LED Interior Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patr, Oct 17, 2015.
  1. Nov 15, 2015 at 9:25 AM
    #161
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    I used small piece of duct tape, and pulled them out
  2. Nov 15, 2015 at 10:35 AM
    #162
    s2kshock
    s2kshock Well-Known Member
    A
    2020 Tacoma TRD OR DCSB w/ Tech, Cement
    265/70/17 Tires and Upgraded Wheels
    Think its dumb the Gen 2 had LED tails and 3 doesnt...
    knhorn likes this.
  3. Nov 15, 2015 at 11:29 AM
    #163
    johnnycat500
    johnnycat500 Well-Known Member
    SoCal
    2016 TRD Sport Access Cab White
  4. Nov 15, 2015 at 12:57 PM
    #164
    patr
    patr [OP] First-time Owner
    2016 Blazing Blue Pearl Tacoma TRD Sport 4x2
    All of them were easy, no hard work at all
    30 minutes TOPS
    Definitely worth the money
  5. Nov 15, 2015 at 3:19 PM
    #165
    Hook & Ladder
    Hook & Ladder Well-Known Member
    Maine
    16' TRD Tacoma
    The project @c4_fabrication-Sliders, HC bumper w/ swing out @kb_voodoo_fabrications-Bed rack @tepuitents-RTT @cali_raised_led-Fogs, ditch lights, bed stiffeners @prinsudesign-Roof rack @kingshocks-2.5 with adjuster @totalchaosfabrication-UCA @rcioffroad-diff skid plate Follow at @wicked_overland #nacrew
    JW how did the two pod lights above the driver/passenger come out? They click in off, so do you just pop them out ?
  6. Nov 15, 2015 at 4:16 PM
    #166
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    Does anyone have the correct numbers of the exterior bulbs? Like rear tail/stop/turn, front marker and turn? I want to go red behind the red lens and amber for the front turns. I cant cross the bulbs, the O/M and Superbright dont agree to the same bulb sizes.
  7. Nov 15, 2015 at 4:44 PM
    #167
    Echomun
    Echomun Member
    2016 Silver v6 SR5 Double Cab 5' bed
    Tacoma bed mat, Husky weatherbeaters, LEDs.
    On the license plate bulbs, do you turn the black outer piece or just the grey?
  8. Nov 15, 2015 at 5:50 PM
    #168
    arpowers410
    arpowers410 Well-Known Member
    Andrew
    Ohio
    2019 trd off road
    Just the grey plug it just twists out.
    Echomun[QUOTED] likes this.
  9. Nov 16, 2015 at 4:05 PM
    #169
    vols2vols
    vols2vols Active Member
    Scott
    2016 Tacoma TRD Sport Double Cab 4X4 Barcelona Red
    well i put the wled-cw5-cbt in my plate tag lights. a woman's hand would be better on this job, they look good. was taking the vanity lights out and i didnt have a puller so i was using a small electronic screwdriver and touched some metal and blew a fuse. so i was taking fuses out to see which one i had blown and it was a 7.5 fuse. but i must have put one of the fuses in the wrong spot, i know im stupid. my truck would not start. so i had to read the manual and override the regular procedure to get it to start. after that, couldnt get the shift to go out of park, yes i had lights in the dash saying brake over ride malfunction or something like that. so i had to pull the little plug out and push down on whatever to shift. took to toyota place to repair and it cost me 60.21 because it was my fault. the repair bill said " replaced mpx under dash changed location of stop lamp fuse into proper spot". i asked them if they would put the rest of my led's in since obviously i am not keen on this. they said they couldnt put anything in other than what it calls for and if i put the led's in it that it could void my warranty. now im thinking about taking my plate led's back out and putting the oems back in or taking it to a stereo/led man here in town that everybody says does great work. also dont even know if the plate canbus led is right. some one on this forum says he is going with the 194 and he may know something. and back to the license plate light, dont know if it can be done but if we could pop off the clear cover on the bumper, it may be a simple change?
