LED light bar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTaco07, Nov 5, 2011.
  1. Nov 5, 2011 at 10:03 AM
    BlueTaco07
    BlueTaco07 [OP] Super Mod!
    Cody
    Panama city, Florida
    Looking
    Trying to wire the reverse lights. gives me a posi wire to run the the reverse lights but where do I run it to?
  2. Nov 5, 2011 at 10:05 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    I'm no electrician but I think we'll need some more information.
    Are you wiring these to a relay? Are they going to be able to be powered anytime, or only when the truck is in reverse? Does it have a harness with it? Pics?
    Fink
  3. Nov 5, 2011 at 10:24 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    take the two 10mm bolts out of the side of the tailight
    pull the tail light off
    where the bulb for the reverse light is there are two wires, one red and black and one white.
    tap into the red and black wire
    check to make sure it lights up. :thumsbup:
  4. Nov 5, 2011 at 11:48 AM
    BlueTaco07
    Cody
    Looking
    I took all the bolts off the side but it still seems like its held on by something?
  5. Nov 5, 2011 at 11:49 AM
    Fink
    Orlando, FL
    I think he has this handled...I'll just sit back and read. :eek:
    Fink
  6. Nov 5, 2011 at 11:52 AM
    TacticalBacon13
    Dunk
    Beech Creek
    there are two 10mm bolts, one on top and one on the bottom. once there out its held in with two clips, just lightly tug and they will let go.
  7. Nov 5, 2011 at 11:52 AM
    BlueTaco07
    Cody
    Looking
    I just need to know how to take the tailight off. I took the bolt that he said to take off off but its still being held on by something :(
  8. Nov 5, 2011 at 11:54 AM
    Fink
    Orlando, FL
    That's the easy part for me.
    After the two bolts are out, just pull on them gently and they should end up popping out with a little negotiating.
    Fink
  9. Nov 5, 2011 at 11:57 AM
    TacticalBacon13
    Dunk
    Beech Creek
    this\/
    and this \/
  10. Nov 5, 2011 at 12:03 PM
    BlueTaco07
    Cody
    Looking
    Okay i got it out and i found the wire. Am I supposed to splice or how should I go connected this rascal?
