LED Light Bars
Discussion in 'Lighting' started by ToyotaKTMracing, Oct 17, 2012.
  1. May 5, 2014 at 3:21 AM
    #1361
    FMF
    FMF Well-Known Member
    Topher
    Chicago Illinois
    2013 4x4 TRD OffRoad
    SUSPENSION ARB Old Man Emu BP-51 OME Internal Bypass coil overs and rear shocks Suspension ARB Dakar one ton Rear Hi-Lux Leafs EL091 U Bolt Flip Kit Firestone Ride-Rite Air Helper Spring Daystar Universal Air Bag Cradle Wheelers Front Super Bump Stops SPC Performance Adjustable Front Upper Control Arms All-Pro 4" Steel Braided Brake Lines EBC Green Stuff Brake Pads WHEELS TIRES TRD 16-in Off-Road Beadlock-Style Alloy Wheels Bronze BFGoodrich Mud-Terrain KM2 255/85R16 with matching full size spare. ARMOR ARB Deluxe Bull Bar with Quadratec Q9500is Winch with Dyneema Synthetic Rope B.A.M.F Kick Out Rock Sliders PERFORMANCE ARB Safari Snorkel TRD Performance Exhaust System INTERIOR Clazzio Leather Seat Covers LIGHTING ARB IPF 900XS Extreme Driving Lights Rigid Industries Dually Flood Lights All interior lighting swapped to LED's AUDIO Front Doors: Rokford Fosgate p1694 6x9 Rokford Fosgate Tweeter P1T-s Back Doors: Rokford Fosgate P16 6 ½ OTHER Custom Martin Truck Bodies Aluminum Flatbed Weather Tech Window Rain Deflectors Bird Dawg Tech Extreme Deck Gadget Mount PrinSu Design Aluminum Roof Rack T6 Aluminum Devil Horn Toyota Emblem Ceramic Window Tint Bushwacker fender flares
    Here is a shot of my 52" LED bar.
  2. May 5, 2014 at 6:10 AM
    #1362
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    10' PRO-4X CC, modded..
    Too long to list :D
    What What! Chris in da house :D
  3. May 6, 2014 at 4:55 AM
    #1363
    teamjm
    teamjm Active Member
    Philippines
    2010 3.0 D4-D Toyota Hilux
    Shackel Spacer Rims Tires Bilstein
    Hi guys,
    This is John from the philippines.
    Here's my Hilux 4*4 3.0 diesel
    with 2 pcs of double row 42 inches :)
  4. May 14, 2014 at 10:02 AM
    #1364
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    How are you guys running the power cable for roof mounted light bars? Obviously some of the wiring has to get into the cab somewhere... :confused:
  5. May 14, 2014 at 10:16 AM
    #1365
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    I drilled a hole into the water channel under the weather stripping, ran it down the door jam into the engine bay. Then from there if u need it in the cab to a toggle switch go through the firewall.. I'll post a pic when I get a chance, of that hole I drilled.
  6. May 14, 2014 at 2:32 PM
    #1366
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    Too long to list :D
    I used to have the cable tucked along the outside edge of the windshield, but now I drilled a hole through my factory XM antenna cover (Nissan) since there is a factory drilled and sealed 3/4" hole in the roof right under the cover :)
  7. May 14, 2014 at 2:39 PM
    #1367
    Sheepdog
    Sheepdog Well-Known Member
    Gary
    San Diego, CA
    Black 2002 Tacoma Xtra Cab, 4x4, TRD, SR5
    Eibach/Bilsteins, Beefed shackles, Bushwacker Cut-Outs, Custom roll bar, TG Sliders, Elite Front Bumper, XRC8 Winch
    I want to see a picture of the little LEDs on. the ones you mounted on the ends... Are you running blue and red??? :spy:
  8. May 14, 2014 at 5:22 PM
    #1368
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    Too long to list :D
    Was Amber. I had them for 6 months before I took them off so I could fit some covers on the lights. Still have the wiring harness yucked inside the fins on the LED bar so I can put them back up sometime..
    This is the only decent pic I have, never really took pictures of them on.
    That's a long exposure so they weren't actually that bright. They were about as bright as a normal amber side shine strip.
    http://www.tacomaworld.com/forum/lighting/244444-led-light-bars-67.html#post8555594
  9. May 14, 2014 at 5:41 PM
    #1369
    NightProwler
    Harlan
    Maricopa, Az
    :spy:
    Fyi, we discussed this on page 66&67 too.
    Check it out;)
    I think ima take mine off.. Not liking the quality of the them. Some leds are dim. And one end is coming unstuck a little. I may try to find some better quality strips, but can't find any that are super long like 42", the length of my bar, and of good quality,not eBay crap...
