LED Lighting Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chan2565, Jun 14, 2016.
  1. Dec 1, 2018 at 12:39 AM
    #3741
    Sgrif513
    Sgrif513 Well-Known Member
    2019 Cement TRD Sport DCSB
    I have a 2019 TRD Sport and mine doesn't either. It's my first Taco so I guess I don't know anything different. Would be nice to have some lighting in there though.
    RobP62 and Boyitz like this.
  2. Dec 1, 2018 at 2:33 PM
    #3742
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    I have not been on this thread in a long time. I will say that I am extremely happy, both for price and output of both high and low beams, with the Hikari bulbs. I am also happy with my Baja Designs fog lights. All have performed within or above my expectations. I have made a few country road trips and have zero reasons to look for any better bulbs. The only downer, if you really want to call it that, is the BD fogs cannot be used for city driving for respect of oncoming traffic. When I need them they are fantastic.
    RobP62 likes this.
  3. Dec 1, 2018 at 2:52 PM
    #3743
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hi Steve! Nice you popped in! Great you're still happy with the Hikari's! I still say they are great bulbs. They were on sale again on Amazon the other day too.
  4. Dec 1, 2018 at 3:02 PM
    #3744
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    The Hikaris are rated as one of the best bulbs on Amazon. A close second would be the Kantana bulbs. They are the exact same bulbs as the Supernova V.4 bulb sold by Headlight Revelotion at 1/3 the cost.
    https://youtu.be/TXEJVCIsCaA
    mrproduxn and RobP62[QUOTED] like this.
  5. Dec 1, 2018 at 3:14 PM
    #3745
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :thumbsup: They really are great bulbs.
    mrproduxn likes this.
  6. Dec 2, 2018 at 12:24 PM
    #3746
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    seems that concerns raised by forum members have been heard by your mods, and thread updated. Note for 2nd gen owners looking for answers here, (you are in 3rd gen section)that specific bulb types in here focus on the 3rd gen 2016+ Tacoma models, but in general terms there is still good info in here.
    Boyitz likes this.
  7. Dec 2, 2018 at 12:29 PM
    #3747
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Nice to see the thread back on target.
  8. Dec 2, 2018 at 1:46 PM
    #3748
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
  9. Dec 2, 2018 at 7:55 PM
    #3749
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Similarities is they are all constructed of Surface Mount Devices (SMD), onto Printed Circuit Boards, that are of the right thickness to plug into the 921 socket. This is an inexpensive way to build these bulbs, some may even say cheap. Things to look for in the images are the quality of the build, how well the components are aligned, thickness of the pcb, shiny, even flow of solder. Another detail is that LEDs provide light based on how much current flows through the LED module, in comparison to its specifications. Constant current drive IC is desired.
    "Error free" is only relevant if your vehicle monitors the current draw on each circuit to determine if the bulb is the correct one. Later model vehicles use this. My only knowledge is 2005 - 2011 Tacoma is not going to need "error free" feature for bulbs I can't say for certain 2012 +.
    Next difference is the SMD LED type used. The descriptions should tell you which LED type is used, typically in the form of 2835, 3020,3035, & 2835 respectively. The #s refer to the size format of the SMD LED - specifically a 2835 is 2.8 x 3.5mm. It tells you only the size, but not the performance, however there maybe differences in performance depending on who actually supplied the SMD chipset.
    Lumens is a basic measurement of the total quantity of light, specification is often based on calculated maximum for the chipset used, but no one runs the LEDs at their maximum, as they would not last. Typically operate at 75% of maximum. Colors other than white (the 5000 - 6000 Kelvin color temperature) will have much reduced light outputs. What lumens doesn't tell you is the Color Rendering Index (CRI), and Viewing angle ( angle the light leaves the LED) & how that will interact with your reflector. We'll leave the CRI and viewing angle out of this comparison.
    unfortunately, the variations between who makes the LED chip set will vary considerably, variations between 90 lumens/watt to upwards of 160 lumens/watt output capability.
    each of these SMD LEDs are typically 0.5W LEDs. (remember they are actually only operated at 75% of max).
    Check the reviews -
    Choice #2
    https://www.amazon.com/dp/B074YBMK56?ie=UTF8#customerReviews - used in Tacoma, owner is happy.
    I think though the 15 LED examples using an internal heatsink allowing airflow through the middle of the bulb pcb is a better design at first glance compared to Choice #2 with its 18 (versus 15) LEDs
    Choice #1,3,4 - 3&4 are the same, #1 uses a slightly different chipset.
    comes down to personal choice, unless you are willing to try all three types to find the best one; probably comes down to shipping costs, reviews, and seller review with minimal difference in actual use.
    skyking3, RobP62 and Ruggybuggy like this.
  10. Dec 2, 2018 at 8:27 PM
    #3750
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Great assessment. :thumbsup:
  11. Dec 3, 2018 at 12:27 PM
    #3751
    Boyitz
    Boyitz Well-Known Member
    Baltimore
    2018 TRD Sport 4x4 DCSB Cement
    I just wanted to follow this up and say that @deAutoLED.com responded to my email immediately, and quickly sent me out replacements. I didn't get a chance to put them in until today, but the buzz is now gone. Thanks again for great customer service!
