LED Lighting Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chan2565, Jun 14, 2016.
  1. Jan 6, 2019 at 7:33 PM
    #3901
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    any updated lists on interior LEDs? from the pages i could find, quite a few different ones that "worked" or did not fit right...
  2. Jan 8, 2019 at 9:19 AM
    #3902
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    You will be dissapointed by the inexpensive Ebay dual color. They are only 3.6Watts each.
    https://youtu.be/OiepB7FL6Sw
    Parker315, KingRob and RobP62 like this.
  3. Jan 8, 2019 at 9:25 AM
    #3903
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Great vid! A clear example of you get what you pay for in this case. That's why I don't mind spending the extra money for better lighting when I have to.
    However, there are exceptions to this rule and every once and while you spend less and get the same as people spending more. My light bars are like that.
    Parker315 and KingRob like this.
  4. Jan 8, 2019 at 11:01 PM
    #3904
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Ebay model, you take your chances. Dual color, good output, though no strobe functions, or combined color output. just switchable between 3000K (yellow) and 6000K (white) colors.
    https://www.ebay.com/itm/2X-dual-co...4-9005-9006-9007-9012-880-9000LM/142871179541
    36Watt , fan cooled, though raw lumen output is exaggerated, as are most of these type of ads.
    Realistically, an educated guess you are likely to get about 1800 - 2000 Lumen per bulb, and this should be a considerable improvement over stock, pending the beam pattern. If used in a projector it should work quite well; Reflector housing its a gamble on if you will have glare, or unwelcome shadows. Overall the design of this bulb is good with its thin center point, getting the light source as close as possible to stock filament location in the one axis.
    Parker315 and RobP62 like this.
  5. Jan 9, 2019 at 6:10 PM
    #3905
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    Opinions please on the following :
    1.) Headlight Revolution GTR LED
    2.) Headlight Revolution Supernova V4
    3.) Xenon Depot Extreme Pro LED
    4.) Other ?
    Thanks
    RobP62 likes this.
  6. Jan 10, 2019 at 4:12 AM
    #3906
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Don't waste your money on #1 buy #3 instead. Easy choice.
    Edit - check out the link in my signature.
    Parker315 likes this.
  7. Jan 10, 2019 at 5:58 AM
    #3907
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Once I get this burnt out bulb replaced. I diffidently wont be buying Hikari's ever again.....
    RobP62 likes this.
  8. Jan 10, 2019 at 6:37 AM
    #3908
    SLACKBOY
    Erich
    Washington State
    Thanks for the feedback !
    RobP62[QUOTED] likes this.
  9. Jan 10, 2019 at 7:51 AM
    #3909
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    So are they sending you another one?
  10. Jan 10, 2019 at 7:51 AM
    #3910
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You're welcome.
  11. Jan 10, 2019 at 7:55 AM
    #3911
    IPNPULZ
    going to be fun!
    This is being discussed at the moment....
  12. Jan 10, 2019 at 7:55 AM
    #3912
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Oh cool!!!!!
  13. Jan 10, 2019 at 8:00 AM
    #3913
    IPNPULZ
    going to be fun!
    I am thinking of just ordering new XD bulbs....
  14. Jan 10, 2019 at 8:03 AM
    #3914
    Parker315
    Parker315 Modding on a Budget | TTC Member #0127
    Brett
    Cypress Texas
    17 Tacoma TRD Sport DCSB MGM
    TTC (Texas Toyota Coalition) Member #127
    These are awesome! Thanks for sharing the videos. I can tell you first hand with the products I have from you guys, they are excellent quality and the performance is spot on!
    Dude, I'm blown away by what you're doing here. He simply answered a question that a member asked which was "Has anybody tried these out yet?". I'm getting tired of so many people trying to discredit a good company that's working hard to get their name and product out there. It would be one thing if their quality of products was cheap china made crap, but thats the farthest from what they have. I have 4 different products of theirs and all of them are grade A. I have a LED headlight bulb that destroyed Hikari both in Brightness, Throw, and Performance, as well as quality and i am a huge fan of Hikari.
    Thank you for posting what you did and having their back on this one. Thanks for seeing it for what it truly was. That's why I enjoy this forum so much. :thumbsup:
    Hosh541, cipherbreaker and VE7OSR like this.
  15. Jan 10, 2019 at 8:12 AM
    #3915
    IPNPULZ
    going to be fun!
    Maybe deAuto can chime in on there LED headlight bulbs?
    RobP62 likes this.
  16. Jan 10, 2019 at 8:57 AM
    #3916
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Whatever you need to know just ask @Parker315 ! He's one of the threads OG's and an Ambassador for them! He has videos too.
  17. Jan 10, 2019 at 9:02 AM
    #3917
    IPNPULZ
    going to be fun!
    deAuto LED Head lights for my 2017?
    RobP62 likes this.
  18. Jan 10, 2019 at 10:54 AM
    #3918
    Jayro
    Jayro Well-Known Member
    Los Angeles
    2019 TRD Pro and 2019 TRD Off-road
    This is cheap to do. Thank you!
    RobP62 likes this.
  19. Jan 10, 2019 at 11:39 AM
    #3919
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    RobP62 likes this.
  20. Jan 10, 2019 at 11:49 AM
    #3920
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Bulbfacts.com is a review site for Headlight bulbs, and they rank deAutoLED LED headlight bulb at the top of their premium list for the amount of light produced onto the road, and high up for their beam accuracy.
    Boyitz and Parker315 like this.
