LED Lightbar comparison shots.
Discussion in 'Lighting' started by atvlifestyle, Oct 12, 2014.
  1. Oct 12, 2014 at 4:43 PM
    atvlifestyle
    atvlifestyle [OP] Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    I have been interested in LED light for awhile and have a pretty decent variety. A friend did a writeup of lights on 3 of my toys and a few other lights I had in my garage. Anyhow here it is:
    Allright here is a quick writeup on some led's. Most of these are led cubes and full light bars, we will give as much info as possible about each pictured. A disclaimer that although these are pretty good representations that not all factors were 100% the same. There were different lights mounted on 3 different vehicles at different lift heights as well as minor ground and mounting/aiming differences, but you get the idea. There are some trees as well as a gentle hill with trees in the far background for reference points. The main points to watch are the tree, the hill, and the back row of trees .
    First the vehicles and the basic lights we will be lighting up with.
    2004 WJ Limited with 2.5" lift ( this is also the one used for the stock light reference point as it had the best looking stock lights ( least amount of fogging and such,) as well as the least amount of lift making them the most "stock" lights among the test group)
    the lights are as follows
    stock headlights ( for a base reference distance/color)
    the center bar is a Blitzpro 15D 3 watt LED
    and the cubes on the sides are Blitzpro 6D 3 watt LED
    next is a 2002 WJ Overland with 6" lift and has the following lights tested
    the main led bar is a Lampus 10" Spot bar
    the small cubes below the bumper are Hanma 4 watt LED Flood cubes
    the last vehicle is a 2001 tacoma and has lots of lights.
    the lower bar is a Hanma 20" 3 watt LED dual row combo beam bar.
    the roof mounted bar is a Hanma 40" 10 watt LED spot bar
    the rear high mount cubes are Hanma 4 watt LED spot cubes.
    and the lower rear single row are Blitzpro 6lz 1 watt LED flood.
    as well as a 6led 3watt ea cube spot pattern
    6led 3watt ea single row with a flood pattern
    and now on to the comparison shots!
    we will start with the stock low beams on the wj as this is about the focal point of the majority of the lights is a bit fuzzy, but you get the idea.
    I believe this was: Blitzpro 15D and both 6D's
    all with headlights
    Blitzpro 6D cubes only
    the single row flood. and remmber that this is a SINGLE light, not a pair!
    the single row flood again
    here is the single 6led cube. again this is a single light! ( and it lit up the branch hanging a bit making it a little harder to see that it cast light a bit further up the hill. ( can even see some of the back row of trees)) this alone seemed to be about one of the best bang for the buck lights.
    all on on the offroad wj
    just the lower 4led cubes in flood pattern
    just the main bar
    and now for the bright one! this rig is set up for silver lake at night
    the main lower
    the upper long range ( looks a bit different but the angle from the hight is part of it, the other part after looking at the pics closer is the grass being lit up and looking greener were the main part of the beam is hitting.
    a little different angle from hood high to show the distance better
    both upper and lower front bars
    the rear low bumper mount 6led bar with the 1watt leds
    upper 4led high mount
    another angle
    same lights with yellow covers ( for like fog )
    and the high and low together
    same shot with the cover on the upper light