  12. Dec 3, 2018 at 1:19 PM
    #3752
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I bought these
    https://www.xenondepot.com/921-T16-Xtreme-LED-bulb-p/xt-led-921c.htm
    I liked the idea of how it would direct the light and make use of the housing. I like the temp and think it puts out good light. Also it’s appealing instead of a board packed full of leds. It doesn’t cause any bright spots with the backup cam… I actually only get a bit distracted from the backup cam from the taglights.
    I’m not a tester or have the equipment to do so, so this is just my thoughts
    RobP62 and rickm like this.
  13. Dec 3, 2018 at 2:05 PM
    #3753
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Most of the time, this is the best type of result. Real world experiences of what you see. I honestly prefer them.
    Thanks. :thumbsup:
  14. Dec 4, 2018 at 1:42 PM
    #3754
    six1five
    six1five Well-Known Member
    Kunal
    Nashville, TN
    17 SR AC 4x4 2.7L MT
    So I got the reverse/turn led bulbs from the first post. They work just fine with the headlight stalk position at DRL.
    If I turn to headlights- get some hyper flashing.
    Any recs on load resistors?
    2017 SR AC 4x4.
    RobP62 likes this.
  15. Dec 4, 2018 at 8:34 PM
    #3755
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Welcome to the forum :hattip: I wish you would have asked first before buying from the first post. That is very old and since then a lot of changes have ocurred with the technology. I'm sure some other guys will chime in but I believe you need at least 6 ohms.
    Parker315 likes this.
  16. Dec 5, 2018 at 2:59 AM
    #3756
    Parker315
    Parker315 Modding on a Budget | TTC Member #0127
    Brett
    Cypress Texas
    17 Tacoma TRD Sport DCSB MGM
    TTC (Texas Toyota Coalition) Member #127
    Ahhhhhh man.... like Rob said, You really should have asked first. All the items on the first page are WAY out dated and there are far better options out now.
    @RobP62 and I both have a newer turn signal that's not only the brightest on the market, but also doesn't require resistors .
    RobP62 likes this.
  17. Dec 5, 2018 at 3:18 AM
    #3757
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    Thanks for sharing the info!
    RobP62 likes this.
  18. Dec 5, 2018 at 7:52 AM
    #3758
    six1five
    Kunal
    Nashville, TN
    Thanks for the responses. It’s a quick shipment back to Amazon
  19. Dec 5, 2018 at 7:53 AM
    #3759
    six1five
    Kunal
    Nashville, TN
    What bulbs are you running now?
  20. Dec 5, 2018 at 8:10 AM
    #3760
    Parker315
    Brett
    Cypress Texas
    Copied from my build thread
    Lighting Upgrades: Each set change was just an upgrade from the previous. No other reason for changing. All the lights worked well.
    -LowBeam Projectors
    o 1st Set Auxbeam H11 LED F-16 Series CREE Chips(also found on Amazon)
    o 2nd Set HIKARI LED H11 (H8,H9),Philips Lumileds 12000lm 6K Cool White,2 Yr Warranty
    Hikari Ultra LED Kit - H11 Philips Lumileds
    (Excellent LED Option)
    o Current: Morimoto HID Elite 55w 6500K
    -HighBeam Reflectors
    o 1st Set HIKARI LED H11(H8,H9),CREE XHP50 9600lm 6K Cool White,2 Yr Warranty
    HIKARI LED H11, CREE Chips
    o Current: deAutoLED 45w H9 LED (AMAZING LIGHTS) New product I will get the link to these shortly
    -Fog Lights
    o 1st Set Auxbeam F-S2 Series H11 LED Bridgelux COB Chips(also found on Amazon)
    o 2nd Set Auxbeam H11 LED F-16 Series CREE Chips(also found on Amazon)
    o 3rd setup OFFROADTOWN 2pcs 3'' SAE Fog Lights – Installed Using CaliRaised brackets
    o Current: Morimoto Oval XB LED SAE Projector - (Product link here)
    -Front Turn Signals
    o 1st Set JDM ASTAR 1260 Lumens Extremely Bright PX Chipsets 7440 7441 T20 LED Bulbs,Amber Yellow Used WithAaron 50W 6ohm Load Resistors
    o Current: deAutoLED 7440 (Best I’ve seen) No Resistors Required
    -Reverse Lights
    o 1st Set Brightstar LED 921
    o 2nd: deAutoLED LED 921 (GREAT BULB) I will get the link to these shortly
    - Current: SypderAuto LED Tailights. Reverse lights Built-in.
    · License Plate Bulbs
    o 1st set: Superbright LED (flickering issues)
    o Current set: deAutoLED (great quality) I will get the link to these shortly
    -Interior Lights
    o MesoJDM Ultimate Map and Dome Lights
    o deAutoLED Vanity LED Lights I will get the link to these shortly
    @deAutoLED.com can you help me to provide the product links to the items mentioned here. I want to be sure I link the right items.
    Here is a Video I have on the FRONT turn signal bulbs
    https://www.youtube.com/watch?v=UtxbvQSd-JM
    RobP62 and deAutoLED.com like this.