  10. Nov 16, 2015 at 4:13 PM
    #170
    patr
    That's unfortunate, but like the dealer said, it was your fault :eek:
  11. Nov 16, 2015 at 5:48 PM
    #171
    Echomun
    Echomun Member
    LoL! That sucks dude. Sounds like my luck. LoL
  12. Nov 18, 2015 at 7:16 PM
    #172
    Billherman
    Billherman Member
    Just a follow up on the back dome light size. I tried a 31mm like the original post said which was too big. After trying smaller and smaller sizes I finally ended up with a 28mm. It fits perfectly. Superbrightleds did not have a 28 but I found one on Amazon. Hopefully this will save someone else some trouble.
  13. Nov 19, 2015 at 7:52 AM
    #173
    ToyFXR88
    ToyFXR88 Well-Known Member
    WI
    2016 MGM DCSB TRD Sport 6MT
    Couldn't help but notice that all the part numbers you listed were for canbus compatible bulbs. Was there a reason you selected canbus bulbs?
    According to tech specs on super bright led website, most of the lights available in natural white produce more lumens (brightness) than cool white. But I do like the look of cool white better.
    Tacoma2GR likes this.
  14. Nov 19, 2015 at 7:57 AM
    #174
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I liked the cool white except for the vanity mirror lights. it's like they almost have a hint of purple.
  15. Nov 19, 2015 at 8:20 AM
    #175
    sparty83
    sparty83 Well-Known Member
    2021 Tacoma TRD Sport
    I went to their site which they don't have 2016 Tacoma, I assumed you just went with 2015?
  16. Nov 19, 2015 at 8:20 AM
    #176
    sparty83
  17. Nov 19, 2015 at 8:25 AM
    #177
    ToyFXR88
    WI
    No, don't do that. Use the part numbers the OP posted. Go to their site, click search and type the part number in verbatim and you'll get exactly what you need. FYI I also recommend upgrading your reverse lights. They're 194/921 style. Search for either, but those bulbs are all fairly compatible, just vary in size. I LOVE super bright back up lights, so I went with WLED-W19-T bulbs. A bit pricey, but they produce almost 300 lumens each, 4-5x more lumens than the bulbs listed by the OP for the plate lights
  18. Nov 21, 2015 at 7:22 PM
    #178
    Krezz
    Krezz Well-Known Member
    Kevin
    Ontario, Canada
    '18 Tundra Platinum Crewmax
    All mod's listed on website - regarexpeditions.com
    So I got my interior lights all done, was simple enough, especially thanks to this thread. The tape around the map lights was A+! I taped it, let it settle for a moment and then used the grip of the tape and wiggle/pulled those suckers right out. The dome light used by the OP, was in fact, I found to be a bit larger than it should be. It did go in, slightly sideways but it works, so I'll leave it for now.
    I have the TRD Sport Premium pack, so my dome light is a bit recessed due to the sunroof, but looking for the little indents is where I was able to slip my flat head screwdriver into and the cover popped right off without issue.
    Vanity lights were super easy, and I find them perfectly fine to use still. The brightness isn't distracting.
    Tomorrow when I have sunlight, I'll be tackling the rear plate lights, using the directions I've read earlier in the thread, so here's to that!
    the taco crna likes this.
  19. Nov 21, 2015 at 7:40 PM
    #179
    patr
    Glad you had success with the installation :)
  20. Nov 22, 2015 at 5:42 PM
    #180
    Krezz
    Kevin
    Ontario, Canada
    So was working on the plate lights and I didn't measure the length of the old vs the LED, and then ran out of time as I had to get to a dinner. I was able to swap one side so far, going in under the truck and turning the socket, then pulling them out seemed to work. Getting it back in, was a little trickier. Anyone else who has done this already, does the LED slot back in perfect, or does it sort of stick out a little more? I'll try and get a picture tomorrow if required. I was able to drive to the dinner and back home and the light didn't move or anything, so maybe it's secure enough, but I just wanted to hear others results. Tomorrow morning I plan on tackling the other side and will compare the bulbs a bit better and try to snap a picture of the end result.
