Not yet, anyway.
    The only proper led units are $1k +
    I think I'll just look for a decent new halogen replacement I'm really not for messing with the wiring atm
  12. Mar 5, 2019 at 9:07 AM
    Too Stroked
    Tom
    I was hoping you might come to that conclusion. If you want my 2 cents, even though there are a ton of aftermarket / replacement housings out there, none of them really measure up to OEM when it comes to quality, optics and resistance to oxidation / water intrusion. That said, you might want to check out the following thread. Not only does it detail a really, really effective upgrade you could do using OEM assemblies, but it also gives you the part numbers for said housings. Enjoy!
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
  13. Mar 5, 2019 at 9:41 AM
    FishaRnekEd
    New Orleans, LA
    Thanks!
    i'm looking into it now.
  14. Mar 5, 2019 at 9:44 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    spend a bit more, get a custom made housing and run hids
