LED Hyper flashing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ryukentsu, Sep 15, 2018.
  1. Sep 15, 2018 at 11:24 PM
    Ryukentsu
    Ryukentsu [OP] Member
    2016 Toyota Tacoma Base
    Hello I have a 2016 Toyota Tacoma SR two wheel drive 2.7. I installed OPT-7 LEDs with no risistor. They work fine for the high and low beams. I tried installing turn signals and Led brakes and I get hyper flashing when I turn on the headlights not when they are off. Can I please get some help. The LEDs in tried installing were. I have the basic cluster panel. No color display just plain Meter.
    JDM ASTAR Extremely Bright 3030 Chips 7440 7441 7443 7444 992 LED Bulbs ,Brilliant Red https://www.amazon.com/dp/B072W6DV2H/ref=cm_sw_r_cp_apa_cCFNBb91X5E37
    JDM ASTAR 1260 Lumens Extremely Bright PX Chips 7440 7441 7443 7444 Amber Yellow Turn Signal LED Bulbs https://www.amazon.com/dp/B00PHVUWR8/ref=cm_sw_r_cp_apa_zCFNBbMKT5BD1
  2. Sep 15, 2018 at 11:27 PM
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    You'll need a new LED Flasher relay. The relays in they aren't meant to handle LED so it's thinking the bulb is dying. I picked one up at Napa for $10
    EDIT: Did some searching, looks like the 3rd gens don't have an external relay for flashers. Looks like it's built into the cluster itself.
  3. Sep 15, 2018 at 11:28 PM
    Ryukentsu
    Would you happen to have a link?
    Thank you.
  4. Sep 15, 2018 at 11:29 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
  5. Sep 16, 2018 at 12:03 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    You'll need to get resistors and install them to get rid of the hyper flash.
    I have front LED blinkers and when I installed the rear LED blinkers, I got hyper flash (only on one side). Installing this resistor fixed it right up.
    https://www.diodedynamics.com/led-resistor-kit-pair.html
  6. Sep 16, 2018 at 8:34 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Needs a resistor, basically too much current reaching the bulb due to the LEDs having a lower resistance than stock, hyper flashing is the result of the increased power. Either buy something like above or buy resistors yourself and solder them in line to the LED.
