LED Light Bars
Discussion in 'Lighting' started by ToyotaKTMracing, Oct 17, 2012.
  1. May 20, 2018 at 12:20 PM
    #2181
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    Hey guys here is another option for a light bar. The company is called XKglow and makes a solid light setup.
    http://www.xkglow.com/27inch_120W_LED_Light_Bar_18_000_L_Spot_Flood_p/xk061120.htm
    Specs:
    Luminous: 18,000Lm
    •Light Bar Size: 26.75" length X 3.13" height X 3" width
    •LED brand: CREE
    •Beam Type: Spot and Flood COMBO light
    •Flood LED casts 30 degree angle
    •Spot LED casts 10 degree angle
    •Light Bar contains (6 Flood and 6 Spot) 10W per LED
    •Operation Temp: -40°C-150°C
    •Operating Voltage: 9-35V DC
    •Waterproof grade: IP 68
    •Color Temperature: 6000K
    •Material: die cast aluminum housing
    •PolyCarbonite Lens
    •Life Span: 50,000 hours
    -RJM
  2. May 20, 2018 at 10:11 PM
    #2182
    knifer
    knifer Well-Known Member
    Yellowknife,NT
    2013 Spruce Mica TRD SPORT
  3. May 21, 2018 at 7:53 AM
    #2183
    Loco38SUP
    North Seattle, WA
  4. May 21, 2018 at 4:49 PM
    #2184
    BellyUpFish
    BellyUpFish Well-Known Member
    What light bar is that?
  5. May 22, 2018 at 8:06 PM
    #2185
    Loco38SUP
    North Seattle, WA
    Finally got a chance to take some night pics.
    -RJM
  6. May 23, 2018 at 1:11 AM
    #2186
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Liked the reflection in the hood. oooh shiny!
  7. May 23, 2018 at 6:31 AM
    #2187
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Looks like a lot of wasted light on the ground. Would throw even better at a higher mounting.
    Aws123 likes this.
  8. May 23, 2018 at 8:02 AM
    #2188
    Loco38SUP
    North Seattle, WA
    I agree, thats why I wonder about the lower grill insert mount. At that height so much light is wasted. If there was a cab mount I liked that would have been my preferred choice.
    - RJM
  9. May 23, 2018 at 9:13 AM
    #2189
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    10w bars ftw!! For a single light bar that generally gives you the most usable light for your money that is. The spread on that one is pretty impressive and im sure better in person. We're probly not seeing a lot of that spill on camera.. Still wanna get one of these types to compare it to mine to see if they perform any better. Seems like they have slightly larger reflectors. Similar to that of BD's. Their longer bars get up there in price tho.. And looks like they use fluted cups/reflectors (instead of lenses) for their flood optics.. :puke:
  10. May 25, 2018 at 3:20 PM
    #2190
    Heffery5000
    Heffery5000 Well-Known Member
    Jeff
    Haverhill, MA
    2014 tacoma trd offroad access cab blue ribbon metallic
    Urd short shifter Changed out grill Method wheels
    Its a 30" dual row from Auxbeam. Theyre kind of a budget company but have some friends whove had goodluck with them so figured id give it a shot. Works great no moisture as of yet
  11. Jun 1, 2018 at 10:40 PM
    #2191
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    what is everyone running for 32" combos?
  12. Jun 7, 2018 at 7:55 AM
    #2192
    Loco38SUP
    North Seattle, WA
    Anyone else think that curved light bars look like they are sagging when mounted on the cab?
    For some reason they don’t look right to me!
    -RJM
  13. Jun 13, 2018 at 9:49 PM
    #2193
    Mxmili
    Mxmili Well-Known Member
    Max
    Philadelphia
    2011 base 4x4 2.7l
    Bilstein 5100s at 0 Ome 883
    Installed both light bars and fogs on my base, mounted behind the lower bumper, give off a significant amount more light, used an aluminum angle and just drilled and tapped the legs that came with the lights right into the crash bar, worked out great. Didn’t even remove the bumper. Both are from Amazon.
