LED interior lights randomly all went out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTacoma777, Jun 18, 2025.
  1. Jun 18, 2025 at 11:13 PM
    BlueTacoma777
    BlueTacoma777 [OP] Well-Known Member
    Hudson
    2005 Silver Tacoma TRD OFFR
    33 AT Tires 3” Bilstein F lift Rear leaf pack Shell Method wheels
    Hello, I was just working on a center console mod on my truck last night. I had one rear door open and the driver door open, thus turning on the dome light. After probably 20 minutes the dome light went out and the map lights didn’t work either. Tried moving switch to on off and door and nothing. Replaced fuse and still keeps blowing so a short circuit somewhere. I’ve had these LED bulbs in my last taco and this taco for about 5 months and everything’s been fine until this point. Inspected all bulbs and just fine there. Any advice/help? Thanks!
  2. Jun 19, 2025 at 4:12 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'd remove the LED bulbs first and see if it still blows just to rule those out.
    You said you were woking on the center console, what exactly were you doing when they went out?
  3. Jun 19, 2025 at 9:24 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It was working.
    I did something.
    Now it doesn't work.
    Undo whatever you were doing in the center console.
  4. Jun 19, 2025 at 9:35 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I assume you mean the 7.5 ampere Dome Fuse is blowing.
    This fuse powers these loads:
    Clock
    Interior Light
    Wireless Door Lock Control
    The circuit is as such:
    Battery >> * Short Pin >> 7.5 Amp Dome Fuse >> Clock, Interior Lights and Wireless Door Lock Control.
    * Short Pin is not a fuse it is just a shorting device link.
    BlueTacoma777[OP] likes this.
  5. Jun 19, 2025 at 9:48 AM
    BlueTacoma777
    Hudson
    Remove the leds, and try with nothing in it? Or do you mean put the incandescent ones back in?
  6. Jun 19, 2025 at 9:49 AM
    BlueTacoma777
    Hudson
    I was just taping this organizer into the center console, but when it went out I was standing outside.
  7. Jun 19, 2025 at 9:51 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Just pull them out, if the short clears you just need some new bulbs if not then something shorted on the Dome fuse circuit.
    Jimmyh likes this.
  8. Jun 19, 2025 at 9:52 AM
    BlueTacoma777
    Hudson
    Will try that. Thank you
    Jimmyh likes this.
  9. Jun 19, 2025 at 10:22 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Possibly just a failed LED...
    I hope that is all it is, best of luck.
  10. Jun 19, 2025 at 10:53 AM
    BlueTacoma777
    Hudson
    Alrighty well just tested the new fuse in with the leds taken out and surely enough the fuse isn’t blowing anymore. Looks like I’m gonna buy the meso custom ones instead of the cheap Amazon leds. Thanks guys!!!
    Edit: Just put in the new LEDs, got my lights back to working order. Thanks!
    Jimmyh likes this.
