led light swap in stock fog light location mod
Discussion in 'Lighting' started by Raxman80, Jun 22, 2014.
  1. Jun 22, 2014 at 8:51 PM
    Raxman80
    Raxman80 [OP] Well-Known Member
    Ray
    Downey ca
    08 4X4 DC SB TRD Off Road
    2.5 king coilovers and 2.5 king adj rr rears. King bumps. total chaos UCA Deaver 3 leaf add. K&N cold air. flowmaster. Chase rack. Leds everywhere General Grabber X3
    hello. i found some led lights that fit in the factory fog light hole on my 08 taco. it does not require a lot of modding. the led lights are 5,100 lumen each.
    here are the the specs
    Beam Type: Spot / Flood
    weight: 1 lb
    Amp draw (14V): 4.35
    LED Module: 6x10 CREE
    Lumens (LM): 5,100
    if anyone interested in a set of these hit me up.
    flood or spot available
    65.00 each
    120.00 for a pair
    5.00 each for shipping
    8.00 for a pair if shipped
    here are some in stall pics.
    this is how the light comes
    the factory bottom mount needs to be cut off and ground smooth to fit in the factory fog light hole.
    this is how it mounts up in the factory location. the led light has four 10/32 threaded holes on the back. i used some flat plate to secure it. miner trimming on the inside of the fog light hole. it wont be seen or prevent the factory fog light from being reinstalled. i wired them to the factory fog light switch.
    new led light vs factory fog light.
    10,200 lumen of fog light :)
  2. Jun 22, 2014 at 11:11 PM
    SteveoATC
    SteveoATC Well-Known Member
    San Diego, CA
    2012 off road DC/SB
    OME 885 coils with Dakar leafs in back, 17" XD Addicts, 33" Hankook Dynapros, BAMF bolt on sliders with kickout
    Seems too bright to be street legal!
  3. Jun 23, 2014 at 6:02 AM
    Raxman80
    Ray
    Downey ca
    Yes way to bright to be street legal. Off road use only.
  4. Jun 25, 2014 at 3:45 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    What's the output look like against a wall parked 20ft away?
  5. Jun 25, 2014 at 9:33 PM
    Raxman80
    Ray
    Downey ca
    I'll try to get u pics tomorrow.
  6. Jun 26, 2014 at 9:06 PM
    Raxman80
    Ray
    Downey ca
    Here u go
  7. Jun 26, 2014 at 10:07 PM
    SteveoATC
    San Diego, CA
    2012 off road DC/SB
    Those are just the fogs??
  8. Jun 27, 2014 at 10:51 AM
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Yea because if they were headlights you would see light on the wide side of the center beam
  9. Jun 27, 2014 at 5:46 PM
    kubatcha
    kubatcha Well-Known Member
    Could you post a picture of how they shine on the road?
  10. Jun 27, 2014 at 8:36 PM
    Raxman80
    Ray
    Downey ca
    The only pic I have
    [​IMG][/URL]
