LED lights for License Plate Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gijoejeep, Mar 25, 2016.
  1. Mar 25, 2016 at 10:52 AM
    gijoejeep
    gijoejeep [OP] New Member
    Joe
    2016 Tacoma SR5
    LED Lamps
    So I have been looking all over for how to replace the license plate light with the LED bulb. I have the bulb, i just can't get the access to the light to replace it. It doesn't have a screw like earlier generations. I tried to twist the harness under the bumper and pull it out but no luck. Has anyone does this work before?
    i8boots likes this.
  2. Mar 25, 2016 at 11:10 AM
    Eric the Ricer
    Eric the Ricer Well-Known Member
    NOVA
    2016 Quicksand Tacoma Sport
    push/twist from the back. it's a tight fit but that's how it's done
    ffpdfirefighter2002 likes this.
  3. Mar 25, 2016 at 12:33 PM
    gijoejeep
    Joe
    2016 Tacoma SR5
    LED Lamps
    Push in towards bumper and then twist counter clockwise if looking at it from the engine ?
  4. Mar 25, 2016 at 12:37 PM
    plode682
    plode682 Well-Known Member
    Southern NJ
    2016 Tacoma TRD Off Road
    I can't even get my hand to bend the right way to reach them to change mine out. Trailer hitch makes it a real PITA.
  5. Mar 25, 2016 at 3:45 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    yep I gave up too and still have the bulbs in the console just waiting to try again another day
  6. Mar 25, 2016 at 5:27 PM
    gijoejeep
    Joe
    2016 Tacoma SR5
    LED Lamps
    Figured it out. Just grab and twist the gray piece. Use one hand to pull out the plastic a little and the other can reach it enough to turn it
  7. Jul 16, 2016 at 4:37 PM
    Tacoma Meister
    Tacoma Meister Member
    Shawn
    2016 Inferno Sport TRD
    Just installed my led license plate lights today and you are right it is a challenge with a tow package. I was able to get the right side by just twisting the grey plug counterclockwise and pushing in at the same time and it released. Replaced the bulb and reinstalled. However, the left side for some reason was more of a challenge. I couldn't push in and twist at the same time. So, I used a flat screwdriver and pushed in on the charcoal plastic lens assembly piece and popped the whole assembly forward and towards the license plate. Pulled the wire connector through, replaced the bulb, reinserted into the lens assembly and snapped it back into the bumper. In retrospect, I think releasing the whole lens assembly towards the license plate makes it a lot easier then trying to squeeze your hands into such a tight space. Don't be fooled by the heavy duty clamps on the side of the assembly. With a screw driver and proper pressure they will push in and release. Good Luck!
  8. Feb 19, 2017 at 4:57 PM
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    While fighting with that one, the bulb fell out and into the lens assembly. Do those clips lock in and need to be squeezed in on both sides, or will simply pushing towards the plate get that thing to pop out?
  9. Feb 19, 2017 at 6:17 PM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    What is the bulb model number?? The LED bulb you r using?
  10. Feb 20, 2017 at 11:59 AM
    srdatv
    srdatv Proud Tacoma Owner
    SCOTT
    massachusetts
    2017 trd sport double cab
    led interior lights,led plate lights,led low beams,side steps,rainguards,hood deflector,hood graphic,goodyear duratrac tires,sill plate decals,glove box decals.
    I used some angled needle noise pliers that are long and was able to turn the bulb to loosen it then grabbed it with my hand.yes with the tow package it is a pita,took some time but got it done.
  11. Feb 20, 2017 at 2:20 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    Yea I figured it out a while ago I forgot to update I used some needle nose as well.
  12. Feb 20, 2017 at 3:42 PM
    OBXPaul
    OBXPaul Just do what you say you're going to do!
    Paul
    Kill Devil Hills, NC (Outer Banks)
    2016 Black Tacoma Limited, 1983 Blue Deluxe Pickup
    1983 restoration in progress, major mods so far new 6" lift and 35" Mickey Thompsons.
    I changed mine from the top, just gently pry out the light from the bumper and than you can easily change out the bulb. No need to do it from underneath.
  13. Feb 20, 2017 at 3:43 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    See I knew there was a smart guy here somewhere
  14. Feb 21, 2017 at 5:53 AM
    srdatv
    SCOTT
    massachusetts
    yeah but my luck I would break the damn thing doing that.:censored:
  15. Feb 21, 2017 at 6:03 AM
    nate_scarbrough
    nate_scarbrough Well-Known Member
    Nate
    2017 Mettalic Grey TRD Off-Road
    Good luck! I did mine when I first got my truck and it was a pain in the ass.
  16. Feb 21, 2017 at 7:03 AM
    Jeffaz1
    Jeffaz1 Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    It's not easy to pry out the cover from the top without putting a couple small scratches around it. I had to do it that way on one of mine because the bulb actually fell out as I was twisting the thing back in and I couldn't get it back out any other way. Was a total pain in the ass, but I got it done.
  17. Feb 21, 2017 at 7:40 AM
    GoGoGadget
    2017 DCLB OR
    Same thing happened to me, but I popped it out from underneath. I was worried about cracking it prying from the top.
  18. Feb 21, 2017 at 9:41 AM
    OBXPaul
    Paul
    Mine came out easy, no scratches or any trouble at all.
