LED Light Bar Install?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ruggybuggy, Dec 26, 2017.
  1. Dec 26, 2017 at 4:57 PM
    Ruggybuggy
    Ruggybuggy [OP] Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Yes I have search but didn't really find an answer. I had a light bar installed on my 12 Tacoma in the lower grill. I bought a 31" straight LED light that came with the mounting feet on the ends of the light. I was able to mount the feet right to the aluminum bumper supports and the light was positioned exactly in the right position in the grill. Now I have a new '18 and I've decided to mount a new led bar in the same position. Every installation I've come across shows an optional bracket that has to be mounted so the light bar can be mounted. Can't the light be mounted in the same position as the Gen 2 trucks without using the "special" brackets? Is the height from the aluminum bumper mount to the opening the same for both trucks?
    Thanks in advance.
  2. Dec 26, 2017 at 5:06 PM
    Malibu7tss
    Malibu7tss Can' t think of anything to type here right now.
    Central pa.
    2016 trd sport dcsb 4x4 bbp 6spd manual
    Old man emu with 888's and headstrong off road progressive aal, trd pro wheel, Cooper Stt Pros 285/70r17
    It is not the same. You can make your own brackets. And the light bar will fit. The special brackets make life so much easier though.
    Ruggybuggy[OP] likes this.
  3. Dec 26, 2017 at 5:54 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Buy the vehicle specific brackets. It will make your like easier.
  4. Dec 26, 2017 at 6:00 PM
    7ender
    7ender Well-Known Member
    You cannot mount straight to the crash bar.
    I picked up some 2nd gen light bar brackets to experiment with, and was able to use them with little modification. They were ~20$ as opposed to the currently available 3rd gen options that run ~$60.
  5. Dec 26, 2017 at 6:28 PM
    Ray-man
    Ray-man New Member
    Blue tocoma trd
    6" lift
  6. Dec 26, 2017 at 6:31 PM
    Ray-man
    Ray-man New Member
    Blue tocoma trd
    6" lift
    What was light bar in your 2ed gen did it come with brackets, how did it hold up, that' sounds like what I want to do with my taco do not want to cut out the grill looking for a quality light bar
  7. Dec 26, 2017 at 7:49 PM
    1cleanFG
    1cleanFG DialsGarage
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Toytec Alumaseries Coilovers OME El111R Camburg UCAs Scs sr8 17” 285/70/17 KO2
    I have a 17 TRD OR and used the Cali raised brackets and a rough country led light bar.. works perfect.
    Its stealth mount=no cutting.
    I do have a brand new set of RC 2nd gen brackets sitting around.
  8. Dec 26, 2017 at 7:55 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Where are you located? I have a set of stealth mount brackets that I've been meaning to sell but I'm to lazy to hassle with shipping.
  9. Dec 26, 2017 at 8:17 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I was a cheap ebay light bar that worked very well. It has two foot type brackets that I used self tapping screw to hold it down to the bumper supports. It lined up perfect.
  10. Dec 26, 2017 at 8:18 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I'm in Florida for the next two weeks then up to MN 56649.
  11. Dec 26, 2017 at 9:48 PM
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
    I used the cali raised mounts and light bar from them. Fits perfect and super clean. The 2nd gens crash bar lines up differently allowing you to just screw the regular mount into it. I had an 09 and now a 16.
  12. Dec 27, 2017 at 4:56 AM
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    I too used the cali-raised brackets, but I did see someone who drilled it into the area behind the grill...
  13. Dec 27, 2017 at 6:29 AM
    dj0mladen
    dj0mladen Well-Known Member
    Milan
    New Hampshire
    '17 TRD Sport Double Bed
    Where did you find them? I would be up for little experiment to save few bucks.
  14. Dec 27, 2017 at 6:38 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I would like to know as well. I had a $50 ebay led light bar on my 2nd gen that worked really well. Three years old and still working great. I wouldn't mind doing this for my 3rd gen. I don't really want to pay $300 for a light and mounts.
  15. Dec 27, 2017 at 10:41 AM
    ajracing
    ajracing Well-Known Member
    aj
    Houston, Tx
    2018 tacoma
    what's this Cali light brackets you guys are talking about?
  16. Dec 27, 2017 at 10:52 AM
    dj0mladen
    Milan
    New Hampshire
  17. Dec 27, 2017 at 11:13 AM
    7ender
    I got them on eBay, but the identical ones are all over if you just search for them on Amazon, etc.
    On my second gen I had mounted straight to the crash bar with no brackets. On the third gen the offset is not correct to reach the bumper grill. You'll need to use the second gen brackets to get the spacing correct, and then use some sort of adapter to get the height correct. I used the mounting brackets that came with my light bar but drilled a couple extra holes in them.