    Nilight LED Light Bar 2PC 7Inch 36W Spot LED Work Light Off Road Led Bar 12v Driving Lights Super Bright for Jeep Cabin Boat SUV Truck ATVs,2 Years Warranty https://www.amazon.com/dp/B01M2D4S7E/ref=cm_sw_r_cp_api_i_KnFiBb7MCX1ZY
    3EBF99BA-6896-4FA6-967C-2F48B6413D58.jpg 97D92EC0-62ED-4AA9-8A59-3EACED2EC80E.jpg
  14. Oct 25, 2020 at 10:10 PM
    #2194
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Just finished installing my somewhat stealthy setup on my TRD Sport, which is:
    Baja Designs Squadron R SAE Amber Fog Lights
    Rough Country 12" Single Row Light Bar (in hood scoop)
    Rough Country 20" Black Series Single Row Light Bar (in Pelfreybilt bumper)
    18,000 lumens total
    I'm very happy with the light output, as well as the look. I'm not excited about chrome, so the black series is exactly what I was looking for, as well as hiding a light bar in the hood scoop, so everything is nice and tidy.
    The 12" Rough Country light bar has been installed in the hood scoop for 5 years now, and it's held up and performs flawlessly. But to be honest, I'd probably skip it next time, as it doesn't really add much to the overall brightness on the road. This probably has to do with the fact that it's sitting behind the mesh, but damnit I hate the look of chrome lights, and I want it to look hidden, so whatever.
    I was originally skeptical about the 30 degree spot beam not being wide enough for spotting wild game on rural roads at night (this is how I wound up with the steel plate bumper purchased 50% by the insurance company after I hit a deer at night and smashed my OEM bumper). But, with this combo, I get plenty of light in the ditches and sides of the road to spot any critter a long ways away.
    japjoe7 and Lelandt like this.
  15. Oct 25, 2020 at 10:33 PM
    #2195
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Rigid 50" Hyper Spot and Flood combo top.
    Rigid D2 Driving for ditch lights, probably going to replace these with side shooters.
    Rigid SAE fogs with amber covers.
  16. Nov 29, 2020 at 4:53 PM
    #2196
    ISU800m
    ISU800m "Worst case Ontario"
    Kyle
    Plymouth, MA
    2018 Silver TRD OR
    I currently have a 40" Cali Raised light bar mounted in the Prinsu and a 30" Cali Raised amber mounted between the bumper and the grille. These lights have never let me down, and for the price are pretty bright. However, they have some serious condensation problems going on. I am looking at Baja X6s for the Prinsu and Heretic for the bumper. Is the baja worth the $1400? Is Heretic any good? I want to buy lights once more and never buy them again, just cant quite figure it out!
  17. Nov 30, 2020 at 10:55 AM
    #2197
    Thunder chicken
    Thunder chicken Well-Known Member
    NW Ontario
    ‘18 access cab manual
    We have these locally and people seem to like them. The retail store owner says in the 7-8 years he’s been selling them he’s only had a few come back for warranty and mostly abuse damage but the company honoured it anyways
    I just got a 30” curved but haven’t got it installed yet (brackets in the mail...)
    https://speeddemonlights.ca/
  18. Jan 23, 2022 at 5:56 AM
    #2198
    gregnauman
    gregnauman Well-Known Member
    Greg
    2020 Tacoma TRD Pro
    None
    I was able to get a Rigid SR20 Midnight edition for $430 so decided to go rigid with the lifetime warranty. Should look good on the TRD Pro with SSO bumper
  19. Feb 19, 2022 at 9:01 PM
    #2199
    13yota
    13yota Well-Known Member
    Colorado
    2013 2.7 single cab 4x4
    As anyone mounted their lightbar to a tall topper, as opposed to right above the windshield, and have pics/review? Or any other lightbar mounts other than CaliRaised for the windshield? Or put a 50in+ lightbar on their front bumper?
    Amazon accidentally mailed me a 52in curved lightbar and pods instead of crossbars, and didn’t want it returned. Trying to decide if I wanted to use it or sell.
  20. May 25, 2022 at 4:16 AM
    #2200
    Jrunr619
    Jrunr619 Well-Known Member
    You should post picture of this light bar in action!
