Led light wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by White lightning boosted, Jan 5, 2018.
  1. Jan 5, 2018 at 6:57 AM
    White lightning boosted [OP] Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm hoping to wire some run-d led Amber cube lights tapped from the factory amber running lights. My goal was keeping them independent from the bright led headlights in the event of dense fog. If they are led should the factory wiring and fuse support this safely? Feedback appreciated.
  2. Jan 5, 2018 at 7:33 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I Ran my amber pods in my fog light spot by using an add a fuse into the Radio slot..then ran to my Switch then a relay and finally to my pods.
    When key is on... my switch has power.
    Then i can run my pods in any combination I choose.
  3. Jan 5, 2018 at 7:40 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Can you turn off your running lights while your headlights are on? I don't think so.
    Led use less current than other lights but it depends on the specs of the lights.
  4. Jan 5, 2018 at 8:43 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I think they are a total of 70 watts for the pair. Was just trying to keep it simple if I could. Fewer switches in the cockpit too. Thanks!
