Led light bar or pods
Discussion in 'Lighting' started by dmascorro, Oct 22, 2019.
  1. Oct 22, 2019 at 12:13 AM
    dmascorro
    dmascorro [OP] Member
    Daniel
    2015 metallic grey tacoma TRD
    Been looking to get a LED light bar or pods just can't make up my mind any suggestions?
  2. Oct 22, 2019 at 12:21 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Light location?
  3. Oct 22, 2019 at 2:04 AM
    dmascorro
    Daniel
    Maybe front light bar or ditch light also looking to replace my factory head light with LED but don't know which one.
  4. Oct 22, 2019 at 2:14 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    don't bother with LED on the 2nd gen headlights unless you switch to a projector. the headlights can't focus the beam and you pretty much blind everyone. it will seem like its awesome. I had them for a bit got tired of getting flashed by everyone. Picked up a used set of HID Retrofits on TW and fixed them up. You can add projectors and LEDs as another option which is the new popular method. Its really up to you but LEDS in halogen headlights do not work well.
    Pods or Light bar depends on if its for looks for use and depends on what. I have a combination of both in various formats.
    DirtJumper14 likes this.
  5. Oct 22, 2019 at 2:30 AM
    bs63366
    bs63366 Well-Known Member
    San Angelo
    2014 Tacoma TRD Off Road DCSB
    ARE Z-series shell, ImMrYo mirror lift, always on fog-lights.
    What are you looking to get from the lights? If you are looking for more light on road, check out the thread on here for bright replacement headlights or some of the replacement fogs that I believe RIGID and Baja Designs sell that have the cutoffs you need to use them on road. If you are looking for specifically off road, ditch lights seem to be better suited pointing to the sides to illuminate what is besides you and the light bar will take care of in front of you. That being said if you put the light bar above the windshield you will get glare off of the hood from it.
  6. Oct 22, 2019 at 9:06 AM
    dmascorro
    Daniel
    ok sounds good thanks for the information I'll have to look in to that. what about cali raised led any idea if they are any good?
