LED Light Bars
Discussion in 'Lighting' started by ToyotaKTMracing, Oct 17, 2012.
  1. Mar 15, 2016 at 10:36 PM
    #2021
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    I just did this today cdd8ac9d5279402b1a59c4285c5a00d2_5542df439afe7cc7cbc45fa460d5010777f07773.jpg0d58d9d814d9bf3d608e4a4626c875c8_78e407bc600f0a47a01e0dcf0d60fdfe4951cfd7.jpg
    TN_Tacoma likes this.
  2. Mar 16, 2016 at 7:52 PM
    #2022
    kengulo
    kengulo Well-Known Member
    Ken
    SGV 626
    2015 TRD PRO DCSBSW 6SPD MT
    Used the switch it came with, don't have any place to add additional switches without cutting things up. Center heated seat switches too far and don't think it's the best location. Right on the steering wheel column is very accessible and doesn't block or interfere with any adjustments. Put a 30inch 5d bellow grill for better wide angle then plan to move my 30inch 4d bar to front roof rack and a single row 30inch 3d facing the rear on the rack as well with the switches most likely right next to the other one.
  3. Mar 22, 2016 at 9:59 PM
    #2023
    kengulo
    Ken
    SGV 626
    5d vs 4d bar will mount 4d behind upper grill or roof basket
  4. Mar 22, 2016 at 11:29 PM
    #2024
    JohnLin15
    JohnLin15 The Slower DC
    Johnny
    Alabama/Mississippi
    2015 MGM DCSB Prerunner
  5. Mar 23, 2016 at 4:08 AM
    #2025
    Fullmetalcheeto
    Fullmetalcheeto Well-Known Member
    Cheeto
    16 tacoma off road 4x4, 97 4runner 4x4, 05 Tacoma PrerunnerTRD, 89 Toyota 4x4 long travel prerunner, 93 Geo Metro
    Extensive
    Finally got a light bar. 50" radius dual row from LED warehouse. Under $300 and looks/ performs amazing. Will get some action shots when i get er out in the open to show the light output.
  6. Mar 23, 2016 at 9:05 PM
    #2026
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Random shots to keep it goin.
    This 4d with 10 watt leds has some crazy big projector lenses, heh. Looks funny from the side up close. Still not sure if I wanna put the 3d back in or not.. Not caring for the more intense beam not blending well with the other lights. Can't tell on roads. But turning or in close quarters it's way noticeable. Much more intense and whiter than my others.
  7. Mar 23, 2016 at 9:43 PM
    #2027
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    What mount is this?
  8. Mar 24, 2016 at 2:39 AM
    #2028
    Fullmetalcheeto
    Cheeto
    Extensive
    Had a local shop custom make me some to put it where i wanted it. If you are interested i can make contact, it looked like he made about a half dozen using my truck as mock up
  9. Mar 24, 2016 at 6:16 AM
    #2029
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
  10. Mar 24, 2016 at 9:14 AM
    #2030
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    Can you take some pics of the mounts an how they bolt on I take it you drilled them on
    Dhannah likes this.
  11. Mar 24, 2016 at 4:32 PM
    #2031
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    So I just picked up these 120W 7" Round Spot lights (10Wx12). You mostly see this design with only 60W (5Wx12)....but I happen to come across these for $134/pair with 10,200 lumens each..so why not. These were to replace my horrible Hella 700FF HID conversions. They might have been a decent idea 5 years ago...but the beam pattern was always horrible and the cheapo DDM ballast took a full minute to warm up. I was never happy with them.
    Any who these lights are bad ass. Just what I was looking for. I need something with a thinner profile than the Cannons to fit my grill guard. I have a 300W double row 32" Cree Spot light bar...which produces more of a Euro-beam in my opinion. So I was looking for a concentrated long range spot for long distance. The construction seems top notch and they are very heavy. The only negative comment I can say is the adjustment up and down doesn't have much fine tuning. It has this plastic gear/cog wheel. I wasn't able to set the vertical where I wanted, so I ended up putting some shims in the front to get them to aim up just were I wanted.
    http://www.ebay.com.au/itm/Pair-7In...ad-4WD-Lamp-/400743474724?hash=item5d4e2c2624
    Headlights and 32" LED Bar
    32" LED light bar and the new 120W x2 LED Spot light . Yes they completely over power the 300W 32" LED Bar.
    Headlights and the new 120W x2 LED Spot light . This after I optimized the aiming at a long distance. Bottom of the spot on top of the headlight beam and at a distance the gap in between completely closed and the spread is perfect at a distance. I will try to get some long range photos this weekend.
    I would love to see a side by side comparison with the Cannons everyone has
  12. Mar 24, 2016 at 11:02 PM
    #2032
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    This is what I'd like to know as well. Not much available for the access cab world since we don't have the same mounting holes up top like the double cabs.
  13. Mar 25, 2016 at 3:25 PM
    #2033
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Careful with this mod boys and girls. 3" flush mounts came out super clean. @Yotamac did the cutting. Takes a steady hand.
    Dhannah, EricU and Yotabilly like this.
  14. Mar 25, 2016 at 11:08 PM
    #2034
    Fullmetalcheeto
    Cheeto
    Extensive
    No bolting. We wanted to keep it as flush as possible to minimize obscuring the weather stripping on the door. You can see in the photos how little it is displaced by the bracket. We rivited them in place. Bonus is if we ever decide to take them out or relocate, the holes are minimal and easy to hide or patch. Here are a handful of snap shots i just took after driving 15 hours, sorry its dark if you need more in the light let me know. The brackets wrap tightly above the door pillar but have about 1/8- 1/16 of an inch clearance.
    And here is also how we ran the electrical...
  15. Apr 2, 2016 at 7:30 PM
    #2035
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    Did you use a tapered adapter between the light and bumper to "square up" the lights so they point directly back?
  16. Apr 2, 2016 at 8:53 PM
    #2036
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
    What is the difference between 5d, 4d 3 d
  17. Apr 2, 2016 at 8:59 PM
    #2037
    kengulo
    Ken
    SGV 626
    3d - led with reflector housing emitter, not as long distance/wide, can see emitter
    4d - led with projector type lense - focused long distance beam, more narrow not as much flood, looks dark when looking at bar when off
    5d - led with reflector and projector type lense - more flood lighting and distance whiter look to bar when off
    lights-30-inch-led-light-bar_70930-base-_9e81b369c117efd44abbd2fd983784f658e86e99.jpg
    4D-For-Philips-Curved-LED-font-b-Bar-b-f_bba2ed846b91c54a30d20b7ec141068570d21a2e.jpg
    CREE-5D-LED-Light-Bar-42-inch-400W-Offro_5aafe9536d98aeb2b6f5bb71ad6ce57193d2500a.jpg
    5d bar
    4d bar
    outxider, BenTheMan and Naveronski like this.
  18. Apr 2, 2016 at 9:18 PM
    #2038
    Gnarman
    Southwest
    Thank you!!
  19. Apr 12, 2016 at 3:02 AM
    #2039
    NightProwler
    Harlan
    Maricopa, Az
  20. May 13, 2016 at 5:37 AM
    #2040
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    can anybody tell me which brand this LED bar is? I like this look the best!
