LED Lights Flickering when turned off
Discussion in '1st Gen. Tacomas (1995-2004)' started by nkuhl16, Feb 3, 2023.
  1. Feb 3, 2023 at 12:17 PM
    nkuhl16
    nkuhl16 [OP] Member
    Nate
    Hi everyone. Recently bought some Amazon special LED lights (https://www.amazon.com/dp/B09ZNT6DNY?ref=ppx_yo2ov_dt_b_product_details). They are super bright and seem like decent quality (so far). I have them wired to the battery with a relay getting its signal from a piggyback off the high beam fuse. They come on when the high beams are on and everything works great. However, when my bights are not on, occasionally, the LED lights will flicker as if there is a voltage/current leak? I've swapped the relay and checked my grounds. I'm thinking I may need a diode to stop unwanted current flowing in the circuit or a load resistor so the LEDs act more like the halogen bulbs that the brights are used to switching on. Just wanted to see if anyone else ever had a similar issue and what they did to resolve it! Thanks!
  2. Feb 4, 2023 at 12:47 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If they’re on a relay they should be isolated from the high beam circuit.
    I’d try disconnecting the relay coil from the high beam circuit. If they keep flickering, something is up with the relay or the wiring. If they don’t, then you’ve got current in the high beam circuit that is activating the relay.
  3. Feb 4, 2023 at 5:31 PM
    UncleStan
    UncleStan Well-Known Member
    02 Double cab Tacoma
    Is your relay grounded?
  4. Feb 4, 2023 at 5:45 PM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    Some lights will strobe when turned on.. off..on ..
  5. Feb 4, 2023 at 7:18 PM
    nkuhl16
    nkuhl16 [OP] Member
    Nate
    Yeah, relay is grounded. With the high beams off, all lights off, truck running and e-brake off, the high beam circuit I’m tapping into still is giving like 7.5 amps. Enough to make the LEDs flicker I suppose.
