LED LIGHT BAR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JordanDziekan, Dec 31, 2016.
  1. Jan 22, 2017 at 11:25 PM
    TacoTony430
    TacoTony430 Member
    2016 Quicksand DCLB TRD Sport
    Ammo can bed storage Derped emblems and grill
    I just installed the eyourlife bar with Opt7 harness the other day onto the Cali Raised brackets. Required some modding of the brackets to make the bar fit. Mainly the holes in the side of the lightbar do not take the mounting screws that Cali supplied. I used a Dremel to make the slots a little bigger and then cut the bolts that eyourlife supplied so they would provide the right tension.
  2. Jan 23, 2017 at 1:25 AM
    Argo98
    Argo98 Well-Known Member
    Argo
    2017 Toyota Tacoma TRD-Sport 4x4
    Rough Country 3" spacer lift w/ shocks 285 KO2's wrapped around 16' ProComp Series 7069 Misc. bibbidybob lights
    Has anyone done a 50' curved roof mount? Trying to wrap my head around how the wiring goes from the engine bay to the roof of the car without being exposed...
  3. Jan 23, 2017 at 3:31 AM
    pc3coyote
    pc3coyote www.pc3coyote.com
    Paul
    SoCal
    17 BBP Sport DCSB 4x4
    Thanks! Do you think the Mictuning bar would be a better choice after you installed the Eyourlife or is worth the hassle?
  4. Jan 23, 2017 at 4:19 AM
    qxrtz4321
    qxrtz4321 Well-Known Member
    Mitch
    Montana / Washington
    I have, it tucks neatly between the window and black molding that surrounds window. Use 14ga wire and lube it up to make sticking it in there easy
  5. Jan 23, 2017 at 8:11 AM
    TacoTony430
    TacoTony430 Member
    It wasn't too much of a hassle, just a little extra work. I can't speak for the mictuning bar because of the size of the mounts on the side. I recommend reaching out to Cali Raised and see if they know what fits aside from the bar they sell.
