LED Light Bars... Show em off!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner32, Aug 18, 2011.
  1. Aug 19, 2011 at 3:30 PM
    #41
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    good god!!!!!! i was just about to say, no one has any action shots but ill shut up now! Thats bright as fuck
  2. Aug 19, 2011 at 3:34 PM
    #42
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    oh hot dam!
  3. Aug 19, 2011 at 3:54 PM
    #43
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    :popcorn: The guy at my shop just asked me if I wanted to be his show truck for his lighting products. He just did a Jeep Rubicon with a Rigid bar, it looked good. I think I am going to do it. He has bids with local,state and federal police in our area and he wants to use my truck to show him what he can do along the lines of undercover lighting. I will post pics when and if it happens. I will have to pretty it up a bit before that happens.
  4. Aug 19, 2011 at 3:56 PM
    #44
    toughtaco
    Not a light bar but here is what I got now
    I am going out side now to take a pic of the back of the truck......... there is some more lights on the back.
  5. Aug 19, 2011 at 4:01 PM
    #45
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    How many lumens do those HID lights produce? Can a light bar even create the same brightness?
  6. Aug 19, 2011 at 4:09 PM
    #46
    toughtaco
    Nothing too bright but definitely helps with reverse.
  7. Aug 19, 2011 at 4:26 PM
    #47
    UMBCrew
    UMBCrew Well-Known Member
    Nic
    Central Valley, CA
    05 6" Pro Comp Stage II
    6" Pro Comp Stage II, 305/65r17 Pro Comp Xtreme AT, Pro Comp 7033 17x9s, AFe Stage 2 Si, All-Pro Rear Bumper, Ultra-Guage, Kenwood KDC-X895, Kicker 6.5 2 ways
    yeah mine is that bright if not brighter. its hard for me to take a photo like that though cause there is nowhere around here with trees or anything for reference just open ground and since its aimed at the horizon to identify objects it doesnt properly show the distance.
  8. Aug 19, 2011 at 4:43 PM
    #48
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Not gonna lie...that's the coolest illumination add-on I've ever seen on a truck of any kind. So much so that I want one bad. However, at a price tag of $1,399 there's no fucking way I'll even consider it.
    This has me thinking about building my own. :D
  9. Aug 19, 2011 at 4:50 PM
    #49
    UMBCrew
    Nic
    Central Valley, CA
    thanks
    let me know how that turns out building your own thing. those companies put a ton of R&D into the lenses and reflectors in their light bars and is really the only difference between the different brands. the other main thing to consider is the control circuit for the light and being able to cool it sufficiently.
  10. Aug 19, 2011 at 4:55 PM
    #50
    prerunner32
    prerunner32 [OP] TRD
    Alan
    Foothill Ranch
    05 Prerunner TRD Sport Longbed
    285/70/17 BFG A/T's, 17in Method Double Standard Wheels, Camburg 2.5 Coilovers, Alpine Head Unit, Infinity Speakers, 10" JL Audio Sub, 2 Rockford Fosgate Amps, AFe Stage 2 Si (Oiled)
    This is exactly where I am thinking of doing a mount. Preferably a Rigid 30"... I wonder if it would fit? Do you have any pics from looking inside the truck?
  11. Aug 19, 2011 at 4:57 PM
    #51
    ItalynStylion
    Steven
    DFW, Tx.
    Yeah, the heat was my main concern. The lens really shouldn't be that bad to figure out. It all has to do with focal points of the lens. I learned the stuff in highschool physics forever ago. Now I'm wishing I could remember lol
    And I already found the LED's for cheap. Same ones too ;)
  12. Aug 19, 2011 at 5:05 PM
    #52
    UMBCrew
    Nic
    Central Valley, CA
    like of them lighting wise? no, go back a couple of post of mine, ill see if maybe i cant find a good spot over the weekend for you.
    but to help you out the way i mounted them was all i did was drill two holes @ 32" on center in a piece of flat iron bar and bolted that bar to the aluminum brace for the bumper which already had holes all the way thru it. then just drilled more holes in the flat bar to mount the light to.
  13. Aug 19, 2011 at 5:11 PM
    #53
    UMBCrew
    Nic
    Central Valley, CA
    oh and another note is that the bumper itself kinda blocks some of the light so if your looking at like the euro style bar where its spot in the middle and flood on the sides, im not sure how much actual flood youll get with it behind the grill. mine is all spot and it seems to block alot behind the grill even.
  14. Aug 19, 2011 at 5:21 PM
    #54
    UMBCrew
    Nic
    Central Valley, CA
    CREE's? im pretty sure thats what they all use. the lens on mine is like molded so that its a solid piece of plastic from the front all the way back to the led. its not just a cover. i think on the rigids it is mainly a cover and they use the rear reflector as their main concentration of light. as far as cooling their all basically fin cooled off of the rear like an air cooled engine. hope that helps.
  15. Aug 19, 2011 at 5:24 PM
    #55
    prerunner32
    Alan
    Foothill Ranch
    Yea the plan would be take that part of the grill off and just have the bar there. Have a really clean look. And that would be awesome to see some pics! thanks!
  16. Aug 19, 2011 at 5:51 PM
    #56
    UMBCrew
    Nic
    Central Valley, CA
    can i ask your reasoning for wanting lights, do you do a lot of night wheeling? for the price of the lights there are a lot better more effective uses for the money. like locker if you dont have one, sliders and other trail armor. if i had bought my truck before i bought my light i wouldnt have spent the money on it i would have regeared and put in a locker. just my two cents.
  17. Aug 19, 2011 at 6:14 PM
    #57
    toughtaco
    I need lights to see both on and off road. Especially when I am backing up at night, I have a anytime push button reverse camera with push button reverse lights that you can see in this thread. I use them more often then you think even when someone is tailgating me.....haha..... its effective. They are also fun to use when messing with friends......:D
  18. Aug 19, 2011 at 6:22 PM
    #58
    UMBCrew
    Nic
    Central Valley, CA
    i was actually asking OP but i want to do that too put some nice bright reverse lights on so i can mess with tailgaters. all LED light bars are technically illegal on road though. especially here in CA.
  19. Aug 19, 2011 at 6:25 PM
    #59
    toughtaco
    ^^^Sorry............
  20. Aug 19, 2011 at 6:26 PM
    #60
    toughtaco
    The most important thing about the legality of LED lights is the price!!!! I just priced 30" led light bars............. $1400.... Really!!!!
