LED light bar security
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kai38`, Jan 3, 2013.
  1. Jan 3, 2013 at 3:47 PM
    kai38`
    kai38` [OP] Well-Known Member
    I have a 21in LED light bar to mount on the front of the Tacoma.
    I don't have an after market bumper and will be mounting the LEDs on a Distinct Offroad light bar and the nuts/bolts will be exposed and someone could easily remove them and steal the LED light bar.
    The problem will also be the side bolts are exposed also.
    Any suggestions?
  2. Jan 3, 2013 at 3:51 PM
    nut
    nut she'll ride
    Patrick
    Currently Richmond, VA
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    mount it like mine. its a PITAto get to the bolts without taking the grill off
    I have since cut out the little horizontal plastic piece in front of the light (on the lower valance), no pic of that
  3. Jan 3, 2013 at 3:53 PM
    rondog
    rondog your TW web developer!
    Ronnie
    Escondido/San Diego
    he said he has a custom bumper..maybe there is some sort of aircraft cable you can tie to it that is bolt cutter proof..just thinking, not sure if anything like that exists
  4. Jan 3, 2013 at 3:55 PM
    nut
    nut she'll ride
    Patrick
    Totaled
    :notsure:
  5. Jan 3, 2013 at 3:55 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    was wondering the same thing, but possibly mounting two 15" LED bars instead of one 21" on mine.
  6. Jan 3, 2013 at 3:57 PM
    nut
    nut she'll ride
    Patrick
    Totaled
    I have one 15d from blitz, going to add another soon and mount them side by side in the lower valance like i have the first one. easy as pie
  7. Jan 3, 2013 at 4:00 PM
    kai38`
    Is it mounted between the aluminum blocks for the bumper with a piece of metal across it?
    I was thinking of doing that.
    Did you have to remove the plastic outer bumper first?
  8. Jan 3, 2013 at 4:04 PM
    myth01
    myth01 Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    Figure out the size bolts your gonna use and go buy the same size in stainless steel anti tamper bolts. You may have to buy the tool to use with the bolt heads but they will be safer than regular bolt heads
  9. Jan 3, 2013 at 4:08 PM
    nut
    nut she'll ride
    Patrick
    Totaled
    Exactly, I just used a piece of aluminum angle iron between the blocks on the truck. All I removed was the top grill and did all the work reaching down (couldnt ever figure out how to remove the bottom grey outer bumper piece)
    I love it. Hard to steal and looks clean ;)
    Paid less than $15 for the angle iron at lowes
    Put 2 pieces back to back like this and it makes it super rigid. Just remembered thats what i did
    edit: ill take pics tomorrow and post up
  10. Jan 3, 2013 at 8:43 PM
    kai38`
  11. Jan 3, 2013 at 8:48 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    tennessee
    09 Taco & 16 SR5
  12. Jan 3, 2013 at 8:49 PM
    monsterkx2fiddy
    tennessee
    09 Taco & 16 SR5
  13. Jan 3, 2013 at 9:19 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
  14. Jan 3, 2013 at 9:39 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Nothing is cordless Dremel proof.
    I broke the key off to my storage unit in the Brinks "tamper proof" lock.
    Storage place owner let me borrow his bolt cutters. No joy, the design of the lock protected it against that.
    Went to Lowe's, bought a cordless Dremel and AC inverter.
    Plugged it all into the cab of the truck and let it charge while I grabbed something to eat.
    5 minutes and one cutoff wheel I made two cuts in the shackle and opened the storage unit.
  15. Jan 3, 2013 at 9:42 PM
    IronCladTRD
    IronCladTRD Consistently Irregular
    Corbin
    Hotel California
    2003 4x4 Manual V6 3.4L
    5100s/Eibach 3" lift, All-Pro Expo rear leafs, Elite front bumper & sliders, Smittybilt XRC8 winch, 33x10.5r15 BFG All terrains, Ultra Rogue 15x8 rims, homemade bed rack, Midland 1001z CB radio Deckplate mod, Century shell, train horn, debadged
    You need this
  16. Jan 3, 2013 at 9:47 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Chandler, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
  17. Apr 21, 2014 at 5:24 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Reviving an old thread.
    I want to use tamper resistant stainless hardware to attach a Rigid E2 20" bar to my ARB bumper (on top of bumper or on center of hoop).
    Does anyone have a good solution to replace the Rigid hardware for an E2 bar?
