LED Interior Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patr, Oct 17, 2015.
  1. Oct 3, 2016 at 9:08 PM
    #521
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    Did mine Saturday.... the tape trick worked for me on the map lights... just start with the tape trick before trying to use your fingers, lest you get the bulbs oily. If you do, a cotton swab and some isopropyl alcohol to clean the bulbs should do the trick... just go easy on it, so you don't drip isopropyl alcohol on any of the plastics.
    The rear one however, well, I guess I should have read the thread more. I could not get it to fit, because I ordered the 31mm. I see some have had luck by compressing the drivers side spring and that buys a few mm, so I will try that tomorrow. If that fails, I just might solder a bloody wire in there, LOL. Wish me luck.
    Dustin-OH16 likes this.
  2. Oct 7, 2016 at 1:19 PM
    #522
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... Thanks for posting this on LEDs ... wanted to remember this post for future reference ... :thumbsup:
  3. Oct 15, 2016 at 8:11 PM
    #523
    sqa4life
    sqa4life Well-Known Member
    2017 SR5 4x4 DCLB MGM
    Thank you.
    Ordered the same sets
  4. Oct 17, 2016 at 8:14 AM
    #524
    FishTaco57
    FishTaco57 Active Member
    Guy
    Columbus Ohio
    2017 TRD Offroad Quicksand
    Has anyone tried the OP's part # for a 17 DC yet? I'm assuming they would be the same jus trying to make sure. I read through most of the thread and didn't see anyone mention 17's
  5. Oct 17, 2016 at 8:21 AM
    #525
    DigitalSensei
    DigitalSensei Well-Known Member
    Texas - DFW Area
    2016 4x4 Off Road INFERNO!
    Looks like a nice setup.
  6. Oct 18, 2016 at 7:46 PM
    #526
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    I am going to go back to halogen as well. I have some friends with 3rd gen Tacos and we all did the LED Lights from Sylvania. Lifetime Zevo LED. Anyway, mine are still fine but one of my friends worked fine and then one day they wouldn't shut off when closing the doors. Long story short, BCM (Body Control Module) failed due to the LEDs according to the dealer. Not sure how but I've seen other threads with the same thing. He is battling them to change under warranty since the LED are not what is called for in the manual. Anyway, I ordered the SilverStar white Halogen bulbs and will take pics of how they look.
  7. Oct 18, 2016 at 8:10 PM
    #527
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Let there be light!
    okay...it might be a bit overkill
    SilverII and incogneato like this.
  8. Oct 18, 2016 at 8:49 PM
    #528
    jkcashin
    Jamie
    2017 TRD OR AC MT
    Similar to what I ended up doing, as the 31mm festoon bulbs didn't fit. I used a single array rather than the double you have here.
    Since I still have 4 nice festoon bulbs, I am going to solder wires to them and re-purpose them as floor lighting. Wish me luck!
    pcampbel01 likes this.
  9. Oct 18, 2016 at 8:56 PM
    #529
    jkcashin
    Jamie
    2017 TRD OR AC MT
    Mine's a '17, but it's an AC, and a Canadian one at that.
    I did the front map lights as the OP suggested JDM ASTAR 800s, which worked fine.
    The rear dome, as many have already reported seems to be a 28mm festoon but the OP part was a 31mm. There's some tips on how to get it to fit, but I was not comfortable with doing that so I ended up using a 48 LED array like the post above... it comes with a number of connectors you attach to the array, one of which was a spring-loaded festoon fitting which went from about 15mm to nearly 40mm, so it fit fine. I bought it locally at an RV parts place. Only complaint is it's warm white and the JDMs are cool white.
    As mentioned, this has left me with 4 spare festoon bulbs... I was lamenting the lack of floor, i.e., "courtesy" lights in the Tacoma, so I am going to work on making these bulbs do that duty... probably driven by a relay off the map light switch with an override switch.
  10. Nov 26, 2016 at 9:47 AM
    #530
    Savage707ron
    Savage707ron Well-Known Member
    2017 trd off road
    How do I pop the map lights off? Any advice?
  11. Nov 26, 2016 at 9:49 AM
    #531
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    They pop off at the map lens pivot point using a small flat screwdriver.
  12. Nov 26, 2016 at 10:14 AM
    #532
    Savage707ron
    2017 trd off road
    OK I will try that. Thanks
  13. Dec 3, 2016 at 3:13 PM
    #533
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    One thing I don't remember reading is, I left my dome light on over night a while back, didn't drain the battery like the reg bulb would have.
    Corneeeeelius likes this.
  14. Dec 14, 2016 at 6:27 PM
    #534
    mcwalke2
    mcwalke2 Well-Known Member
    Charlotte, NC
    Thanks for this man!
  15. Dec 14, 2016 at 8:52 PM
    #535
    incogneato
    incogneato Well-Known Member
    Allen
    Tennessee
    2022 Jeep Gladiator Mojave 6MT
    Wish I'd written down the part numbers the OP gave. I ordered form superbrightleds, just grabbing their "recommended for our vehicle" bulbs. Dome light was a major hassle installing... blew the fuse as soon as I tested it. I wish changing the least accessible fuse block, ever was the end of the story, but what I have now are interior lights that no longer go off when in the "door" position; even with the factory bulbs back in. Then I found the thread I wished I'd seen earlier, where folks are having to replace the overhead console to correct it. At $600+, it looks like I'll live without that feature, or cobble my own system. Live and learn...
  16. Feb 2, 2017 at 6:28 AM
    #536
    patr
    patr [OP] First-time Owner
    2016 Blazing Blue Pearl Tacoma TRD Sport 4x2
    That really sucks, I feel for the people that have had $$ issues with this mod
  17. Feb 2, 2017 at 1:35 PM
    #537
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    I think the biggest problem people have with this mod is that when they go to pop out the oem bulbs is that you are shorting out the circuit using a metal tool to pop out the oem bulbs. touching the reflector and prying with a metal tool into the socket is creating a short which is blowing the CB or worse the control module for the lights.
    but that's just my thoughts. also I used vleds which at the time where dual polarity 194 bulbs, the 3175 29mm festoon and the standard vanity bulbs from vleds.
    edit : and I've done this to a 2014 4Runner LE, 2016 Tacoma Sport DC and a 2016 Highlander XLE (that bitch has way to many dam lights in it)
    and I never shorted anything across 3 vehicles.
  18. Feb 15, 2017 at 4:32 PM
    #538
    Shermyota30
    Shermyota30 Well-Known Member
    Bay Area
    17 sport 2wd doublecab
    I install the interior led bulbs and now the vanity mirror is too bright. Anybody have knowledge of another bulb brighter then oem but not blinding like the led's?
  19. Feb 19, 2017 at 9:05 AM
    #539
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Incandescent.
  20. Feb 19, 2017 at 8:15 PM
    #540
    Def Leppard
    Def Leppard Active Member
    Richard
    2017 Blue Tacoma TRD
    I would like to do this mod, but seeing post where people have had electronical problems after worries me. How common are these issues? I figure, so long as I don't use a metal tool to pry out the old bulbs, I shouldn't have any issues, right?
