LED Lighting Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chan2565, Jun 14, 2016.
  1. Apr 23, 2017 at 11:20 PM
    #361
    Pax11B
    Pax11B Well-Known Member
    2017 Quicksand Tacoma TRD OR AC
    https://www.tacomaworld.com/threads/pax11b-quicksand-build.491885/
    Thank you kindly!
  2. Apr 25, 2017 at 10:12 AM
    #362
    Dannyblues
    Dannyblues Well-Known Member
    Danny
    New Milford Connecticut
    2016 Tacoma TRD sport 4x4 double cab black
    weather tech mats, mud flaps, black side rail step, cargo bed liner, roll up cargo bed cover, wheel locks towing package
  3. Apr 26, 2017 at 7:24 PM
    #363
    NateWest
    NateWest Well-Known Member
    Nate
    Maple Valley WA
    2017 Super white DCSB TRDOR
    After Almost a year how are the LED lights holding up? Would you do anything different? Have you had any issues or replacements?
    tcBob likes this.
  4. May 1, 2017 at 4:36 AM
    #364
    bfabpt
    bfabpt Member
    Virginia
    2020 Tacoma Pro MT
    I tried to replace taillight bulb but was not successful in removing taillight assembly. I removed 2 bolts the 2nd from the top and the bottom one but taillight wont come off. Anybody experienced the same? What is the best way to remove the tailights? Please advise, thanks in advance.
  5. May 1, 2017 at 5:39 AM
    #365
    hiroslammer
    hiroslammer Well-Known Member
    Carlsbad,CA
    2016 OR 4x4
    There's three bolts that have to be removed, second from top and bottom two, then a forceful tug.
  6. May 1, 2017 at 6:55 AM
    #366
    SuperTan
    SuperTan Well-Known Member
    Beach Cities, Cali
    17 TRD OR DCSB MGM 4x4
    I Think it's just one bolt on the bottom.
    There are two metal spikes on then outer edge of the tail, one top and one on the bottom. These two pop in. So it's going to take some force to get the originals out. You just have to pull it straight out
  7. May 1, 2017 at 6:57 AM
    #367
    SuperTan
    Beach Cities, Cali
  8. May 1, 2017 at 8:50 AM
    #368
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Nope, there are only two. Just one on the bottom, you can tell which one by loosening and you will feel the light come loose.
    But then you need to pull a fair amount as the left side is attached with some pop in things.
  9. May 1, 2017 at 11:23 AM
    #369
    NateWest
    Nate
    Maple Valley WA
    Just did the tail lights yesterday, Two screws in tail gate then everyone says light should come out with forceful pull. What I didn't remember seeing or hearing is there are two tabs behind the light holding it in. They are in the middle one on top and one on bottom of the light
  10. May 1, 2017 at 4:02 PM
    #370
    iyapysnf
    iyapysnf Well-Known Member
    2016 DC OR M/T
    Just ordered mine. Should be here later this week.
  11. May 1, 2017 at 6:05 PM
    #371
    NateWest
    Nate
    Maple Valley WA
    Any advice for changing the license plate lights? Struggling. I understand they turn and have removed one but am struggling with the other. My hands won't fit!:frusty:
  12. May 1, 2017 at 6:12 PM
    #372
    Fresh6390
    Fresh6390 Well-Known Member
    TN
    17' Super White Tacoma DCSB SR5
    Installed these Auxbeam F16s in the lows and fogs; built in Canbus; no errors. Overall way better than stock halogen bulbs. Pretty nice for $46/pair.
    17TRD, SilverII and Ecko380 like this.
  13. May 1, 2017 at 6:29 PM
    #373
    bfabpt
    bfabpt Member
    Virginia
    2020 Tacoma Pro MT
    I was able to change mine yesterday. I lay down under on each side to get a better view and try different approach. On the passenger side, I was able to use both hands. Other members suggest, removing the case by using screwdriver and reach for the tabs on each side under, then push out the case. If it still doesn't work, find a smaller hand to help you. :)
  14. May 1, 2017 at 7:28 PM
    #374
    NateWest
    Nate
    Maple Valley WA
    I was able to do passenger side with both hands also. I scratched all the skin off but i did it. drivers side has a few more cables in the way.
  15. May 1, 2017 at 9:41 PM
    #375
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This is a prime example of an incorrect lighting upgrade. While your OEM projectors manage the LED headlight source by maintaining hard cutoffs, the halogen fog reflectors have no such recourse and emit glare everywhere blinding other drivers and actually reducing your visibility in poor weather conditions. This is what is captured in this photo.
    Not sure what I am talking about? I have documented this phenomenon very well here:
    https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
  16. May 3, 2017 at 1:13 AM
    #376
    NateWest
    Nate
    Maple Valley WA
    Copy that, thanks Crashnburn. I didn't notice it until you said something. I guess I'll put the factory bulbs back in the fog lights.
    Ive ordered and installed all of OP's recommended bulbs except Im still waiting on the high beams. Im getting the hyper flash on my turn signals. any recommendations?
    Also realized the low beams OP linked to on Amazon say
    • Used for Fog lights or DRL only. No high or low beam function.
    Any Low beam links?
  17. May 3, 2017 at 4:25 AM
    #377
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Look to Morimoto fogs from The Retrofit Source for drop in replacement LED fogs. They replace the entire light housing which is needed to be LED compatible since the fogs are not projectors.
    Info on hyperflash:
    http://www.vleds.com/hyper-flash-fix-load-resistors
    The H11 bulb has no high/low function, as it is a single filiment bulb, it is just low beam/fog. The listing does not explain it well, or they are saying it is insufficient for headlights. I would be skeptical of the light output for safe headlight use. An LED that can output sufficient light for headlights will need cooling, most use bulky fans at the base of the LED and better units will use passive heat sinks of various styles at the base of the LED. Those have neither.
  18. May 5, 2017 at 9:56 AM
    #378
    obz
    obz Well-Known Member
    Utah
    2017 Silver Sky TRD Sport 4x4
  19. May 5, 2017 at 11:07 AM
    #379
    freeriderchad108
    freeriderchad108 Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    I'm nearly done with my conversion.
    So far I've done...
    Low Beams: Morimoto 5500K HID from The Retrofit Source. Provide tons more light than the LEDs I tried. I tried the AtShark, OPT7, A generic CREE, and a no-name cree brand. All of which put out the same light, which was much less intense than the 35w HID kit I have.
    Fogs: Morimoto XB fogs. Much better than the non-projectors with a brighter bulb. Put out a sharp cutoff and tons of light.
    Reverse: 921/T15 ACME from TRS. Great light for such an easy install. I'm going to install more reverse lights to help backing the boat up at night.
    License Plate: T10/194 ACME from TRS. Looks much better than the stock halogens that are nearly yellow.
    Links
    Low Beams: https://www.theretrofitsource.com/a...=51812,50562,47309,48136&preselect_restrict=1
    Fogs: https://www.theretrofitsource.com/a...Toyota+Tacoma&preselect=&preselect_restrict=1
    License Plate: https://www.theretrofitsource.com/a...Toyota+Tacoma&preselect=&preselect_restrict=1
    Reverse: https://www.theretrofitsource.com/a...Toyota+Tacoma&preselect=&preselect_restrict=1
    wahoobie likes this.
  20. May 5, 2017 at 11:49 AM
    #380
    MaddBaller
    MaddBaller Member
    2017 Taco TRD off road
    anyone got easy instructions or a video link to do the license plate bulbs... I tried but hard to put it out and change the bulbs... might be doing something wrong...
    2017 taco trd off road
