LED Lighting Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chan2565, Jun 14, 2016.
  1. May 31, 2018 at 9:15 AM
    #2861
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    It was sarcasm.... But really all this shit is an overload of the lighting senses.....
  2. May 31, 2018 at 10:52 AM
    #2862
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    I currently have the Xenon Depot H11 HIDs in my low beams. Going to put the the Xenon Depot LED's in my high beams eventually. Why wouldn't I just go with the H9's then? Why are you using the H11's in your high beams also? Aren't the tabs a little different between the H11 and H9?
    RobP62[QUOTED] likes this.
  3. May 31, 2018 at 11:01 AM
    #2863
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    H11 and H9 use the same mounting hole/socket and connectors.
    The differences are "basically a matter of different filament with different characteristics. The H9 has a 65w (nominal) filament optimized for maximum luminance and flux at the expense of shorter lifespan. The H11 has a 55w (nominal) filament optimized for long life at the expense of lower luminance and flux."
    EDIT: I'm not sure if or how LED bulb makers are differentiating from H9 or H11. I know the Hikari was listed the same bulb for both H9 and H11...
    bobrown14 and RobP62 like this.
  4. May 31, 2018 at 11:11 AM
    #2864
    XenonDepot
    XenonDepot Well-Known Member Vendor
    @rickm - Our H9 and H11 LED kits are the same. @ToyoDrew 's response above regarding the differences between the two halogen bulbs is spot on!
    @ToyoDrew - Our H8, H9, H11, & H16 all share the same base.
    Parker315 and ToyoDrew like this.
  5. May 31, 2018 at 11:12 AM
    #2865
    TACO ALVY_24
    TACO ALVY_24 Taco Alvy - Dark Knight Edition
    Dan
    VA
    2017 Tacoma TRD Sport
    Extremely helpful!! Thank you @RobP62 .
    I found that knob last night and tried turning it (Drivers side) turned about 2 fulls turns and didnt notice any light adjustment. I will try again tonight.
  6. May 31, 2018 at 1:47 PM
    #2866
    ToyoDrew
    Texas
    It might be a moot point for you since you already turned it, but I used a Sharpie and marked the top of that screw (at the 12 o-clock position). With the truck about 1 foot away from a wall, I marked the wall where the top of the cutoff line is for the headlights. I then backed the truck 25 feet away from the wall and then marked the wall again where the cutoff line was now at. When the truck is 25 feet away, there should be a 2 to 3 inch drop from the first mark on the wall (when the truck was only 1 foot away).
    Mine was dropping about 5 inches if I remember correctly, so I ended up having to turn each screw a full 360 degrees in order to raise it a couple inches. As you're turning the screw, each "tooth" is super small incremental change and I couldn't see it moving with the naked eye. Because I couldn't see any movement, the only thing that really told me I had changed anything was by comparing it to the marks on the wall. Once you get out on the roads tho, then you really notice the difference!
    If anything, do as Rob said ealier and get up behind a couple sedans and make sure your lights get to the top of the trunks without actually shining into the rear windows.
    RobP62 likes this.
  7. May 31, 2018 at 2:51 PM
    #2867
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Glad I could help. It's how we roll in here.
    Were you in front of a wall? I know this sounds odd but I felt the same way. Almost like 2 or 3 turns did nothing then all the sudden it jumped up quick. Try again, but make sure you keep track so you can do them both the same.
  8. May 31, 2018 at 2:52 PM
    #2868
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Excellent advice Drew!
    ToyoDrew[QUOTED] likes this.
  9. May 31, 2018 at 3:15 PM
    #2869
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Personally for the money I have in the Hikari bulbs I am done with headlight bulbs. I am happy with what I have. Just going to put those in my faux Pro headlights this weekend. Then done with lights. Basically done with mods. I think a summer hiatus from TW is coming. Don't expect any further mods. At least not to the Tacoma. Time for a new project. Maybe another Z28.
    ToyoDrew and RobP62 like this.
  10. May 31, 2018 at 4:03 PM
    #2870
    APynckel
    APynckel Well-Known Member
    2018 MGM Tacoma TRD OffRoad 4x4 DCSB
    Bakflip MX4 Tonneau Cover XenonDepot ExtremeHID w/ Phillips bulbs
    If I wanted a set of the H11 high beams as @RobP62 is doing, and match my Phillips Xenondepot Extreme HID low beam kit as best as possible, what link should I use to order?
    RobP62 likes this.
  11. May 31, 2018 at 4:52 PM
    #2871
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    ToyoDrew likes this.
  12. May 31, 2018 at 4:54 PM
    #2872
    APynckel
    So is this the same bulb as the H11 led foglight kit?
    RobP62 likes this.
  13. May 31, 2018 at 4:58 PM
    #2873
    APynckel
    Bought
    RobP62 likes this.
  14. May 31, 2018 at 5:04 PM
    #2874
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    This is the Xtreme Pro LED bulb, which is what I'm reviewing currently. This is their top of the line LED kit.
  15. May 31, 2018 at 5:05 PM
    #2875
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You're gonna like these in the high beams for sure!
  16. Jun 1, 2018 at 12:19 AM
    #2876
    ToyoDrew
    Texas
    Wow, 20% off the already discounted price...that put it right in the sweet spot for me (and apparently @APynckel too :D )!! I literally almost bought them, it was in the cart and was filling out my info! The $32 in shipping to Hawaii brought me back to my senses tho...
    Not sure why it's so much in shipping (for 3 day air) when a USPS flat rate would have been about half that, plus it almost always makes it in 2 days (because it can ONLY go by air). Oh well...I'm moving back to mainland in a few more months, maybe I'll be able to catch a Labor Day sale or something.
    Parker315 and RobP62[QUOTED] like this.
  17. Jun 1, 2018 at 4:46 AM
    #2877
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Damn! You should have contacted them to ask for a break. I agree, $32 bucks is crazy.
    Parker315 likes this.
  18. Jun 1, 2018 at 11:51 AM
    #2878
    ToyoDrew
    Texas
    I couldn't. It was too late in the evening...which means it was the middle of the night for everyone else.
    No worries, I never use my HBs anyways (other than to flash them to get someone's attention) and I'm still very satisfied with the Hikari's in the LBs and the Morimoto's in the fogs. :D
  19. Jun 1, 2018 at 12:03 PM
    #2879
    mrproduxn
    steve
    Retired DoD SE VA
    I figured you guys in HI were switching low beams over to Lava Lamps.
  20. Jun 1, 2018 at 12:11 PM
    #2880
    ToyoDrew
    Texas
    :rofl::rofl:
