Led light bar relay
Discussion in 'Lighting' started by Dans2131, Feb 7, 2020.
  1. Feb 7, 2020 at 11:01 PM
    Dans2131
    Dans2131 [OP] Active Member
    Daniel
    2020 white tacoma trd off-road 4x4
    Heyy so I did my ditch light and ran a fuse jumper to my light fuse and the switch turns in and off perfect with my lights , now I have installed an led light bar and was wondering where I can put another jumper so the switch will do the same to turn on and off with my headlights , not sure if putting a jumper on a jumper would be smart or what other fuse would be good to use ?
  2. Feb 7, 2020 at 11:03 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    You don’t want to be driving around on the streets with a lightbar constantly on. It’s not very hard to turn the lightbar on with the switch anytime you need light...
    whatstcp likes this.
  3. Feb 7, 2020 at 11:06 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Sounds like he needs a separate switch and a relay to trigger the light bar. Yes, he doesn’t need to be running around with the light bar on when the lights are on.
  4. Feb 7, 2020 at 11:11 PM
    Dans2131
    Daniel
    Sorry that’s was bad word choice on my part I was referring to the switch , on my first Install I put the switch leds like the button only to turn on and off when I turn on my lights and when the truck is off the light switch is off , now I have to do the same for this switch for the led lights . The way I got that to work was with a fuse jumper so that the light on the switch will illuminate when the lead lights turn on and off but not the led or ditch lights those only turn on when I click the switch , my concern is where can I plug in another fuse jumper or can I put 2 fuse jumpers together is that safe ?