    Anyone have any suggestions for a good roll I can purchase? In amber only of course..
  10. May 14, 2014 at 6:39 PM
    #1370
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
  11. May 14, 2014 at 8:25 PM
    #1371
    Sheepdog
    Gary
    San Diego, CA
    I like it! You should do red and blue if you rewire them. Zombie response, right?
    Sorry about that, bud. I tried to make sure it wasn't discussed yet but I was looking for the pictures to be quoted rather than just txt. Do you have a writeup on your rig? specifically the headlights? I did a retro with the very same housings but I swapped out the white LEDs in the bottom for orange and made them my turn indicators. I really like the double halos you have though! Makes a really cool effect!
  12. May 14, 2014 at 9:08 PM
    #1372
    NightProwler
    Harlan
    Maricopa, Az
    Heh, no it's cool I just wanted u to see mine;)
    And not really the right thread to discuss this topic but wth why not...
    Yeah I still have yet to start working on my new retro with all new (same) housings and newer projectors. Had a lot of problems with them. I didn't really know exactly how to swap the leds but I actually was looking at the 5mm leds today for ideas on other applications. Just not sure how to wire them up yet but I'll research that. Not sure I want to change them. I kinda wanna remove them. I have crazy bright led eagle eye bolts I custom installed into the headlight filler panels. Waaaaaaay brighter than anything else I've seen so far for led turn signals. Was gonna see if I could fit them into that same holes where the 5mm's go but I don't think they will without drilling or hacking it up. I am afraid it'll turn out like shit. And those housings aren't cheap. I've bought 3 so far. 1 as halogen replacements, 1 for my current retro(when I discovered what a retro was:), and my new ones for a 2nd retro. Ha. Hoping this one goes without a hitch. Anyways there's this, but not much of a write-up. http://www.hidplanet.com/forums/showthread.php?50430-2001-Tacoma I thought ibwas a badass at the time. Lol. I was such a noob. Learned a lot since then and I'm confident as I really know what I'm doing this time. 1st times always like a 'trial' set just like everyone says. Ha.
    But I may do a write-up for my new set whenever I get to it... Still thinking up exactly what I want to do, make changes this time around and whatnot.
    Oh and I actually have tripple halos. I had white ones inside the shroud to shine through the port holes. But they kept burning up or something and I kept replacing them (under warranty). So I just unplugged them and said fuck it this time, NOT gonna split them a 4th time..
  13. May 14, 2014 at 9:09 PM
    #1373
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    Too long to list :D
    The ones I had were fine, but I did have 1 LED burn out where the silicone split. But you will be hard pressed to find Amber side shines from a good company. Fwiw my amber strips have been in my foot wells ever since and they have been hding strong!
    Cannot, fully illegal :( But it's okay, orange is my color! And my zombie response lights are amber and white just how I like it :)
  14. May 14, 2014 at 9:27 PM
    #1374
    NightProwler
    Harlan
    Maricopa, Az
    Yeah there's not much out there for side emitting.. I was trying to think of a way to use those 5mm's somehow. But I don't see how I could. Idk I don't really wanna put much time and effort into this.. oh well..
    And I agree. Amber and white ftw!
    Oh and on a side note, I got pulled over last night. While I was running my lights on a desolate road. Cop didn't care at all about my lights he said (funny cuz I had to've blinded him)... But yeah, I was speeding:rolleyes: He let me go tho:D
  15. May 14, 2014 at 9:41 PM
    #1375
    Sheepdog
    Gary
    San Diego, CA
    I know that's illegal, dude... But who cares when SHTF and the zombies come.
  16. May 14, 2014 at 9:57 PM
    #1376
    NightProwler
    Harlan
    Maricopa, Az
    Lol. Just put some metal spikes on that plate bumper of yers. Or some spike lug nuts. That would be sum shit! Heh.
  17. May 14, 2014 at 10:47 PM
    #1377
    NightProwler
    Harlan
    Maricopa, Az
    Here we go:)
    This is something I was thinking of doing actually:D
    2nd pic is pretty sweet I think...
  18. May 14, 2014 at 10:50 PM
    #1378
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
  19. May 14, 2014 at 11:04 PM
    #1379
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    HAHA :rofl:Thats what I thought too.
  20. May 14, 2014 at 11:09 PM
    #1380
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    Too long to list :D
    That would be cool, but until the SHTF I gotta keep it legal. It's illegal for me to even have them mounted to the car, even if they aren't on.
    And I assume us police applicants will be under extra scrutiny :p
