LED Interior Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patr, Oct 17, 2015.
  1. Nov 7, 2015 at 9:17 AM
    #121
    AndyNguyen
    AndyNguyen Well-Known Member
    The vleds is also 31mm bulb, its very tight. The bulb does not fit straight
    Dustin-OH16 likes this.
  2. Nov 7, 2015 at 9:29 AM
    #122
    pghmtnbiker
    pghmtnbiker Well-Known Member
    Jon
    Pittsburgh, PA
    2016 Tacoma Access Cab Off Road Super White
    I'm assuming you ordered https://www.superbrightleds.com/moreinfo/festoon/de3175-led-bulb-4-smd-led-festoon-30mm-car/2107/ correct?
    The main difference (besides size) is 4 LEDs instead of 10 and a decreased brightness 61 vs. 95
  3. Nov 7, 2015 at 11:25 AM
    #123
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    Thank you, especially, for this nicely detailed 'how to'. It made my installation go much better than it would have otherwise (I still stupidly blew the fuse).
    I just want to make (2) notations:
    First, in my Access Cab TRD OR, the prying divots on the Dome Light cover are on the side closest to the front of the truck, not the rear.
    And Second, the License Plate bulbs can, indeed, be a real PITA to remove and re-install. I lost some skin.
    Thanks again for your help........................... Frank
  4. Nov 7, 2015 at 12:33 PM
    #124
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Thanks for posting this info!
    :thumbsup:
    Ordered all of these along with the 921 back-up lights - looking forward to the added visibility.
    Next will I'll upgrading the Limited's OEM fog lights with some Morimotos from Vleds!
  5. Nov 7, 2015 at 5:25 PM
    #125
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    that's why I said a 30mm or better yet a 29mm led. vleds 3175 comes in 31mm. other 3175 outside of vleds come in 30 and 29mm.
    vled 3022 is a 29mm hence I posted 3175 and 3022 bulbs.
    access cabs have a different dome light than double cabs, sorry about that.
  6. Nov 7, 2015 at 9:38 PM
    #126
    patr
    patr [OP] First-time Owner
    2016 Blazing Blue Pearl Tacoma TRD Sport 4x2
    Wow, I hadn't realized this thread blew up the way it did :p
    I'm glad I could help everyone!
    This is true, the bulb is a little bit slanted inside of the socket but it fits well enough that I don't see the need in buying a smaller one (yet)
  7. Nov 9, 2015 at 7:12 PM
    #127
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Nice selection of Sylvania LED's now being sold locally at Autozone stores. I bought the dome and maps. Two thumbs up. Bright. They've gotten rid of their Pilot brand bulbs and replaced them with Sylvanias (in all the stores I've been in lately). Good move on their part.
    DeadEyeWI and Mrharper68 like this.
  8. Nov 10, 2015 at 7:03 AM
    #128
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    finally ordered mine
  9. Nov 10, 2015 at 8:30 AM
    #129
    Derek G
    Derek G Well-Known Member
    Silverton CO
    2016 TRD OR DC
    Do they make the map lights in red? Had a hard time searching the site.
  10. Nov 10, 2015 at 8:46 AM
    #130
    NMTrailRider
    New Mexico
    Philips also makes a nice LED 30mm dome.
    I do know that you can get an incandescent red 194. Not sure about LED.
    Mrharper68 and Derek G[QUOTED] like this.
  11. Nov 10, 2015 at 8:55 AM
    #131
    Derek G
    Silverton CO
    2016 TRD OR DC
    I think I would need LED to get enough punch from red. The good thing is that incandescent is cheap to try. I put them in our fire trucks once but the tint they use burned off in a month.
  12. Nov 10, 2015 at 9:13 AM
    #132
    NMTrailRider
    New Mexico
    There are cheap red LEDs available online. But I wouldn't trust them. The cheap ones are terrible.
    Derek G[QUOTED] likes this.
  13. Nov 12, 2015 at 9:37 AM
    #133
    arpowers410
    arpowers410 Well-Known Member
    Andrew
    Ohio
    2019 trd off road
    Just ordered a set for the map lights, dome light and license plate lights. Didn't need the mirror/vanity lights seeing on how the drivers side on mine doesn't even have a mirror, didn't even check the passenger side. Should be in the mail in a couple of days, anyone have a detailed way or video on how to get the map lights out, the rest should be self explanatory I just don't want to mess up the over head console.
  14. Nov 12, 2015 at 10:54 AM
    #134
    NoDak
    JR
    Minot, ND
    could try reading the thread, it has instructions :)
  15. Nov 12, 2015 at 11:14 AM
    #135
    arpowers410
    Andrew
    Ohio
    2019 trd off road
    Yeah I read through it I found the instructions. Kind of jumped the gun on that last post. My bad at work.
  16. Nov 12, 2015 at 11:21 AM
    #136
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Installed my LEDs. One of the vanity LEDs didn't work (I know they are polarity sensitive). You have to push the actual diode to get it to work so must be a weak soldering joint. The overhead 31mm Festoon puts out great light, but as others have said, that little bastard is a tight fit. I'm afraid if I hit a big enough bump, it's going to pop right out so ordering the VLED6K BULB 29MM 3022 instead. The rest of the lights are great. With the license plate LEDs they will brighten the camera so you'll need to turn the contrast down in your settings.
  17. Nov 12, 2015 at 9:15 PM
    #137
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    Have people had success with the 31mm dome light? I ordered that one before reading the post saying its too tight.
  18. Nov 12, 2015 at 9:21 PM
    #138
    UberDingu
    UberDingu Well-Known Member
    CT
    21 Off-Road AC 4x4 V6
    I've had no issues with it. It is a tight fit but it works fine
  19. Nov 12, 2015 at 9:29 PM
    #139
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    ok thanks for the input, I received them in the mail today so I'm going to install them tomorrow morning
  20. Nov 13, 2015 at 4:04 AM
    #140
    atrouth
    atrouth Well-Known Member
    Anthony
    2016 MGM Tacoma TRD Sport DCLB 4x4
    Depends which one you get. The 31mm I got wont fit in there, its cocked at a slight angle and doesnt allow it to be secured with the spring fit piece
