LED Interior Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patr, Oct 17, 2015.
  1. May 4, 2016 at 6:43 AM
    #381
    Mother
    Mother Well-Known Member
    Orlando
    2016 DCSB OR 4X4
    Lol, I'm, not sure why nobody will give you an answer. I went ahead and ordered the same ones as the OP yesterday. Once I get them installed I'll be sure to let you know whether or not they dim if nobody else does first.
  2. May 4, 2016 at 6:45 AM
    #382
    poppy510
    poppy510 Well-Known Member
    haha thanks!:annoyed:
  3. May 4, 2016 at 6:51 AM
    #383
    Mother
    Orlando
    2016 DCSB OR 4X4
    I just looked on the product pages under specifications and both the dome and map lights the OP specified say "NO" next to dimmable.
    You should be able to find some that are though, if that is important to you.
  4. May 4, 2016 at 6:58 AM
    #384
    poppy510
    thanks...Ill keep looking for dimmable and maybe someone will chime in.
  5. May 7, 2016 at 5:15 AM
    #385
    grjman
    grjman Member
    Gary
    Middleto, MA
    2016 Tacoma sport 4X4 ACLB with premium audio & tow pkg.
    all interior LED lights, 4" nerf bars (black), access tonneau bed cover, rubber bed mat, mud guards, back up LED lights.
    I ordered the WLED-W19-T backup lights, installed one and it didn't work tried both in same socket and still neither worked so had to return them. They are not canbus. might there be a +/- side?
  6. May 8, 2016 at 10:43 AM
    #386
    psvines
    psvines Well-Known Member
    2016 SR5
    Yea, I noticed the original bulb is flat on the ends which fits well in the receptacle slot on the left side. The LED is not flat on the ends which ends up making it slightly longer. Mine too is wedged in place and appears to be ok.
  7. May 8, 2016 at 1:33 PM
    #387
    poppy510
    Sweet mother crumpet. Can anyone tell me if they dim? Jaysus.
  8. May 8, 2016 at 3:30 PM
    #388
    clcartwr
    clcartwr Member
    If you buy dimmable leds they will dim....If not they won't. The ones posted originally are not dimmable.
  9. May 8, 2016 at 9:17 PM
    #389
    patr
    patr [OP] First-time Owner
    2016 Blazing Blue Pearl Tacoma TRD Sport 4x2
    I can confirm that they dim
  10. May 9, 2016 at 8:32 AM
    #390
    poppy510
    Awesome, thank you.:amen:
  11. May 12, 2016 at 4:48 AM
    #391
    Mother
    Orlando
    2016 DCSB OR 4X4
    I just slapped mine in this morning (same as OP) and I would say that yes, they do dim... but not as much as the stock bulbs. The LED's dim to a point and then turn off. If you want ones that do a true analog dim to zero then I would make sure to buy ones that specify being dimmable.
    Also, regarding the 31mm dome light being tight. I took a pair of pliers and squeezed down the spring terminal on the one side a bit, then pried it back up a little with a small screwdriver to make sure it still had enough tension to hold the bulb's orientation and that made it go in nice and easy.
  12. May 12, 2016 at 5:01 AM
    #392
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    technically the dome light is a 29mm size, if you read thru a few pages it was determined its not a 31mm size.
  13. May 12, 2016 at 5:40 AM
    #393
    Mother
    Orlando
    2016 DCSB OR 4X4
    I know. I read the whole thread. The 31mm that the OP bought works though. I was just letting people know how to make it work more easily should others choose to purchase that light.
  14. May 12, 2016 at 12:30 PM
    #394
    64strings
    64strings Member
    James
    2016 Red Tacoma TRD Sport
    Funny thing...the bed light was the only LED that came with the truck.
    Herniator likes this.
  15. May 12, 2016 at 1:58 PM
    #395
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    Yes, I figured that out after a while; when I was outside one night; I thought boy is this bright. Wonder why the interior ones aren't LED; maybe cost?
  16. May 12, 2016 at 2:58 PM
    #396
    CookieOneLove
    CookieOneLove Active Member
    Josh
    VB, VA
    25 Crush TRD-OR
    Taco #1 16 MGM Tacoma TRD-OR 4x4 (totaled) Taco #2 17 SW Tacoma TRD-OR 4x4 (traded for 22 Tundra) Tundra motor blew… traded in for new Taco
    So has anyone ran into any issues with the LEDS in the visors. I swapped everything out and for some reason the outside visor lights do not come on. The inside LEDS work fine but for some reason the outsides are off. I swapped them around and it's not the bulbs because they work when switched to the inside.
    Any ideas?
  17. May 12, 2016 at 3:07 PM
    #397
    clcartwr
    clcartwr Member
    Are the light polarity sensitive? Probably why they are doing that. Have you turned the bulbs in the socket?
    ExtraExtra likes this.
  18. May 12, 2016 at 6:13 PM
    #398
    64strings
    64strings Member
    James
    +1
  19. May 12, 2016 at 6:16 PM
    #399
    CookieOneLove
    Josh
    VB, VA
    25 Crush TRD-OR
    Ill try that in the morning. I did switch between the sockets and they worked unless I just happened to rotate then the right way while switching them around cause they worked fine in the other inside socket
  20. May 12, 2016 at 6:20 PM
    #400
    64strings
    64strings Member
    James
    Did you order from SuperbrightLEDS.com? A little detail...there's some text stamped on the light assembly. The text goes towards the bottom. That should solve your polarity issues.
    CookieOneLove likes this.
