LED Lighting Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chan2565, Jun 14, 2016.
  1. Jan 5, 2019 at 10:14 AM
    #3881
    deAutoLED.com
    deAutoLED.com Well-Known Member Vendor
    I'm answering a question being asked about the deAutoLED product. It is not me simply mentioning something without a reason.
    KingRob, RogueTacoma and chris4x4 like this.
  2. Jan 5, 2019 at 10:16 AM
    #3882
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    That not how the moderators will see it.
  3. Jan 5, 2019 at 10:51 AM
    #3883
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Nope I don’t care it’s not working give me a new one
  4. Jan 5, 2019 at 11:12 AM
    #3884
    Burritoma
    Burritoma Well-Known Member
    Deep South
    2019 Quicksand SR5 V6 DCSB
    That's odd, the link now goes to $89 headlight bulbs, not the $1 194 license plate bulbs.
  5. Jan 5, 2019 at 11:28 AM
    #3885
    Techsan
    Techsan Well-Known Member
    South Texas
    2017 BBPDC
    If there’s nothing wrong with it and it’s just a bad connection/wiring issue, you might care.
  6. Jan 5, 2019 at 11:40 AM
    #3886
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    We see it, and he was addressing a question. He is welcome to do that. To add, it seems you are hell bent on trying to shit on their product. Ive checked out their stuff first hand, and before they became a vendor. I can assure you they sell good stuff, and have the customer service to back it up. SO, get off the shit posting.
  7. Jan 5, 2019 at 12:44 PM
    #3887
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    This technology advances faster than the consumer can keep up. I watched a video once where an engineer dissected a headlight LED bulb. There's not a lot going on in there. A circuit board, wiring, diodes, a fan, more wiring. It's a very unique miniaturized setup. But honestly it's very simplistic in nature. No different than any other small electronic device you can but for 5 bucks in a toy store. It just happens to have higher end components. They are assembled by machines of course and we all know how loose the quality control can be at this level of cost. Besides the diodes, a major component in the assembly is the fan. Since everything is so miniaturized and since wattage is constantly increasing, these things generate a lot of heat which is detrimental to all the small components.
    The point finally is, your buddies bulbs likely just wore out and stopped working. It's unlikely that both of the fans quit working at the same time but anything is possible. If they did though, that would definitely fry them. The only other explanation is some sort of spike or short in that part of the wiring harness. Or, as you said, bad luck.
    That's why I still endorse and am impressed with the @XenonDepot LEDs. My versions don't have fans to fail. They have heat sinks to move the heat away from the main unit. Less moving parts is what drew me to them. When I am in the truck, my lights are on too, even during the day in full sun. I honestly just leave them in the on position so I never have to remember to turn them on.
    I know none of this helps your bud right now but it might help him decide on what to replace them with.
  8. Jan 5, 2019 at 12:46 PM
    #3888
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, WTH!? I know it was correct when I linked it. I did a search online and can't seem to find them either. Sorry.
  9. Jan 5, 2019 at 1:02 PM
    #3889
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    You banned him the first time for doing exactly the same thing and your OK with it now? The vendor markets inflated priced leds that anyone can buy on Ebay. That's the reason he never posts pics of his products. I'm just making forum members aware but if your OK with it, great.
    I'm out of here.
  10. Jan 5, 2019 at 1:04 PM
    #3890
    IPNPULZ
    going to be fun!
    Checked and have power @ wire harness from the Truck send me a new one!
  11. Jan 5, 2019 at 1:14 PM
    #3891
    IPNPULZ
    going to be fun!
    So now that this has happened with Hikaris on low beams what should i use a High beams?
    RobP62 likes this.
  12. Jan 5, 2019 at 1:50 PM
    #3892
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    So you contacted the Amazon seller and they are not going to send you a coupon for a replacement bulb?
  13. Jan 5, 2019 at 1:52 PM
    #3893
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yeah, I've been searching and can't find them.
    This is all I could find. But this is all you need.
    https://www.ebay.com/ulk/itm/192219744236
  14. Jan 5, 2019 at 2:01 PM
    #3894
    IPNPULZ
    going to be fun!
    I sent them an email but have yet to hear back im sure they will take care of it. I just put my old headlights back in. I was going to buy Hikaris for the high beams but I am having 2nd thoughts now so now I need to look around for a HB replacement. I will want them to replace the pair!
    RobP62[QUOTED] likes this.
  15. Jan 5, 2019 at 2:12 PM
    #3895
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Ahh, ok. Well, I know some people are not keen on endorsements but I like my @XenonDepot Extreme Pro LEDs. At least if you have an issue you can call and speak to a person who is also an end user.
    And then there's @deAutoLED.com . I mean, I have their bulbs too in my front turn signals. They are insanely bright. And they also have excellent customer support.
    Pick one, either will not be a bad choice.
    I will only buy lighting from sources that offer customer support from now on.
    Case in point. My 42" Auxbeam lightbar developed a crack in the clear lens. Maybe stress related, maybe a stone. Ou was prepared to attempt a repair but I contacted them. It was within the warranty time frame so they sent a new light bar.
    I am a Amazon Prime member and shop there nearly daily but I definitely think twice about what I buy. Lighting, unless it's through the manufacturer will not be one.
    Parker315 likes this.
  16. Jan 5, 2019 at 2:24 PM
    #3896
    IPNPULZ
    going to be fun!
    I really want to look into the xtreme pro led lights.
    Parker315 and RobP62[QUOTED] like this.
  17. Jan 5, 2019 at 2:40 PM
    #3897
    NEPAChuy
    NEPAChuy Well-Known Member
    Jeremy
    2018 Tacoma TRD OR Blue Pearl
    Those photos do the products much better justice and they look great! Nice work. I never said they looked poor.
    The only more impressive finish I've seen personally was a filled, sanded, and airbrushed piece, which is a lot of post-processing that would drive up cost substantially.
    ToyoDrew and RobP62 like this.
  18. Jan 5, 2019 at 2:43 PM
    #3898
    NEPAChuy
    Jeremy
    This is why I've gone with deAutoLED bulbs for my truck. I read most of this thread prior to purchasing and the general consensus was great quality and customer service. My truck just seems to not get along with the bulbs and I can't figure out why. And I'm 99% certain it isn't user error. How many engineers does it take to "screw" in a light bulb?
    Parker315[QUOTED] and RobP62 like this.
  19. Jan 5, 2019 at 2:55 PM
    #3899
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    On the @XenonDepot website there is a 10% off coupon. You might get free shipping too. Would make them $108.
  20. Jan 5, 2019 at 2:56 PM
    #3900
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Now you know why I suggested @mesojdm :thumbsup:
