LED LIGHT BAR SWITCH, DIMMABLE?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spencer97TJ, Nov 21, 2017.
  1. Nov 22, 2017 at 12:02 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    yeah, the idea seems so straight forward it would be hard to mess it up - connect switch dimmer leads to green and green/white wires coming from a switch on your dash. i don't know.
  2. Nov 22, 2017 at 4:07 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    He reposted the same process here in a thread on TW somewhere. It’s a real nice walkthrough on DIY Bussman.
  3. Nov 24, 2017 at 12:09 PM
    Spencer97TJ
    Spencer97TJ [OP] Well-Known Member
    Spence
    CT
    stock
    Time to actually install the light bar now. I only had time for the harness and switch last weekend. I will return to the dimmer issue on another day.
  4. Nov 25, 2017 at 3:03 PM
    Spencer97TJ
    Spence
    CT
    stock
    Diy light bar mount. Steel strapping from Home Depot. I made spacers out of 3/4 inch copper pipe. Might be a better spacer idea. But I had pipe and a cutter on my bench. And it worked well.
  5. Nov 26, 2017 at 10:50 AM
    Spencer97TJ
    Spence
    CT
    stock
    Pretty happy with how it all mounted up.
    Lumberjackcoma likes this.
  6. Feb 16, 2020 at 3:49 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Bump for question. So I was going to wire up my led light bar switch as described in this post (add-a-fusse and splice into dash power for switch illumination). But got me thinking , can’t i just “splice” into a nearby switch (auto high beam switch) for all three wires. The main power (green wire on led switch), then dash light power and ground (red2 and black) ? 6nW3HicXL5XzKbvemxLboR0QT-AkYslCvTnK2XXv_d17ce5bac6a461136b720b8dd6bafa11ebdbc993.jpg 19p0YN1IvelKuyDW6duuZ69rdUL2YuCII0lTgoBq_14a4d58e2d3aeec798f13a560f4f9d554bea7795.jpg
    If the stock switch (auto high beam switch) has a main power with fuse obviously, and power/ground for illumination why not just piggy back off these three ? Obviously the remote wire for the LED light bar relay is independent of this , and has already been wired up and fed through the fire wall .
    I’m probably missing something like too much power through the stock wire ? Or fuse not rated for an additional switch ?
  7. Mar 9, 2020 at 4:59 PM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
  8. Sep 1, 2020 at 9:04 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Does anyone’s lights dim automatically? I wired my switch up And it was working fine but once I put the light bar into the relay, once I turn the dash lights on the words light up bright but then dim over 50%. This doesn’t matter if the light bar is actually on or not. Anyone have any ideas?
  9. Sep 1, 2020 at 9:32 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    sounds like you wired it to be negatively switched, and you are getting a voltage drop through the relay coil.
  10. Sep 2, 2020 at 5:18 AM
    Canadianguy91
    Sean
    2016 Limited
    How could I have done that?
  11. Sep 2, 2020 at 8:06 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    i have no idea, I did not wire up that circuit.
  12. Feb 2, 2022 at 11:36 PM
    Telemachus
    Telemachus Active Member
    Beating and old, dead horse here.
    LED dim just fine if you tap into the green and green/white wire on the console buttons (2nd Gen). Since it is the ground resistance that changes with the rheostat, both LED lights in a CH4X4 switch dim normally.
  13. Sep 26, 2024 at 12:18 PM
    Wheever
    Wheever Member
    '21 TRD PRO
    Not to make dead horse paté, but does this work on 3rd gen? I'm dealing with the non-dimming LEDs right now.
  14. Sep 26, 2024 at 1:40 PM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    I had a power button on my workstation at the day job. Too bright and at eye level. Sharpie calmed it down nicely :D
