LED Light Bars
Discussion in 'Lighting' started by ToyotaKTMracing, Oct 17, 2012.
  1. Jan 7, 2015 at 10:53 PM
    #1661
    skygear
    skygear                    
    How many can you control..
    I already have 5 bars.
  2. Jan 7, 2015 at 11:09 PM
    #1662
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Well these are new bars I believe that have Bluetooth built into the bar itself. And I doubt you can control multiple bars. Maybe in the near future after this tech is common on bars they'll release software that'll support multiple connections. Would be my guess anyways. Looks promising though. But means that if you want it, you'll have to replace all your bars with ones that have it built in. Maybe they'll come out with a separate controller harness that can be wired in to ones that don't have it. Fingers crossed anyways. Till then, I'll be looking into a wireless remote. But again, not sure if it will control all my lights. Seeing as I also have multiple lights and would like to use the remote to power all of them at once.
  3. Jan 7, 2015 at 11:17 PM
    #1663
    skygear
    skygear                    
    For sure. I understood that. Was more thinking if it was Bluetooth 4.0, you could create a PAN (personal area network) and control them all in that manner. The tech is new to the bars, not new in general. Some devices have issues with generic bluetooth radios too. Like the Samsung product. Also Certain Android versions and IOS versions.
  4. Jan 8, 2015 at 1:09 PM
    #1664
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    A little over 18k lumens for a 51" double row doesn't seem that impressive. Especially not for the high price tag that is likely on that thing, bluetooth or not...
  5. Jan 8, 2015 at 1:24 PM
    #1665
    NightProwler
    Harlan
    Maricopa, Az
    Yeah I wasn't interested in those bars at all. just the fact that they have bluteooth I thought was awesome. I'm sure there'll be more implementing this to their bars before too long. Not sure how practical it'll be, seeing as you would have to pull out your phone all the time, open the app, then switch them on. But would be good if you use them for work lights. Or at parties or something showing off the strobes and stuff. Or just to scare people. lol. I like the idea of the wireless remote better. And even more so having them hooked up to my high beam switch. So yeah now that I've thought about it, don't think I'd like it myself. Certainly would not replace my bars just to have Bluetooth capability. Maybe if they had a plug in harness/controller for my current bars then I'd consider it. But I thought some might like it/could use it.
  6. Jan 8, 2015 at 1:37 PM
    #1666
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    There are actually some Bluetooth enabled relay boards that can be operated via Android OS. the wifi versions can be controlled IOS or Android. the ones i have seen are not a fully done package for retail. you would have to make your own enclosure and wiring harnesses.
    I did see one that could control two led strips that was a finished product. im sure it could be modified to control relays easily.
  7. Jan 8, 2015 at 2:24 PM
    #1667
    NightProwler
    Harlan
    Maricopa, Az
    Hmm.. I've also been wondering if I can tap a relay from my alarm into my light bars. For when I activate and deactivate alarm or remote start. Because my dtrls flash a few times when I do and would like to have the led bars flash as well. Think that'd be a cool mod. But it may not work, especially with remote start since the running lights stay on until you put the key in and press the brake to deactivate the remote start timer. Hmmmmm..
  8. Jan 8, 2015 at 2:39 PM
    #1668
    NightProwler
    Harlan
    Maricopa, Az
    So how would one use something like that controller or for my alarm, to tap into the relay? Would you run a wire and tap into the activation pin on the relay that powers the led bars?
  9. Jan 8, 2015 at 4:15 PM
    #1669
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    without taking this too far off topic, most alarms nowadays just pulse the output to the parking lights circuit a few times before it powers is steady on. I think
    with that controller, all you need to do is connect relay pins 85 and 86 to the controller v+ & O1(-) if you just want the controller to activate the relay and nothing else.
    if you are adding the controller to an existing switched relay circuit... you would need to incorporate a diode on the positive wire to 86. ths will stop power feeding back to the controller when using a manual switch.
  10. Jan 8, 2015 at 4:50 PM
    #1670
    NightProwler
    Harlan
    Maricopa, Az
    Cool thx man. I'll be looking into this:D
  11. Jan 8, 2015 at 8:25 PM
    #1671
    NightProwler
    Harlan
    Maricopa, Az
    Hellz yeah!! Just got my 4.5" skylighter led light cannons from chas. Tested them real quick and holy crap are these things bright!!!! The throw is pretty insane. And very nice quality. Heavy duty mounts! Can't wait to get them installed. Just waiting for my cbi ditch light brackets to come!
  12. Jan 8, 2015 at 10:29 PM
    #1672
    skygear
    skygear                    
    5 pin relay too. make use of that 87a.
    pac7 could be useful also. there are plenty of possibilities.
    What alarm do you have>? Most Viper/ DEI products have plenty of accessory in and out for other triggers. The 59xx versions with the lcd remotes have plenty of trigger points
  13. Jan 8, 2015 at 10:38 PM
    #1673
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    how are you purposing pin 87a to be used?
  14. Jan 8, 2015 at 11:07 PM
    #1674
    skygear
    skygear                    
    Nope, your right. Jumped the gun. I was looking at one of the diagrams and it was setup for a fan using 2 relays. SPST & SPDT.
  15. Jan 8, 2015 at 11:44 PM
    #1675
    DirtRoadRider
    DirtRoadRider Member
    07 prerunner SR5
    Where are you mounting these toendanger?
  16. Jan 8, 2015 at 11:51 PM
    #1676
    NightProwler
    Harlan
    Maricopa, Az
    ...On the ditch light brackets from cbi;)
  17. Jan 9, 2015 at 12:24 AM
    #1677
    NightProwler
    Harlan
    Maricopa, Az
    It's an older avital system. Don't remember what model or anything off the top of my head. I have a downloaded manual somewheres. Have no clue about alarm systems. It was previously installed. I figured I would just use a test light and find the wire that flashes and try tapping into that. Won't get to this for a while. Just wondered if it would actually be possible. I'm sure there is a way using the right harness and relays to complete the circuit. I'lllook into it later though, when I find the time and patience to delve into it all:)
  18. Jan 9, 2015 at 1:19 AM
    #1678
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    Man I'm really digging the lightbars on the roof.
  19. Jan 9, 2015 at 4:02 PM
    #1679
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Our Onx6 would be a great addition to the roof of your Tacoma!
    The 40" Driving/Combo LED features an impressive 25,800 Lumens.
    http://www.bajadesigns.com/ProductDetail?ItemNumber=454003
    The OnX6™ LED light bar also integrates Baja Designs’ trademarked High Speed Spot™ reflector, the same one used by our Team Enlightened racers, to give you the guaranteed furthest projecting LED Light Bar on the planet.
    Add in MoistureBlock technology, A 30 Day Satisfaction Guarantee, and Limited Lifetime Warranty You'll be set for all of your outdoor adventures!
    Give us a call and I'll be happy to find you the light that suits your needs!​
  20. Jan 9, 2015 at 8:09 PM
    #1680
    NightProwler
    Harlan
    Maricopa, Az
