LED Lighting Strips (Interior/Exterior)
Discussion in 'Group Buys' started by Drunknsloth, Mar 14, 2011.
Thread Status:
Not open for further replies.
  1. Mar 14, 2011 at 2:15 PM
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    NEW Group Buy:
    http://www.tacomaworld.com/forum/group-buys/188606-led-strips-rock-lights-bed-lights-etc.html
    I am currently selling LED Lighting Strips for either the interior or exterior of your cars (And for home use as well). They are pre-wired for 12v so it is very simple to wire it in your car.
    Options include:
    Color: Warm White, Cool White, and RBG Colors
    Flexiblility: Flexible or Rigid, (Flexible includes adhesive built in)
    Length: 12" of Flexible, or a pair of 10" Rigid Bars, or Custom Length cuttable every 4" (3 LEDs)
    SET PRICES FOR INDIVIDUAL PURCHASE:
    - Pair of Rigid LED Bars: $29.98
    - 12" Flex Water Proof Strip: $15.99
    - 1' Connector for Rigid LED Bar: $6.99
    - 5' Connector for Rigid LED Bar: $8.99
    - 20' Connector for Rigid LED Bar: $14.99
    - 6' 12v/Ground Connector for Rigid LED Bar: $8.99
    The Rigid Bars are water-resistant to a point out of the box. It can take the rain no problem. If you want them to be fully submersible you will need to add silicone to the ends and connections.
    Great for using in:
    -Backlighting MetalMiller's Skidplate
    -Bed Lights
    -Under Hood Lights
    -Rock Lights
    Maglight vs my Cool White LED Strips:
    More Info here: http://www.tacomaworld.com/forum/lighting/141355-led-lighting-strips-interior-exterior.html
    On My truck before Skidplate Install:
    Waterproof:
    -For Rigid Bars just add silicone to edges and connections to waterproof.
    -12" Flexible strips are waterproof rated IP68 if it is not cut. (Completely Waterproof)
    Colors:
    -For those who want changable colors, you can either buy an extra box that can control the RGB strips to any color, or you can just wire it up to light up certain colors full time. The RGB strip has one 12v wire, and one wire to ground for each of the colors. So for example, if you wanted to have a teal color you would connect the 12v wire to a 12v power source, and connect both the green and blue wire to a ground.
    I hope to be doing business with you soon.
    -Retribution
  2. Mar 14, 2011 at 3:28 PM
    Drunknsloth
    Retribution
    South West
    Colors of the RGB without the Controller box:
  3. Mar 14, 2011 at 3:30 PM
    mnudo200827
    mnudo200827 Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    ok i am in for 5 of the cool white flexible 12" strips. All 5 with there own connections. Going to put 2 under the hood and connect them to a switch and 3 in the bed and connect them to a switch. When do you plan on putting the order thru?
  4. Mar 14, 2011 at 3:37 PM
    Drunknsloth
    Retribution
    South West
    So what will happen is I get maybe 10 people to sign up, I send the order to my uncle and he'll send back the definite prices and I'll get confirmations, then the order will be put through.
    I'll actually send your order to him right now with Nixinus' and see what I get.
  5. Mar 14, 2011 at 3:46 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    def interested! ill look more into this
  6. Mar 14, 2011 at 3:51 PM
    Drunknsloth
    Retribution
    South West
  7. Mar 14, 2011 at 3:58 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Do these have a normal plug on the end that you could plug them into the outlet in the bed?
  8. Mar 14, 2011 at 4:11 PM
    Nixinus
    Nixinus Well-Known Member
    From above: "They are pre-wired for 12v so it is very simple to wire it in your car." This means you will have to run a 12v positive to the fuse box or battery (with inline fuse) and ground at the light to the frame.
  9. Mar 14, 2011 at 4:11 PM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    Put me down for 5 also! 2 strips white and 3 strips green![2 Starter Packages, One extra 12" Flexible Strip and 3 extra Connectors]
  10. Mar 14, 2011 at 4:41 PM
    97yota4wd
    Eric
    Mesa, AZ
    which are brigter the flexable ones or the bars?
  11. Mar 14, 2011 at 9:24 PM
    Drunknsloth
    Retribution
    South West
    I could include a DC to AC convertor but it would be counter productive. It would be better to save the outlet in the bed for other uses.
    Thanks man.
    Your on there now :D
    They will both have the same brightness if comparing the same colors. I have the flexible in Cool White, Warm White, and RGB colors, and the same with the rigid bars. It just depends on what your use is.
  12. Mar 14, 2011 at 9:37 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Just to be clear, a PAIR of 10" bars is $20-30 right?
    Put me down for two pairs of cool white.
  13. Mar 14, 2011 at 9:44 PM
    Drunknsloth
    Retribution
    South West
    Correct, you are down for 2 Paris of cool white (4 10" Cool white rigid bars.) Any connectors?
  14. Mar 15, 2011 at 2:21 AM
    dozer711
    dozer711 Well-Known Member
    Upstate, NY
    '09 DC SB Magnetic Gray Metallic SR5 TRD-OR
    I will take 1 Pair cool white 10" bars.
  15. Mar 15, 2011 at 9:08 AM
    Drunknsloth
    Retribution
    South West
    I'll put you down :D
  16. Mar 15, 2011 at 10:18 AM
    Stack Knots
    Stack Knots Well-Known Member
    Dan
    Pittsburgh,PA
    2012 Tacoma Off-Road
    Does anyone have a picture of these installed as bed lights? Not just being held up by someones hand but permanently installed with some kind of switch in the interior?
  17. Mar 15, 2011 at 10:30 AM
    Drunknsloth
    Retribution
    South West
    Let me find some, these aren't the same as mine but they are mounted.
    Edit: Here you go man: http://www.cardomain.com/ride/2569025/2007-toyota-tacoma-xtra-cab/page-5
    Credit to mjonags32
  18. Mar 15, 2011 at 10:36 AM
    97yota4wd
    Eric
    Mesa, AZ
    put me down for 5 Cool White 12" Flexible Strips With Connectors) [2 Starter Packages, One extra 12" Flexible Strip and 4 extra Connectors
  19. Mar 15, 2011 at 10:39 AM
    Drunknsloth
    Retribution
    South West
    Can do!
  20. Mar 15, 2011 at 10:40 AM
    97yota4wd
    Eric
    Mesa, AZ
    how much are the extra connectors?
Thread Status:
