LED Lightbar Backlighting DIY
Discussion in 'Lighting' started by MTopp, Oct 14, 2014.
  1. Oct 17, 2014 at 1:09 PM
    #81
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Are there any led strips that don't show the yellow leds ?
  2. Oct 17, 2014 at 1:09 PM
    #82
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    the same way you did your bar.. and I plan on doing mine. laying the strip either in the inside of the plexi.. or just on the inside of the black bezel.. on the outside of the plexi.
  3. Oct 17, 2014 at 1:11 PM
    #83
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    the strips will look like this..
    I think you're thinking of Halos.. and that depends on what type of Led/halo you go with..
    #83
  4. Oct 17, 2014 at 1:13 PM
    #84
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    no, I mean led strips. Like you can only see a white strip when off
  5. Oct 17, 2014 at 1:14 PM
    #85
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    the pic posted is what they are gonna look like. thats as "white" as you're gonna get.
    unless you coat them with something.. but then that will take away from the LEDs themselves obviously.
    I know TRS has their coated halos that actually look REALLY nice and clean (white full circle) then light up.. but.. they are only in solid colors.. and only halos.
  6. Oct 17, 2014 at 1:21 PM
    #86
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I think they are like water proof led strips
  7. Oct 17, 2014 at 1:26 PM
    #87
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    no, the waterproof strips look just like the pic above..
  8. Oct 17, 2014 at 1:48 PM
    #88
    MTopp
    MTopp [OP] Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Yeah, and actually for that specific thing, you can use some rgb l connectors
  9. Oct 17, 2014 at 1:59 PM
    #89
    MTopp
    05 SR5 4x4
    #89
  10. Oct 17, 2014 at 2:37 PM
    #90
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    I'm going to give my $.02 about the led strips mentioned so y'all know before you buy. I have a set of the super night 5050 that I used for my light whip and I have to say that the light output is great but the connector adaptor that goes from the module to the light strip is very fragile. I broke it after the first 2 plug-ins and had to be creative to fix it but I much rather it after I modified it. Also the sensor is line of sight so I you plan on using it for the light bars then you'll have to be outside and point the remote directly at the sensor. I again modified that to put a sensor inside the cab as well as in the bed of my truck for different instances.IMG_6012_zpsad414c01_d8ddd3c74e19bc1f15862f05e6c279a4f26e62ef.jpg
    Great work on the light bars by the way. I have 5 and they're all sealed but I wish I could do this.
  11. Oct 17, 2014 at 2:59 PM
    #91
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this is because you are using an IR remote.. RF remotes (the ones Myself and MTopp are using) wont have this issue.
    as far as the connectors, thanks for the heads up. I plan in making my own male/female connectors anyways, as I will have a slightly more complex setup, that will need some regardless, So I plan on just making them all on my own.
  12. Oct 17, 2014 at 3:21 PM
    #92
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    #92
  13. Oct 17, 2014 at 3:25 PM
    #93
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    Right on RF and IR. I just skimmed the ebay page that was linked here and seen it was really close to what I bought and wanted to give a heads up to anyone who would be attempting this and be disappointed later on.
    #93
  14. Oct 17, 2014 at 4:41 PM
    #94
    MTopp
    05 SR5 4x4
    Yeah, but I don't think the strip will bend at 90°
  15. Oct 17, 2014 at 4:44 PM
    #95
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    i would be going around the inside edge of the housing.. so perpendicular to the plexi. but.. even then it might be a tight bend.. so i would use those RGB connectors, or just that sellers product.. wouldnt match the rest of the RGB strips.. but atleast it would be done.
  16. Oct 17, 2014 at 5:44 PM
    #96
    MTopp
    05 SR5 4x4
    Ohh alright. Where'd you see those cubes with LEDs around the edge installed? Link?
  17. Oct 17, 2014 at 6:06 PM
    #97
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  18. Oct 17, 2014 at 6:53 PM
    #98
    MTopp
    05 SR5 4x4
    Yeah, cool. Let me know what yours look like when you make them. I may just run two separate strips on top and bottom if I was gonna do that
  19. Oct 17, 2014 at 7:19 PM
    #99
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    for sure. That's what I was thinking of doing for my roof bar before I found your thread lol
  20. Oct 18, 2014 at 1:54 PM
    #100
    MTopp
    05 SR5 4x4
    Based off my shaved down edge idea, I am going to squeeze in one extra LED strip into the lightbar.
    Those extra strips will be on both sides
