LED Lighting Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chan2565, Jun 14, 2016.
  1. May 5, 2017 at 12:06 PM
    #381
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    There are at few threads buried in the forum about replacing those lights. Just use some keyword searches and it should pull up what you're looking for. You'll have to sift through some pages, but I do remember reading people's procedures for getting to those light connections. (It was a bit of a hassle from what I recall.)
  2. May 6, 2017 at 8:52 AM
    #382
    chan2565
    chan2565 [OP] Well-Known Member
    2016 Tacoma TRD Sport Access Cab A/T
    LED lighting, Aux fuse box, Yaesu FTM-100DR
  3. May 6, 2017 at 11:15 PM
    #383
    NateWest
    NateWest Well-Known Member
    Nate
    Maple Valley WA
    2017 Super white DCSB TRDOR
  4. May 7, 2017 at 12:20 AM
    #384
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Those are super bright, but they do not distribute light well and I would not use them for backing a trailer. Look how they compare:
    https://www.tacomaworld.com/threads/the-921-led-reverse-light-bulb-study.490137/
  5. May 7, 2017 at 6:03 AM
    #385
    freeriderchad108
    freeriderchad108 Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    I will have to so some reading!
    Thanks for the info. After a few nights I'm really not that impressed with the reverse lights so I might be doing a little fabricating
  6. May 7, 2017 at 7:56 AM
    #386
    Marine0311
    Marine0311 Member
    2016 Tacoma SR5 access cab
    K&N remote intake
    I went 4 the cheaper version which was literally only dollars saved for my interior lights and I have LED's that are not as bright as I anticipated and more blue than I had wanted I want to make crisp white light inside not the piss yellow at the stock interior lights were, so I'm definitely going to check out the lights on this post for my interior the pictures look great thanks. On my exterior forward facing lights are all Putco LED's, rear brake and third brake light are stock with a Putco LED brake, turn and reverse strip about to be installed. Just trying to get the proper part number for the towing 4 plug receptor so I can plug it in instead of hard wiring.
  7. May 7, 2017 at 3:55 PM
    #387
    Atlfan13579
    Atlfan13579 Well-Known Member
    Mammoth Lakes
    2017 White TRD Off Road 4x4
    Trd Pro Rims Trd Exhaust Trd Air filter Trd Skid plate 265-75-16
    Is there a good quality full kit for the interior lights and a kit for licence plate, reverse, back up and turn signals. Or is it better to get each individually. I see some on Amazon but they look kinda cheap.
  8. May 7, 2017 at 5:05 PM
    #388
    obz
    obz Well-Known Member
    Utah
    2017 Silver Sky TRD Sport 4x4
    I would suggest you build your own. Problem with the pre-built kits is some have had mis-matching dome lights with their map lights, mis-matching vanities, etc. Lots of people have installed the "piecemeal" sets and have provided experience in this thread... not to mention pics.
  9. May 7, 2017 at 5:08 PM
    #389
    Atlfan13579
    Mammoth Lakes
    Thanks didn't think of that.
  10. May 8, 2017 at 2:05 PM
    #390
    NateWest
    Nate
    Maple Valley WA
  11. May 9, 2017 at 5:15 PM
    #391
    freeriderchad108
    Boston
    2016 TRD Sport.
    Recommended front blinkers didn't cause hyperblink.
    Recommended rear blinkers DO cause hyperblink.
    JonnyG78 and obz like this.
  12. May 9, 2017 at 5:21 PM
    #392
    NateWest
    Nate
    Maple Valley WA
    Same here
  13. May 9, 2017 at 6:00 PM
    #393
    freeriderchad108
    Boston
    What did you do to fix it?
  14. May 9, 2017 at 6:05 PM
    #394
    NateWest
    Nate
    Maple Valley WA
    I sent the bulbs back yesterday, I really don't want to splice resistors into my brand new electronics.
  15. May 9, 2017 at 6:06 PM
    #395
    freeriderchad108
    Boston
    Yeah... I'm kinda thinking that. I'm not messing with that, but I might look into getting load resistors and making my own harness...
  16. May 9, 2017 at 6:10 PM
    #396
    NateWest
    Nate
    Maple Valley WA
    That's in interesting way to go. I like the sounds of that. Please post your findings
  17. May 9, 2017 at 6:14 PM
    #397
    freeriderchad108
    Boston
    Well...
    I'm going to try this...
    https://www.amazon.com/100W-6Ohm-LE...8772&sr=8-2&keywords=7443+load+resistors&th=1
    If they wired them wrong I can just rewire them. it'll be cheaper than buying sockets and plugs and some load resistors.
  18. May 9, 2017 at 6:18 PM
    #398
    NateWest
    Nate
    Maple Valley WA
    I looked at those, I read they they get really hot. like 300 degrees. Wondered how/where to mount to the truck
  19. May 9, 2017 at 7:02 PM
    #399
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    Look great! Still holding up well?
    Really want to swap my headlights and fogs to a more crisp white/light blue to match my led drl's but keep reading horror stories of people short out the electrical board.
  20. May 9, 2017 at 7:15 PM
    #400
    Fresh6390
    Fresh6390 Well-Known Member
    TN
    17' Super White Tacoma DCSB SR5
    I would say so; no issues; I drive with lights on during all commutes.
    LEDs are pretty nice at night. They have nice color, white with maybe a tiny hint of blue. They have a nice linear cut off that I noticed while driving back roads, nice side peripheral output, they don't project that far on distance though.
