LED Lighting Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chan2565, Jun 14, 2016.
  1. Sep 21, 2018 at 4:42 AM
    #3381
    greysands
    greysands Well-Known Member
    Gray
    2018 TRD Off-Road Taco
    Upgraded interior, LEDs in and out - work in progress
    Pulled the trigger on these for the low beams and damn they really step up the night sight. Decided to swap the fogs and reverse lights too. Report back after the weather starts up.04FBDBCD-4645-4EA3-A007-8D99D302F82A.jpg2613E28C-76C7-40B4-BC1D-6288E5AA0B33.jpg
    RobP62 likes this.
  2. Sep 22, 2018 at 11:27 AM
    #3382
    Ray1989
    Ray1989 Well-Known Member
    SoCal
    3rd Gen Sport
    The LED KIT as far as color what would u rate it at 5500 or 6500. Trying 2 Match the DRL lights
  3. Sep 22, 2018 at 1:58 PM
    #3383
    orion808
    orion808 Jack of all trades. Master of none.
    Florida
    2017 Inferno Tacoma Off-Road (Premium & Tech)
    Interior LEDs Hardwired DashCam/Extra USB Black "Tacoma" on tailgate Blackened Badges Nerf Bars Mud Guards Rear Diff. Breather Mod Plasti-dipped Grille Glovebox Vinyl LED Bed Lights LED soft glow flooring accent lights Custom switches Diamondback Tonneau 3rd Bed Rail Sill Protectors w/ Vinyl Tweeter Upgrades Tint windows Husky Floor Mats Molle Panel behind seats Speaker Upgrades Anytime Camera Mod w/ Secondary Rear Camera Plan: Clazzios 2-3" Lift
    They say 6k white. Haven't received yet.
    Ray1989[QUOTED] likes this.
  4. Sep 22, 2018 at 3:05 PM
    #3384
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
  5. Sep 22, 2018 at 3:06 PM
    #3385
    Brawler1588
    Brawler1588 Well-Known Member
    NY
    2018 MGM Tacoma TRD Off Road
  6. Sep 22, 2018 at 3:27 PM
    #3386
    baldbeardedtaco
    FL
    The light not working wasn’t the problem, I mean they were physically too big/long. The done light has to 2 “prongs” the prongs have circle cutouts to House the bulb. With these prongs fully bent past normal position I still couldn’t get the ends to the circle “housing”. It was loop sided.
    It was the Sylvania zevo. I’m going to try the Philips vision instead (it’s a 30mm) maybe that will be enough
  7. Sep 22, 2018 at 7:44 PM
    #3387
    Stanley83
    Stanley83 Member
    White 2018 Tacoma TRD Pro AT
    Also converting to LED. Bought 30mm bulbs from superbrightled.com... a touch too small. Bought 31mm from Amazon.. a touch too big.... so I’m left scratching my head. I’ve left the 30mm in and it often loses contact, but I don’t really notice as the map lights are powerful.
    I’m hoping someone has this one figured out.
  8. Sep 23, 2018 at 6:47 PM
    #3388
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    The dome light contacts on the 3rd gen are expandable. It's a tension fit. The 31mm should work.
  9. Sep 24, 2018 at 7:59 PM
    #3389
    redbeard_TRD
    redbeard_TRD New Member
    Joined TW specifically to ask this question. I did some digging before posting and didn't find any information that could help me figure out what kind of light that is. I'd rather not pull my entire console apart just to find out.
    Did you, or anyone else, find out what kind of bulb it is?
    RobP62 likes this.
  10. Sep 24, 2018 at 8:54 PM
    #3390
    Stanley83
    Stanley83 Member
    Sadly it did not. Thankful for easy return policies!
    RobP62[QUOTED] likes this.
  11. Sep 25, 2018 at 4:10 AM
    #3391
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Welcome to the forum. Most of these switches have proprietary LEDs built in and may not be customizable. I know for a fact the CH4x4 switches you can buy are like that. You select the color when ordering.
    That's not to say it can't be done however.
  12. Sep 25, 2018 at 4:11 AM
    #3392
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hmmmm, well you can always ask an expert. Hey @mesojdm, what size bulb goes in the 3rd Gen dome socket?
  13. Sep 25, 2018 at 7:07 AM
    #3393
    orion808
    Florida
    I think the are talking about the light near the qi charger, not the dome. Follow the posts backwards.
    redbeard_TRD likes this.
  14. Sep 25, 2018 at 7:07 AM
    #3394
    redbeard_TRD
    Not the dome light, I already know what kind of bulb that is. I'm talking about the little light that is in the cubby hole where the QI charger is, right in front of the shifter. It's a soft white light, I'm hoping to change it to red.
  15. Sep 25, 2018 at 7:09 AM
    #3395
    orion808
    Florida
    What about just putting a red film over it? Unless you need it bright, might be the best bang for the buck. Can't see the light directly either, so can be a little sloppy if you have to.
  16. Sep 25, 2018 at 7:56 AM
    #3396
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    My original response was to this post, about the 31mm dome light bulb.
  17. Sep 25, 2018 at 7:59 AM
    #3397
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Ok, then my second response was off base then. About the QI charger light. I missed the part about "the light near" it.
    Sorry. Thanks! :thumbsup:
    redbeard_TRD[QUOTED] likes this.
  18. Sep 25, 2018 at 9:06 AM
    #3398
    baldbeardedtaco
    FL
    It must of been Friday when they made my bulb or dome light lmao.
    I had it fully extended but it wouldn’t seat properly. I’m getting a 30mm today so hopefully that does the trick
  19. Sep 25, 2018 at 9:55 AM
    #3399
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, I had a hard time when I changed over to the Meso version but made it work nonetheless.
    Maybe it is 30.5 mm o_O :D
  20. Sep 25, 2018 at 3:28 PM
    #3400
    deAutoLED.com
    deAutoLED.com Well-Known Member Vendor
    31mm worked in models we tested - we have a complete interior LED kit here:
    http://deautokey.com/product/complete-interior-led-kit-for-toyota-tacoma-3rd-gen-2016
    Video DIY that should help:
    https://www.youtube.com/watch?v=6nFRkNzwk_A
    And please check back - we are adding a lot of Tacoma Tested LEDs daily - fogs / low / High are all out:
    http://deautokey.com/category/shop-by-car-model-toyota-tacoma-all-years-trims
    Fog LEDs - H11 ON drop down:
    http://deautokey.com/product/led-headlight-fog-cree-led-bulb-with-ballast-1800-lumen
    And we suggest our HID for projectors H11 - it out-performed all LEDs tested
    ****THESE DO NOT BOUNCE WHILE DRIVING****
    We know that is a big issue and question we hear a lot - these are steady and sit correctly in your housing eliminating the bounce you sometimes see with our HID kits:
    http://deautokey.com/product/35w-slim-digital-ac-canbus-ballast-h7-h8-h11-h15-9006
    VIDEO for headlight/fogs:
    https://www.youtube.com/watch?v=2syToAHECdo
    Does anyone know the interior for the glove box and sun visors or trunk - we can add it to the kit.
    Thank you
