LED Light Bar ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mike G, Dec 23, 2016.
  1. Dec 23, 2016 at 4:16 AM
    Mike G
    Mike G [OP] Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
    I am thinking about adding a stealth mount 32" LED light bar to my truck, but I want them wired into my high beams. Does anybody know if this is possible and is there a write up on this?
    ChadsPride likes this.
  2. Dec 23, 2016 at 4:17 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    It possible, not sure how.....but possible!
    JoeCOVA likes this.
  3. Dec 23, 2016 at 4:25 AM
    Outlier
    Outlier I get around...
    Dallas GA
    2016 Tacoma AC TRD OR 4x4 V6 Slushbox
    No BRO-ness to speak of... Well, except Kbro2's
    ANYTHING is POSSIBLE. I'd like to do this to my ditch lights. Unfortunately i am an automotive electrical disaster waiting to unfold.
    Subbed :popcorn:
  4. Dec 23, 2016 at 4:28 AM
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    Yes .. all you need to do is find your high beam fuse, use a mini fuse tap off the light bar switch and plug into fuse location for the high beams
    I have the 16' SR5 and i just received my CaliRaised 5D light bar, i am going to use their wiring harness but add a MicTuning light bar switch that fits in factory opening left of steering wheel .. below is a video showing the switch and wiring (you can see the fuse tap i am referring to)
    https://www.tacomaworld.com/threads...group-buy-closed.461034/page-26#post-13929558
    opentang, Mike G[OP] and ChadsPride like this.
  5. Dec 23, 2016 at 4:29 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    At least in VA, this would make you fail the annual inspection. But certainly possible.
  6. Dec 23, 2016 at 4:30 AM
    OhioTaco68
    Central Ohio
    ? Your not allowed to have a light bar installed in Virginia
  7. Dec 23, 2016 at 4:36 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    If he wired in a bypass switch where he could disable the light bar for inspection purposes, and turn it back on afterwards. Put the disable switch in a discreet location and its all o.k.
    Now to the OP, you have to be careful in doing this because if you go tying into the factory light harness and something goes wrong, you have voided your warranty, and without proper auto electrical experience, especially with CAN BUS systems, its easy for something to go wrong.
    breader3 likes this.
  8. Dec 23, 2016 at 4:40 AM
    daddy_o
    Bossier City, La
    Its not the light bar itself, it would be having a light bar on while the high beams are on.
    OhioTaco68[QUOTED] likes this.
  9. Dec 23, 2016 at 4:53 AM
    Mike G
    I live in Md. so no problems with inspections. I definitely want to do this the right way. If I can`t reliably tie it into the high beams, I will just keep what I have.
    ChadsPride and OhioTaco68 like this.
  10. Dec 23, 2016 at 4:56 AM
    ChadsPride
    You could just put it on its own independent switch. JS
    daddy_o and OhioTaco68 like this.
  11. Dec 23, 2016 at 4:58 AM
    OhioTaco68
    Central Ohio
    Like i mentioned above .. use a mini fuse tap
    and splice it to hot wire on switch then plug it into fuse for your high beams
  12. Dec 23, 2016 at 5:30 AM
    Mike G
    Thanks for the info.
  13. Dec 23, 2016 at 5:31 AM
    ChadsPride
    Good luck and report back which ever way you go!
  14. Dec 23, 2016 at 6:58 AM
    OBXPaul
    OBXPaul Just do what you say you're going to do!
    Paul
    Kill Devil Hills, NC (Outer Banks)
    2016 Black Tacoma Limited, 1983 Blue Deluxe Pickup
    1983 restoration in progress, major mods so far new 6" lift and 35" Mickey Thompsons.
    Check your laws before wiring to come on with your lights, most LED light bars put out too much light and are illegal to run on public roads, even with high beam lights.
    0210, OhioTaco68 and ChadsPride like this.
  15. Dec 23, 2016 at 9:42 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I did it with the fuse tap into one of the high beam fuses. Those two fuses are located in the engine box and are towards the rear-passenger side of the box.
    The Cali wiring harness has three wires that run from the relay. Blue, white and black. Black is your ground and the white is the always-hot wire that ties in with the battery wire at the relay switch. The blue wire is hot when you turn your switch on and thus powers the lights via the relay (when done using the the plug-and-play method).
    I cut the white wire about an inch from the relay and covered the stub with heat shrink since it's still going to be hot. I then spliced a piece of 16 gauge into the other side of this freshly cut wire and connected it to my add-a-circuit in the fuse box. To get it into the fuse box I drilled a hole through the floor of the box near the rear-passenger corner.
    I cut off the plastic connector on the Cali harness, pulled it through the 3" rubber gasket gizmo on the firewall and connected to a Mictuning switch. It works. The switch has to be pressed and the hi-beams have to be on for the light bar to come on.
    Oh yeah, you can drill out the relay bracket, find an 8mm bolt (I think that's what it is) and use one of the two empty bolt-holes after of the fuse box to mount it.
    SB
    mmessier2 likes this.
