LED Lighting Strips For Interior or Exterior
Discussion in 'Lighting' started by Drunknsloth, Feb 21, 2011.
  1. Feb 22, 2011 at 7:28 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    hey any chance you could make these using 3watt LEDs?
  2. Feb 22, 2011 at 8:21 PM
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Cool thanks.
    Mine actually are 3 watt LEDs
  3. Feb 23, 2011 at 5:35 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Are they waterproof? I'd be interested in 2 or 3 to mount under the bed rails.
  4. Feb 23, 2011 at 7:28 AM
    BlackRig
    BlackRig Well-Known Member
    Craig
    NE Ohio
    2021 SR5
    I'm probably in also. Been looking for waterproof bed lights.
  5. Feb 23, 2011 at 7:40 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  6. Feb 23, 2011 at 9:33 AM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    Subbed...might be intrested
  7. Feb 23, 2011 at 9:36 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    So is the whole light bar 3w or is each LED 3w :eek:? And how many LED's are in each 10" bar
  8. Feb 23, 2011 at 10:00 AM
    raskal311
    S. Cal
    Yeah I have the same question. My only issue is if it is 3watt each you need a heat sink so my gut is telling me its the entire bar. If each bulb is 3watt I have a side business that could use alot of these. Hey if you make these can you look in to the cost of using Cree XM-L LEDs? I need each bulb drived at 2-3watt.
  9. Feb 23, 2011 at 10:15 AM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    I would be interested in the same thing only in Blue.
  10. Feb 23, 2011 at 10:17 AM
    JLee
    Jerry
    Grass valley CA
    Yeah that's what I was thinking
  11. Feb 23, 2011 at 10:51 AM
    Drunknsloth
    Retribution
    South West
    I believe I can get fully submersible ones in the near future.
    I misunderstood the question. They are 3w per 10". I'm not sure on the exact number of LED's I'll check when I get home.
    I have RGB selectable LED bars and you can just keep them at blue.
  12. Feb 23, 2011 at 10:51 AM
    Drunknsloth
    Retribution
    South West
    I'll talk to my uncle and see what he can come up with
  13. Feb 23, 2011 at 11:10 AM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    subsicribed!
  14. Feb 23, 2011 at 11:12 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Subd. Two strips or four for bed lights?
  15. Feb 23, 2011 at 11:12 AM
    #35
    Drunknsloth
    Retribution
    South West
    :D
  16. Feb 23, 2011 at 11:16 AM
    #36
    Drunknsloth
    Retribution
    South West
    It's up to you. They are bright as hell. I'm going to put some bars in my bed/camper tonight when it's dark to see how they are and take some pictures.
  17. Feb 23, 2011 at 12:01 PM
    #37
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    So if I read correctly (remember I'm not an electrician) one (1) whole 10" strip is 3 watts and does not need a relay?
    What if you're running two strips or four?
  18. Feb 23, 2011 at 12:07 PM
    #38
    Drunknsloth
    Retribution
    South West
    I'm not sure. I'm still planning on running a small inline fuse before I get my aftermarket fuse box. I thought a relay was only if I wanted to connect it in a way that it only turns on when my ignition is on so no one drains their battery on accident.
  19. Feb 24, 2011 at 9:12 AM
    #39
    Drunknsloth
    Retribution
    South West
    There are 9 LED's in each 10" bar.
    I got pictures of the Lights in the bed of the truck with a camper shell. One 10" bar on the ceiling would be sufficient if you are on a budget. Two 10" bars would be good if you have a lot of things in your bed. If you are interested in putting the bars under the bed rails, I would recommend two under each of the sides and one under the rail near the cab. If under a budget, you do not absolutely need the one in the back but it helps the lighting a lot.
    Pictures will go up soon, I don't have the camera on me right now...
  20. Feb 24, 2011 at 9:20 AM
    #40
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
