LED hyper blink mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by BlackSportD, May 3, 2020.
  1. May 4, 2020 at 1:34 PM
    BlackSportD
    BlackSportD [OP] Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Yep more than one way to skin this cat. And for many the Napa, eBay, Amazon etc EP35 is an affordable and easy route. Some like to tinker.
    I'm on a Freddy emu with split second o2 module after having an AEM FIC. I just can't leave well-ebough alone I guess.
    FIC vs EMU is a whole nother thread lol
    cruiserguy likes this.
  2. May 4, 2020 at 4:54 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Ermahgerd you actually took the OEM flasher relay apart and modded it for the LED signal bulbs?!?! You have been added to a very short list of mine of dudes here on TW that I've declared my idols. You're one now:D:cool:
    This is so overkill and overly extra that I looooove it. You/this post gonna make me order LED blinker bulbs just so that I can have a reason to do this!! :rofl:
    I'm glad you shared this hermano :cool:
  3. May 5, 2020 at 1:26 PM
    BlackSportD
    Los Angeles
    I made the list- niiiiiiice
    cruiserguy[QUOTED] likes this.
  4. May 5, 2020 at 3:28 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    There is one negative of having modified the sense resistor. If for whatever reason one of the LED bulbs develops a semi-short let's say will take 8A, that is similar to the normal load with hazard lights on. That current would make the resistor quite hot - 0.1 ohm at 8A is 6.4W. The original metal tape (sense resistor 0.03 ohm) would take about 2W - and I believe this is way under the power rating for that resistor. I do not like hot electrical components in 25 years old truck. Changing the 10A TURN fuse to something smaller (like 3A) is only a partial solution as the hazard lights are sharing 15A fuse with horn, so really the worse case scenario is that that load sense resistor might take up to 15A, and that is over 20W inside the flasher:bananadead:.
    Solution with pull down resistor, while it is more complicated than just replacing the sense resistor, keeps the original power load and everything up to original Toyota design. :crapstorm:
  5. May 5, 2020 at 4:20 PM
    cruiserguy
    Elijah
    SEKS
    Thanks for raining on our parade, Mr. Buzzkill. :rofl::D
    You make valid points.
    I thought we didn't like the idea of splicing in a resistor to the wiring of the circuits? Where would you physically splice the resistor into the circuit? I definitely could be misunderstanding you though. Thanks for taking the time to clarify for me
  6. May 5, 2020 at 4:24 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Welcome to the list buddy! Lol
  7. May 5, 2020 at 4:33 PM
    cruiserguy
    Elijah
    SEKS
    You know who you are :D
    Speaking of my tacoma gurus/false idols that I falsely worship:)rofl:) I haven't seen dirty pool around for awhile... He better be okay
    Empty_Lord[QUOTED] likes this.
  8. May 5, 2020 at 7:41 PM
    BlackSportD
    Los Angeles
    @RysiuM good points for sticking to the EP35. But I'll roll the dice with a funky LED that doesn't fully short, but kinda shorts. If my relay goes poof, I already have a replacement haha. I still like the idea of bad bulb (open) detection. Or maybe its the vet in me that doesn't want to do any pre-checks on stuff anymore when it can be automated. I found my cbr600rr rear break light to be out by inspecting things- would have been great if there was an indicator for that vs. due diligence fucking around in the garage- been riding dirty for months I assume.
  9. May 6, 2020 at 3:51 PM
    RysiuM
    Rysiu
    The flasher is the only "burned bulb detection" indicator in all 1st gen Tacoma lighting. I can imagine how it happened: Pre-electronic flashers were bi-metal ones (or older version had a wire that while heating up was expanding and moving the contact - I remember one from FIAT 125). The "thermo-mechanical" flasher by design had a feature that was hyper-flashing when there was not enough current running through the thermo-expanding element. It was not done on purpose, it was just a nature of the beast. When mechanical flashers got replaced by electronic one I guess designers got the task to have 100% identical behavior of the new electronic flasher as the mechanical one. So they implemented a hyper-flashing feature. This is my guess. I doubt it was intentional as the burned bulb detection does not work when hazard lights are engaged.
    In any way I am happy to have it replaced with EP35 - less "fancy" that truck is, the more reliable they are. I converted all my bulbs to LED (except headlights of course) over 5 years ago and I had zero failed bulbs since then. I don't need a warning that will never happen.
    1. Trace cut between sense resistor and pin 7
    2. Pull-down resistor 100kOhm between pin 1 and pin 7
    3. Voltage divider resistor 560 ohm added between sense resistor and pin 7
    Another view of the connection point for this resistor
    All added resistors are low power (low current) circuit.
  10. May 6, 2020 at 10:12 PM
    BlackSportD
    Los Angeles
    Why not headlights?
  11. May 6, 2020 at 11:05 PM
    RysiuM
    Rysiu
    Bacause I'm sane :)
  12. May 7, 2020 at 5:02 AM
    cruiserguy
    Elijah
    SEKS
    Oh oh I see, resistor directly on the relay itself, not spliced into wiring like my noob arse was thinking. Very cool man. Those pics are awesome too! You always do things in a solid way even if overkill as well:D:cool:
    RysiuM[QUOTED] likes this.
  13. May 7, 2020 at 9:34 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'm not even certain a bulb out detection system for an incandescent bulb based on current would detect a bad LED bulb. They're completely different animals. Actually, if it were a dumb LED bulb and one of the LEDs on it failed short, current consumption would go up a little.
  14. May 7, 2020 at 11:14 AM
    RysiuM
    Rysiu
    That's an excellent point. LED bulbs don't fail like an incandescent one. The current might decrease, increase or stay the same. It it might start spiking up and down (with overheating BUC driver). Heck, the failed LED might even create a short.
    0xDEADBEEF[QUOTED] likes this.
  15. May 7, 2020 at 11:16 AM
    #35
    RysiuM
    Rysiu
    That was not really a project to be working in a truck, but a challenge if I can make that beast do work the way I want.:poking:
