LED Interior Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patr, Oct 17, 2015.
  1. Jan 27, 2020 at 5:29 PM
    #641
    dhectorg
    dhectorg Well-Known Member
    Don
    2020 Toyota Tacoma TRD OffRoad
    I just got my 2020 MGM DCLB Off-Road and I want to upgrade the interior lighting asap. I read thru the thread and there are some suggestions, but I want to get the lasted opinions on this. Who makes the best LEDs upgrade kit for our trucks? I don't mind if it cost a bit more, but I want nice bright 6000k lights that last for the life of the truck (buy once cry once lol).
    JRLYON likes this.
  2. Jan 27, 2020 at 5:38 PM
    #642
    strongrob
    strongrob Active Member
    Rob
    2018 Beige DCSB TRDOR
    SCS F5s
    As the thread says, MESO makes the best interior lights. In that colour temperature also.
  3. Jan 28, 2020 at 4:54 AM
    #643
    SmileyGuy
    SmileyGuy Well-Known Member
    Darrin
    Nova Scotia
    20 Tacoma Off Road Voodoo Blue DC SB TRD Premium CAN
    I purchased these but without a picture of the actual LED bulbs you receive. This kit includes 4 LED visor mirror, 1 LED dome, 2 LED map and 2 LED license plate lights. The LED lights for the license plate look like the LED map lights and are packed/labeled license plate only. All of these LED lights have a polarity meaning they need to be inserted correctly If the do not light up you need to rotate 180 degrees.
    Fyre Flys 9 piece Toyota Tacoma 2016-2019
    3014 Series, 6000k color
    https://www.amazon.com/gp/aw/d/B07KRNFQF6?ref=ppx_pop_mob_b_asin_image
    Dome LED
    Map LED
    Visor LED
  4. Jan 28, 2020 at 5:02 AM
    #644
    SmileyGuy
    Darrin
    Nova Scotia
    These LED lights were very bright but not extreme to the point of too bright.
  5. Jan 28, 2020 at 5:07 AM
    #645
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    I did the Fyres from Amazon in my 20 as well because of a post here and very happy with them. Wanted to keep the stock look because I don’t like the MESO version. I did the 5050 kit though.
    For $15, it was worth the upgrade and I can think about if I want to do anything else.
    PFB and Tekpnw like this.
  6. Jan 31, 2020 at 6:05 PM
    #646
    mandog
    mandog Lesser-Known Member
    Race City, USA
    2017 4WD Off-Road Quicksand Overland
    I’m unsure, but I thought I heard installing these interior LED lights could affect other lights within the truck’s system. Namely the headlights/fog lights.
    I only had my truck for a month before installing some cheap-o Amazon interior LED’s. So, I’m unsure if its because of them or something else entirely, but I’m having a random flicker from one of the exterior headlights. Anyone words of wisdom on this?
  7. Feb 1, 2020 at 6:21 AM
    #647
    SmileyGuy
    Darrin
    Nova Scotia
    Changing the interior lights is straight forward. When you get into turn signals and side marker lights the electrical system does light checking and expects to see a halogen filament draw an expected current. When this check fails the electrical system indicates an error that a light is not working. The term is called hyper flash and warning. There is a fix for this and a load resistor need to be installed across each light base. the resistor emulates the halogen filament during the electrical check. Your internal LED lights will not affect your fog lights or headlights. I would check that your bulbs are firm in the bases in the headlights.
    https://www.superbrightleds.com/mor...-turn-signal-hyper-flash-warning-fix/190/831/
    dhectorg and strongrob like this.
  8. Feb 1, 2020 at 3:19 PM
    #648
    RustedRon!
    RustedRon! Active Member
    Ron
    2019 Tacoma double cab trd sport
    Added front receiver.
    What's the trick on the map lights? How are ya'll getting them out? Mine are recessed in the corner of the diffuser. I can't get my nubs on em!!
  9. Feb 1, 2020 at 4:23 PM
    #649
    pelts79
    pelts79 Well-Known Member
  10. Feb 1, 2020 at 4:27 PM
    #650
    SmileyGuy
    Darrin
    Nova Scotia
    Scotch tape on cold bulb as you already know they get hot fast. Use short piece trying to wrap the bulb. Will probally take a number of tries to get it to stick for the downward pull. You may have trouble inserting the LED light, it should be flat side towards windshield.
  11. Feb 1, 2020 at 10:24 PM
    #651
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    Is the placement of the dome light over the rear seats standard across the 20 line? My 19 SR5 has the dome light rather uselessly over the front seats.
  12. Feb 2, 2020 at 3:03 AM
    #652
    Willys714
    Willys714 Well-Known Member
    VVAZ
    2020 OR DCLB Silver
    Meso Custom not only offers a great product but backs it up with amazing customer support. I bought the rear dome light and the bulb adapter didn’t fit. Toyota has a very poorly designed bulb holder for this type of bulb and MESO Custom immediately had a solution in my hands.
    I’ve bought a lot LED’s for my RV and learned a lot about lumens and color temps, Meso’s light is the right color and really bright. The shape of the ceiling keeps the light from glaring in your eyes but the light is very bright and completely lights the back seat.
    Rainoffire, strongrob and MESO like this.
  13. Feb 2, 2020 at 8:20 AM
    #653
    SmileyGuy
    Darrin
    Nova Scotia
    I have a sun roof that opens therefore the dome is over the back seats. The 2020 SR5 double cab dome is center the cab and 2020 access cab is over rear area. Both domes are behind front head rests.
  14. Feb 2, 2020 at 10:03 AM
    #654
    RustedRon!
    Ron
    hotrodder636 likes this.
  15. Feb 2, 2020 at 11:05 AM
    #655
    strongrob
    Rob
    SCS F5s
    I would have preferred something in the 4000K range with high CRI, though I knew what I was buying and I love the look of MESO’s lights.
    MESO likes this.
  16. Feb 2, 2020 at 11:06 AM
    #656
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    :thumbsup:
  17. Feb 10, 2020 at 11:41 PM
    #657
    dhectorg
    Don
    MESO only sells the dome light according to their website. I want to upgrade ALL of my interior lights, as well as the license plate and reverse lights.
  18. Feb 11, 2020 at 1:45 AM
    #658
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    MESO does sell searing bright reverse lights.
    Total Stage 1/2 LED Taillights.
    Hmm, MESO Ultimate Vanity and License Plate lights.
    One can dream.
    Infervesco and strongrob like this.
  19. Feb 11, 2020 at 7:10 AM
    #659
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    He also sells map lights, so I'm not sure where he's getting that he only sells dome lights.
    strongrob likes this.
  20. Feb 11, 2020 at 7:17 AM
    #660
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Meso interior led lights were too bright for me. I purchased Phillips led bulbs at a local parts store and they are just fine.
    DamGuide likes this.
